Broadchurch S2D2 00031.mpls LIBMKV_TRACE: Exception: Error while reading input
kevmitch
#1 Post by kevmitch » Thu Jul 02, 2020 3:38 am
All but one title on this disc will rip fine. The one that fails is 00031.mpls, segments map 27,28,29,30,31,32. The behaviour is consistent between both my drives
BD-RE ATAPI iHBS212 2 53T1
BD-RE ASUS BW-161DHT 3.10 (patched libredrive firmware)
I am able to do a full disk decrypted backup without issue. When I open the index.bdmv, the titles strangely appear in a different order. However, if I try and rip 00031.mpls from its new order in the backup I get the same error. I have attached a debug log from this last case.
If I deselect the only audio track, which is Stereo LPCM, the title rips without issue.
I have prepared a stripped down backup consisting of only this title, which is about 4.4Gb. I would be happy to upload this somewhere if it helps with analysis.
MakeMKV_log.txt
(46.31 KiB) Downloaded 1010 times
Grauhaar
Re: Broadchurch S2D2 00031.mpls LIBMKV_TRACE: Exception: Error while reading input
#2 Post by Grauhaar » Thu Jul 02, 2020 9:01 am
Are you using a conversion (LPCM f.e to FLAC) for the audio track?
Good Luck :)
kevmitch
#3 Post by kevmitch » Fri Jul 03, 2020 3:54 am
I'm using the unmodified Default profile.
The GUI info pane says
Output format: Raw LPCM audio without channel configuration metadata ( Lossless conversion )
Output description: Save as raw LPCM
kevmitch
#4 Post by kevmitch » Fri Jul 03, 2020 4:18 am
I also get the same result if i try the FLAC profile.
kevmitch
#5 Post by kevmitch » Fri Jul 03, 2020 8:02 am
Ah, the problem is only present in the latest version makemkv-bin_1.15.1. If I downgrade to makemkv-bin_1.15.0, I can rip the title without issue. The 1.15.0 debug output is attached.
MakeMKV_log-1.15.0.txt
(6.46 KiB) Downloaded 1093 times
Hypothesis
#6 Post by Hypothesis » Mon Jul 06, 2020 7:46 am
I think I'm experiencing the same audio issue, how do debug downgrade?
timay
#7 Post by timay » Fri Jul 10, 2020 3:05 pm
I have a feeling that this thread is talking about the same issue: https://makemkv.com/forum/viewtopic.php?f=8&t=22465 . I have the same issue with a different disc that also has stereo LCPM using version 1.15.1 . I haven't tried downgrading but i can post a debug log if that would be helpful.
kevmitch
#8 Post by kevmitch » Mon Nov 09, 2020 3:36 am
Just to close the loop on this, I saw the same behaviour with 1.15.2, but it seems to be fixed in 1.15.3.
