First Blood
setarip_old
Re: First Blood
Post by setarip_old » Mon Nov 29, 2010 7:50 am
Every title is fine except this one
Okay, that's one possible cause eliminated...
Re: First Blood
Post by mike admin » Tue Nov 30, 2010 11:07 am
Thanks for sending the log - it is a problem in MakeMKV, should be corrected in a next version. Problem is MKV-related so you should be able to do a decrypted full disc backup and play M2TS file. http://www.makemkv.com/faq/item/4
ragboy
Re: First Blood
Post by ragboy » Fri Dec 17, 2010 10:48 pm
Tried with 1.6.3, still can't makemkv, and also tried backup with 1.6.2, and eac3to couldn't read the main title.
Saving 1 titles into directory /Volumes/webstuff/mkvs/Rambo I
DEBUG: Code 149 at a+>Es62@;/*QoW6p@9h:29398116
DEBUG: Code 1 at a+>Es62@;/*QoW6p@9h:213134469
DEBUG: Code 0 at db(U'_iL&izym*Rbn#V*O:29397449
Failed to save title 0 to file /Volumes/webstuff/mkvs/Rambo I/title00.mkv
0 titles saved, 1 failed
MrTeagan
Re: First Blood
Post by MrTeagan » Fri Dec 17, 2010 11:17 pm
Same here. No luck.
Director
crowfax
Re: First Blood
Post by crowfax » Fri Dec 17, 2010 11:23 pm
Make sure you both send in new debug logs so Mike can take another look.
Re: First Blood
Post by mike admin » Sun Dec 19, 2010 8:43 am
This is an incorrectly masered disc. Please submit a full debug log from 1.6.3 - it has additional logging code written specifically to catch this error. Thank you.
bokonon
Re: First Blood
Post by bokonon » Tue Dec 21, 2010 2:19 am
Using 1.6.3 on my mac, same problem still.
Am using another bluray copy and same problem.
Attaching log.
riplin
Re: First Blood
Post by riplin » Sun Feb 13, 2011 8:22 am
MakeMKV v1.6.4 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/xxx/MakeMKV_log.txt
DEBUG: Code 5 at J'D6g}}HF]cJ7/:29395563
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in DASPI mode.
Optical drive "BD-RE HL-DT-ST BD-RE BE12LU30 4261" opened in DASPI mode.
DEBUG: Code 0 at Zx0Pz>DlaL[pA+Mp}i(dyM^\Q:213131318
Title #00000.mpls has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00001.mpls was added as title #0
File 00012.mpls was added as title #1
Title #00000.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00005.m2ts was added as title #2
Title #00006.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00009.m2ts was added as title #3
File 00010.m2ts was added as title #4
Title #00015.m2ts has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/jp/Documents/rips
DEBUG: Code 31 at @2qry0#hI`I`%1oP'di:213134377
DEBUG: Code 149 at @2qry0#hI`I`%1oP'di:29398070
DEBUG: Code 1 at @2qry0#hI`I`%1oP'di:213134423
DEBUG: Code 0 at <54*fd~SoG9h>1%2S2TL_:29397449
Failed to save title 0 to file /Users/xxx/Documents/rips/title00.mkv
tkpittman
Re: First Blood
Post by tkpittman » Sat Feb 26, 2011 8:17 pm
I have the same problem with this film.
I am using 1.6.5
windows 7 X64
I have tried 2 copies and it errors at the exact same spot
JAWTHAW
Re: First Blood
Post by JAWTHAW » Sat Mar 19, 2011 4:17 am
me too :(
Saving 1 titles into directory /Volumes/TIGERBITE
DEBUG: Code 31 at c`3WolRZvs{N2#VuL-[:213134377
DEBUG: Code 149 at c`3WolRZvs{N2#VuL-[:29398070
DEBUG: Code 1 at c`3WolRZvs{N2#VuL-[:213134423
DEBUG: Code 0 at luo#3Eb+D*r/#@J397H>s:29397449
Failed to save title 0 to file /Volumes/TIGERBITE/title00.mkv
Re: First Blood
Post by mike admin » Wed Mar 23, 2011 8:02 am
JAWTHAW wrote:me too :(
Full log from 1.6.5 please
Chest Rockwell
Re: First Blood
Post by Chest Rockwell » Fri Mar 25, 2011 2:41 am
I am having same problem. Log for 1.6.5 attached.
seantnichols
Re: First Blood
Post by seantnichols » Tue Apr 12, 2011 3:13 pm
I also am having problems with this disc. I am using 1.6.7 and was able to successfully do a full backup and even make an encoded version with Handbrake, but i'm a purest and want the main title in MKV. :P I tried to make it with the full backup and it failed about 200mb or so in, I put in the original disc and tried to go straight to MKV with the same result, i've tried turning off audio/subtitle tracks and even ripping to a different hard drive, all failed. I've attached my log.
Re: First Blood
Post by mike admin » Wed Apr 13, 2011 8:38 am
seantnichols wrote:I also am having problems with this disc. I am using 1.6.7 and was able to successfully do a full backup and even make an encoded version with Handbrake, but i'm a purest and want the main title in MKV. :P I tried to make it with the full backup and it failed about 200mb or so in, I put in the original disc and tried to go straight to MKV with the same result, i've tried turning off audio/subtitle tracks and even ripping to a different hard drive, all failed. I've attached my log.
Thanks for submitting the log from the latest version. It's a disc mastering error and workaround WILL be added in the next version.
