BD-RE BU40N Revision: 1.04
metasynapse
#1 Post by metasynapse » Thu Jul 02, 2020 11:33 am
Hello friends!
I have the following drive:
Product: BD-RE BU40N
Revision: 1.04
Serial number: MZ3J5KG5755
Firmware date: 2120-05-06 11:42
Highest AACS version: 66
Harware support: Yes
Firmware support: No
Firmware version: 1.04
and I don't really know how to flash exactly this version of firmware. Any ideas? Thanks in advance!
Just for sure :)
Just for sure :)
Re: BD-RE BU40N Revision: 1.04
#2 Post by Billycar11 » Thu Jul 02, 2020 11:40 am
Probably also the new encrypted type you must use the makemkv command line flasher
metasynapse
#3 Post by metasynapse » Thu Jul 02, 2020 11:51 am
ok, thanks, but which firmware version should I use?
icourt
#4 Post by icourt » Thu Jul 02, 2020 11:57 am
Well, looks like drives with the new encrypted firmware are starting to show up fairly frequently!
metasynapse
#5 Post by metasynapse » Fri Jul 03, 2020 12:45 pm
something weird just happen. Operation was successful, but firmware is still 1.04? what the heck?
AffSeda
#6 Post by AffSeda » Fri Jul 03, 2020 1:15 pm
This might be a dumb question, but since it says ROM 1.03 on it (I assume manufactured with that) and has arrived to him with 1.04, does this mean they're upgrading the firmware at suppliers?
metasynapse
#7 Post by metasynapse » Fri Jul 03, 2020 1:17 pm
I don't see any other explanation...
TeddyRaspin
#8 Post by TeddyRaspin » Fri Jul 03, 2020 3:33 pm
Put "enc" option (without quotes) after rawflash because if your unit comes with 1.04 it will accept only fw in encrypted format.
metasynapse
#9 Post by metasynapse » Fri Jul 03, 2020 4:01 pm
It works! :) Thanks, just...stupid mistake. Now I have 1.03 ripping capable drive!
TeddyRaspin
#10 Post by TeddyRaspin » Fri Jul 03, 2020 4:42 pm
Glad to hear that. :wink:
Ezatoka
#11 Post by Ezatoka » Sat Jul 04, 2020 12:00 am
Unrelated question:
Why are the serial numbers from MakeMKV and from the sticker different?
metasynapse
#12 Post by metasynapse » Sat Jul 04, 2020 11:28 am
Unrelated question:
it also makes me wonder. The drive comes from a legal distribution ... I think the distributor or supplier has changed the firmware (forcibly?). This is really strange.
AffSeda
#13 Post by AffSeda » Sat Jul 04, 2020 12:06 pm
I'd guess the number MakeMKV is displaying is actually the serial number of the drive controller / internal device, rather than the serial of the entire unit as a whole (whats on the label).
#14 Post by mike admin » Sat Jul 04, 2020 10:15 pm
I think they are running some sort of upgrade process (could be recall / refurbish) where the drive gets a new firmware with encryption, and changes its serial number in a process.
ssybesma
#15 Post by ssybesma » Sat Jun 04, 2022 1:06 am
Any benefit to downgrading the firmware from 1.04?
1.02 is here: https://www.lg.com/us/support/software- ... CT30011742
Is 1.03 the patched version that MakeMKV references in the LibreDrive section?
This what I have:
Revision: 1.04
Serial number: MODK5IE2313
Highest AACS version: 65
Steve
