#601 Post by MartyMcNuts » Tue Jun 02, 2020 8:19 am
popyMKV wrote: Tue Jun 02, 2020 8:07 am
Romeoz wrote: Thu May 28, 2020 6:13 pm I just flashed the Asus BW-16D1HT to 3.10MK, to 3.02 and now cross flashed to fix the sleep bug to WH16NS60 1.00. Does this look accurate? I get my 4K UHD disc in tonight, I want to make sure I Will be able to rip it when it arrives. Thanks
and @MartyMcNuts
Hey guys.
I have an BW-16D1HT flashed to UHD friendly 3.10MK (ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin).
Now i have read your post that an cross-flash is possible to eliminate the sleep bug.
Sadly i am an flash noob and dont want to brick my working drive.
Have downloaded the latest 22.05. ASUS flash package with modified flasher.
Can you please post me an correct guide with links and names to firmare files how to correctly cross flash without messing my drive useless?
Taht would be really nice.
Thank you
pOpY
To get rid of the sleep bug, you need to cross-flash to WH16NS60 firmware.
You will find firmware "HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936" in the "MK\HL-DT-ST\WH16NS60" folder. Just flash this firmware and you should be good to go.
popyMKV
#602 Post by popyMKV » Tue Jun 02, 2020 8:51 am
MartyMcNuts wrote: Tue Jun 02, 2020 8:19 am
and @MartyMcNuts
Hey guys.
Thank you
pOpY
Thanks a lot for the info.
Do i have to go to "DE_ASUS_BW-16D1HT_3.02.bin" like mentioned from @Romeoz or just flash from my current one:
"ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin" to your mentioned "MK\HL-DT-ST\WH16NS60\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936"
Sorry for all this questions, just want to brick anything.
UPDATE: Flashed -> DE_3.02 and then to the suggested "MK\HL-DT-ST\WH16NS60\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936" can read UHDs and sleep bug gone. Thanks a lot
thx
pOpY
sim2man
#603 Post by sim2man » Tue Jun 02, 2020 11:12 pm
I tried to flash my BP50NB40 drive, but unfortunately I found its SVC is NB40 :(
Is there any plan or existing firmware for BP50NB40-NB40? I believe SVC is the only reason I cannot flash.
This is my ODD info for just in case (from makemkv).
Product: BD-RE BP50NB40
Revision: 1.00
Serial number: MFSGB3D5216
Firmware date: 2115-04-22 15:17
Highest AACS version: 72
Firmware version: 1.00
#604 Post by MartyMcNuts » Wed Jun 03, 2020 3:24 am
sim2man wrote: Tue Jun 02, 2020 11:12 pm I tried to flash my BP50NB40 drive, but unfortunately I found its SVC is NB40 :(
Revision: 1.00
Not sure what you are asking for......
Your drive is already LibreDrive enabled. Cross-flashing for UHD readability can still work for SVC NB40's. (I've flashed a couple myself).
If you want UHD readability, you need to flash (in order):
  • from the MK pack: HL-DT-ST-BD-RE_BP50NB40-NB50-1.01-NM00200-211711231615
  • from the hybrid firmware zip file: DE_LG_BP50NB40-NB50_1.01_MK_HBD
  • from the hybrid firmware zip file: DE_LG_BP60NB10_1.00_MK_HBD
Once you done this, your drive should appear as a BP60NB10 UHD drive.
sim2man
#605 Post by sim2man » Wed Jun 03, 2020 7:37 am
MartyMcNuts wrote: Wed Jun 03, 2020 3:24 am
Revision: 1.00
I've tried them all, but all of them only give me Failure #5, which is why I thought SVC NB40 is not (fully) supported.
I can still backup non-UHD BDs so it seems to work ok, so I cannot find any reason to fail other than SVC.
Do you have any idea?
#606 Post by MartyMcNuts » Thu Jun 04, 2020 1:16 am
sim2man wrote: Wed Jun 03, 2020 7:37 am
Revision: 1.00
I'd say you are right. I noticed the firmware date is early 2015, so this drive will most likely never work with UHD.
