How to install the LibreDrive patched firmware for BD drive, in linux?
annevejb
#1 Post by annevejb » Tue Jul 07, 2020 3:28 pm
How to install the LibreDrive patched firmware for BD drive, in linux? :
Product: BD-RE BH16NS55
in linux?
Re: How to install the LibreDrive patched firmware for BD drive, in linux?
#2 Post by d00zah » Tue Jul 07, 2020 3:35 pm
in linux?
Linux native flashing
Example:
Linux How To: Flash ASUS-BW-16D1HT
annevejb
#3 Post by annevejb » Wed Jul 08, 2020 1:28 pm
Thank you for the info. I have made some progress with it.
My drive firmware is 1.03, so I assume that the approach geared to 1.04, mk-firmware-pack-20200214, is the one to use.
I got as far as getting
sudo makemkvcon f --help
to work. I still struggle with the next line:
example of use
sudo makemkvcon f -f sdf_00000076.bin -d /dev/sr0 rawflash -i ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
reconfigured for BH16NS55 and mk-firmware-pack-20200214
sudo makemkvcon f -f sdf_0000003e.bin -d /dev/sr0 rawflash -i HL-DT-ST-BD-RE_BH16NS55-1.04-NM01701-211901041342.bin
Input file not found -- HL-DT-ST-BD-RE_BH16NS55-1.04-NM01701-211901041342.bin
Internal error 0x83000001
sudo makemkvcon f -f sdf_0000003e.bin -d /dev/sr0 rawflash -i mk-firmware-pack-20200214
Input file not found -- mk-firmware-pack-20200214
sudo makemkvcon f -f sdf_0000003e.bin -d /dev/sr0 rawflash -i mk-firmware-pack-20200214/
Input file not found -- mk-firmware-pack-20200214/
sudo makemkvcon f -f sdf_0000003e.bin -d /dev/sr0 rawflash -i /home/ajb/.MakeMKV/mk-firmware-pack-20200214
Internal error 0xfffffffb
sudo makemkvcon f -f sdf_0000003e.bin -d /dev/sr0 rawflash -i /home/ajb/.MakeMKV/mk-firmware-pack-20200214/
sudo makemkvcon f -f sdf_0000003e.bin -d /dev/sr0 rawflash -i /home/ajb/.MakeMKV/mk-firmware-pack-20200214/MK/HL-DT-ST/BH16NS55/HL-DT-ST-BD-RE_BH16NS55-1.04-NM01701-211901041342.bin
Unable to load sdf.bin
Internal error 0xffffffff
sudo makemkvcon f -f sdf_00000019.bin -d /dev/sr0 rawflash -i /home/ajb/.MakeMKV/mk-firmware-pack-20200214/MK/HL-DT-ST/BH16NS55/HL-DT-ST-BD-RE_BH16NS55-1.04-NM01701-211901041342.bin
So, on that I am stuck.
Update: I have just read the posting
Re: Linux How To: Flash ASUS-BW-16D1HT
Post by MrPickle » Tue Jul 07, 2020 4:25 pm
I found it gives useful extra detail, so:
I then try:
sudo makemkvcon f -f /home/Extra/.MakeMKV/sdf_0000003e.bin -d /dev/sr0 rawflash -i /home/ajb/.MakeMKV/mk-firmware-pack-20200214/MK/HL-DT-ST/BH16NS55/HL-DT-ST-BD-RE_BH16NS55-1.04-NM01701-211901041342.bin
No drive tool logic found in SDF.bin
Internal error 0x8d000000
Still no go.
#4 Post by SamuriHL » Wed Jul 08, 2020 2:06 pm
Downgrade to 1.15.0 temporarily.
#5 Post by d00zah » Wed Jul 08, 2020 2:14 pm
example of use
I then try:
Still no go.
What made you choose/extract 'sdf_0000003e.bin''? Seems VERY old. Example used was 'sdf_00000077.bin' & the most recent I see in my '_private_data.tar'. That should eliminate the "No drive tool logic found in SDF.bin" msg.
& "-i mk-firmware-pack-20200214" isn't a valid option. That's the name of the archive, not the drive-specific FW you should be extracting from the archive. '-i HL-DT-ST-BD-RE_BH16NS55-1.04-NM01701-211901041342.bin' looked correct.
#6 Post by SamuriHL » Wed Jul 08, 2020 2:36 pm
That's what I get for reading too fast. Yes, all of that. But, sometimes the SDF won't load properly for 1.15.1. Reverting temporarily to 1.15.0 can help if you're using the proper SDF and still getting the error.
#7 Post by d00zah » Wed Jul 08, 2020 2:54 pm
Still no go.
A lot to digest in that post... :shock:
Extracting/using the correct .sdf SHOULD do the trick...
sudo makemkvcon f -f /home/Extra/.MakeMKV/sdf_00000077.bin -d /dev/sr0 rawflash -i /home/ajb/.MakeMKV/mk-firmware-pack-20200214/MK/HL-DT-ST/BH16NS55/HL-DT-ST-BD-RE_BH16NS55-1.04-NM01701-211901041342.bin
annevejb
#8 Post by annevejb » Wed Jul 08, 2020 10:46 pm
Done successfully. Gratitude.
Part of the problem could be that I save settings between OS installs by using a partition that is not affected by a fresh install. Over the years it seems to get cluttered.
I try a fresh install of MakeMKV 1.15.1. If it does not work, then I will try 1.15.0.
Using the instructions in
tar -tvf ~/.MakeMKV/_private_data.tar
This does not give any file names, just a long list of numbered bin files.
Ark of _private_data.tar gives sdf_00000078.bin.
Extracted and placed in my .MakeMKV data directory, with the firmware file.
sudo makemkvcon f -f /home/Extra/.MakeMKV/sdf_00000078.bin -d /dev/sr0 rawflash -i /home/Extra/.MakeMKV/HL-DT-ST-BD-RE_BH16NS55-1.04-NM01701-211901041342.bin
[sudo] password for ajb:
Reading input file /home/Extra/.MakeMKV/HL-DT-ST-BD-RE_BH16NS55-1.04-NM01701-211901041342.bin
Current Drive ID: HL-DT-ST_BD-RE__BH16NS55_1.03_211711201704_K9CHCO84447
y
yes
100% Operation finished
Done successfully
OS device name: /dev/sr0
Revision: 1.04
Serial number: K9CHCO84447
Firmware date: 2119-01-04 13:42
Highest AACS version: 72
Firmware version: 1.04
