This becomes the minimum width of the GUI window, and so it is not possible to resize it manually to be any narrower.
Worse, the window becomes even wider still once you start extracting video, as the source path then includes the playlist file at the end of it.
![Image](https://i.imgur.com/BxbG2tr.png)
Perhaps instead of making the window grow, the displayed source path should be truncated in the GUI to fit the existing window size? After all, the specific source file is written right underneath it.
(Posting in the Linux area as I don't know if this affects other OSes or not. Running version 1.15.1)
