It’s more reliable for playback on lg tvs internal player and supports dual track dolby vision. It doesn’t support atmos audio but if you’re playing it off the tv, it doesn’t matter.Chuck_IV wrote: ↑Sat Jul 04, 2020 9:17 pmSo not knowing much about mp4muxer, is this something that should be used over tsmuxer all the time or just for TV based apps(maybe LG specific)? I ask because I used tsmuxer(4.06 fixed) for all mine(3 movies and 2 seasons of Westworld) and they play perfectly. However, I play them on an Nvidia Shield 2019.
Dolby Vision and 1.15.1
Re: Dolby Vision and 1.15.1
Download test files: (dvhe.07)oldirtydog wrote: ↑Sat Jul 04, 2020 8:59 pmi really want to see the different between hdr and DV on my C9![]()
13 Hours.teaser.DV.mp4 - 213.2 Mo
Alita, Battle Angel.teaser.DV.mp4 - 290.2 Mo
You will have HDR10 when you will play the files on your PC.
You will have DV when you will play the files on the LG player.
thank you ,i have over 20 movies on mp4 with vision downloaded from HD-torrent,but my priority is DV and Atmos trueHD:) i think to buy sony x700 online to make 1,2 days test with my DV and atmos movies and it is not ok i will return to the shopdaddy wrote: ↑Sun Jul 05, 2020 5:27 amDownload test files: (dvhe.07)oldirtydog wrote: ↑Sat Jul 04, 2020 8:59 pmi really want to see the different between hdr and DV on my C9![]()
It will be hard to advise with pirate downloads.oldirtydog wrote: ↑Sun Jul 05, 2020 6:47 amthank you ,i have over 20 movies on mp4 with vision downloaded from HD-torrent,but my priority is DV and Atmos trueHD:) i think to buy sony x700 online to make 1,2 days test with my DV and atmos movies and it is not ok i will return to the shopdaddy wrote: ↑Sun Jul 05, 2020 5:27 amDownload test files: (dvhe.07)oldirtydog wrote: ↑Sat Jul 04, 2020 8:59 pmi really want to see the different between hdr and DV on my C9![]()
You will have DV when you will play the files on the LG player.14 day trials xaxa i really dont understand why only 1 movies from 6 playing perfekt on LG C9 ...
For a profile 5 DV you want to use 05.06 fix. And tsMuxer Nightly is the best for Sony x700.oldirtydog wrote: ↑Sat Jul 04, 2020 3:45 amI used 04.06 fixed ?
I can confirm you that the x700 won't plays all those single layer files( BL+EL+RPU) unless it's a MEL DV movie.oldirtydog wrote: ↑Sun Jul 05, 2020 6:47 ami think to buy sony x700 online to make 1,2 days test with my DV and atmos movies and it is not ok i will return to the shop14 day trials xaxa i really dont understand why only 1 movies from 6 playing perfekt on LG C9 ...
But it doesn't matter because that player will play any dual-layer profile 7 TS file produced by the latest tsMuxer with Atmos+subs.
pls send me the dual layer profil 7 tsmuxer and if i choice x700 i dont need to use yoroscope to do single layer correct ? only m2ts file to tsmuxer to ts and atmos sound from eactogui?RESET_9999 wrote: ↑Sun Jul 05, 2020 2:06 pmI can confirm you that the x700 won't plays all those single layer files( BL+EL+RPU) unless it's a MEL DV movie.oldirtydog wrote: ↑Sun Jul 05, 2020 6:47 ami think to buy sony x700 online to make 1,2 days test with my DV and atmos movies and it is not ok i will return to the shop14 day trials xaxa i really dont understand why only 1 movies from 6 playing perfekt on LG C9 ...
I have been following this thread with great interest and some of it is over my head I'll admit. I'm trying to make a DV profile 5 that will play on Apple TV via Infuse. I know the audio limitations and I only have a 5.1 system anyway. I've tried many versions of tsmuxer with no success. Apparently my Google search skills have diminished in my old age. I cannot find anything having to do with the 04.06 fix or 05.06 fix being discussed here. I'm guessing these are tsmuxer versions? Is this what I need? And if so, where can I find it? Any help is greatly appreciated.