Halewafa
#607 Post by Halewafa » Fri Jun 19, 2020 3:10 pm
I just had to create an account to thank you for your guide! I have no clue if I did the steps in the right order, but whatever I did, it worked!
I have an LG BP50NB40 1.02 which didn't work when putting in a UHD. Did two flashes and now it works like a charm!
Quigon
#608 Post by Quigon » Fri Jun 19, 2020 8:26 pm
hi,
I just have a new BW-16D1HT 3.10
I tried to downgrade to 3.01 with ASUS flasher mod and I get an error
"updating failure #4"
can someone tell me why?
#609 Post by Billycar11 » Fri Jun 19, 2020 10:35 pm
Quigon wrote: Fri Jun 19, 2020 8:26 pm hi,
yes
viewtopic.php?f=16&t=19634
#610 Post by MartyMcNuts » Fri Jun 19, 2020 11:55 pm
Halewafa wrote: Fri Jun 19, 2020 3:10 pm I just had to create an account to thank you for your guide! I have no clue if I did the steps in the right order, but whatever I did, it worked!
You're welcome!! Enjoy!!! :D
FanaTekTech
#611 Post by FanaTekTech » Fri Jun 26, 2020 7:43 pm
Hi MartyMcNuts !
Remember me when I had no solutions with my operating system when I tried to flash my drive.
But I have buy an ICYBOX and flashed successfully the drive in another computer (I have 5 computers).
I want to thank you all, continue to share your experience.
MakeMKV read my Star Wars Solo 4kUHD disc and I be happy !
Win 10 Pro 64bits / 32GB RAM / 30To / Fiber optic / RTX 2080 super on 4K Samsung TV
French Active Fansubber / Enthousiast Developer (Java, C# and others)
Has "World Community Grid" running on PC
rere130
#612 Post by rere130 » Sun Jul 05, 2020 8:15 am
I bought the Asus BW-16D1HT optical drive in my country.
With ASUS ODD FW Changer I successfully installed the 3.10MK firmware (ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin).
But big problem, none of my 4 films bought recently in UHD worked with MakeMKV. The reader was making a lot of noise. I tried several times to open and close the drawer.
I then tried to flash other firmware (DE_ASUS_BW-16D1HT_3.01.bin and DE_LG_WH16NS60_1.00.bin) but there is only firmware WH16NS60 1.02MK which works and accepts BR UHD with MakeMKV (HL- DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin).
But again a new problem, it works with MakeMKV but not with DVDFab (the software detects that the installed firmware is not accepted). And since the other firmwares do not launch blu-ray uhd it's complicated ...
Am I the only one having this problem?
Thanks for your help
#613 Post by SamuriHL » Sun Jul 05, 2020 2:28 pm
Downgrade it to ns60 1.00 and it'll work with DVDFab. It won't work with anydvd as it's not uhd friendly firmware.
rere130
#614 Post by rere130 » Mon Jul 06, 2020 8:53 am
SamuriHL wrote: Sun Jul 05, 2020 2:28 pm Downgrade it to ns60 1.00 and it'll work with DVDFab. It won't work with anydvd as it's not uhd friendly firmware.
Thanks for your answer :)
Wich version of LG WH16NS60 1.00 ?
Because I already try "DE_LG_WH16NS60_1.00.bin" and that's not working. The reader was making a lot of noise and that's all :(
I don't see another firmware NS60 1.00 in this pack : viewtopic.php?f=16&t=18933 (22/05/2020)
Except this one in MK folder : HL-DT-ST-BD-RE_BH16NS60-1.00-NM00500-211804030945 but I don't know if that's the same drive than WH16NS60.
Today with WH16NS60 1.02 MK (who was working yesterday), that's not working anymore too... :( I'm going to plug it into another sata port and with another cable to try.
#615 Post by d00zah » Mon Jul 06, 2020 12:39 pm
rere130 wrote: Mon Jul 06, 2020 8:53 am Except this one in MK folder : HL-DT-ST-BD-RE_BH16NS60-1.00-NM00500-211804030945 but I don't know if that's the same drive than WH16NS60.
'BH' (retail, boxed) vs 'WH' (OEM, bulk)... same HW, for all intents & purposes. That FW is fine.