correct, yusesope tool is not needed with the x700. If your source is an original m2ts, then no need to use eac3to as well. m2ts straight to dual-layer profile 7 TSoldirtydog wrote: ↑Sun Jul 05, 2020 2:59 pmpls send me the dual layer profil 7 tsmuxer and if i choice x700 i dont need to use yoroscope to do single layer correct ? only m2ts file to tsmuxer to ts and atmos sound from eactogui?
you can find the latest tsMuxer here: https://bintray.com/justdan96/tsMuxer/t ... htly#files
tsMuxer (04.06 fix)).rarniteflyr wrote: ↑Sun Jul 05, 2020 3:15 pmI have been following this thread with great interest and some of it is over my head I'll admit. I'm trying to make a DV profile 5 that will play on Apple TV via Infuse. I know the audio limitations and I only have a 5.1 system anyway. I've tried many versions of tsmuxer with no success. Apparently my Google search skills have diminished in my old age. I cannot find anything having to do with the 04.06 fix or 05.06 fix being discussed here. I'm guessing these are tsmuxer versions? Is this what I need? And if so, where can I find it? Any help is greatly appreciated.
https://drive.google.com/file/d/1q5v4-J ... sp=sharing
To original m2ts is file on disc or torren full copy with folder BDMV an all this shitRESET_9999 wrote: ↑Sun Jul 05, 2020 3:17 pmcorrect, yusesope tool is not needed with the x700. If your source is an original m2ts, then no need to use eac3to as well. m2ts straight to dual-layer profile 7 TSoldirtydog wrote: ↑Sun Jul 05, 2020 2:59 pmpls send me the dual layer profil 7 tsmuxer and if i choice x700 i dont need to use yoroscope to do single layer correct ? only m2ts file to tsmuxer to ts and atmos sound from eactogui?
Yeah, you're not gonna get people here to help you out with your pirated copiesoldirtydog wrote: ↑Sun Jul 05, 2020 3:44 pmTo original m2ts is file on disc or torren full copy with folder BDMV an all this shitRESET_9999 wrote: ↑Sun Jul 05, 2020 3:17 pmcorrect, yusesope tool is not needed with the x700. If your source is an original m2ts, then no need to use eac3to as well. m2ts straight to dual-layer profile 7 TSoldirtydog wrote: ↑Sun Jul 05, 2020 2:59 pmpls send me the dual layer profil 7 tsmuxer and if i choice x700 i dont need to use yoroscope to do single layer correct ? only m2ts file to tsmuxer to ts and atmos sound from eactogui?
you can find the latest tsMuxer here: https://bintray.com/justdan96/tsMuxer/t ... htly#filesbecause i use torrents to downloads this full copy
Look for the tsMuxer you need on page 161 in Dolby Vision now possible through MP4 Mux thread. Trujax kindly shared it over there, and it forces profile 5 DV, which will run nicely on your ATV4K via Infuse. Of course, before trhat you'll need to use yusesope tool to make a one layer DV file - but I assume you already know the drill?niteflyr wrote: ↑Sun Jul 05, 2020 3:15 pmI have been following this thread with great interest and some of it is over my head I'll admit. I'm trying to make a DV profile 5 that will play on Apple TV via Infuse. I know the audio limitations and I only have a 5.1 system anyway. I've tried many versions of tsmuxer with no success. Apparently my Google search skills have diminished in my old age. I cannot find anything having to do with the 04.06 fix or 05.06 fix being discussed here. I'm guessing these are tsmuxer versions? Is this what I need? And if so, where can I find it? Any help is greatly appreciated.
Does the ATV4K only play profile 5 DV correctly? Or is that an Infuse thing? I've been using MrMC on ATV4K for the .04.06 files I prepared for my Shield, and they play and trigger LLDV fine. Then again, I have no frame of reference for DV other than the Vertex2 saying it's getting LLDV on input. Do these work correctly?Alldu wrote: ↑Sun Jul 05, 2020 6:10 pmLook for the tsMuxer you need on page 161 in Dolby Vision now possible through MP4 Mux thread. Trujax kindly shared it over there, and it forces profile 5 DV, which will run nicely on your ATV4K via Infuse. Of course, before that you'll need to use yusesope tool to make a one layer DV file - but I assume you already know the drill?
Just a question with uncertainty with how we may in the end need to create files... are we better off backing these up with Dual Video as in Video 1 and Video 2. Or will we be able to re-create what is needed in the end with what we have via makemkv as in 1 video ??? I'm guessing we will have to re-create some movies...
Thanks in advance...
lata
zomorf
zomorf
