You should use the modified ASUS flasher.bioteq wrote: Mon Feb 17, 2020 3:39 pmcongrats on the upgraded drive, one question though - what updater did you use to get to bn11, I'm seeing only the 2.00 updater from Buffalo which you linked earlier, not sure if this contains what I need?planet1 wrote: Wed Jun 19, 2019 10:25 pm just wanted to report back that my Buffalo BRXL-PT6U2VB is a UHD-friendly device now
Do I even need to update or do I just cross-flash to 1.03 from Mike?
Thanks for all the info!
Is there a way to downgrade the firmware on a Buffalo BRUHD-PU3 from BU11 to BU10?
Re: BRXL-PT6U2VB is UDH-friendly NOW
Re: Is there a way to downgrade the firmware on a Buffalo BRUHD-PU3 from BU11 to BU10?
OK thank you, that's all I needed to know to get on with it.
I'll report back
I'll report back
So how did it go? My Buffalo drive really needed the LG LibreDrive FW (1.03) in order to read the UHD blu-ray discs.bioteq wrote: Mon Feb 17, 2020 11:10 pm OK thank you, that's all I needed to know to get on with it.
I'll report back![]()
I always use the 1.00 BU40N firmware I wonder what the differences are.
I've got pre-flashed BU40Ns for sale in either the Buffalo or Vantec enclosures. Immediate shipping available.
Hi All,
I just get my Buffalo BRUHD-PU3 today, and I am using DVDFab UHD tool to downgrade it to BU10 by just a click, and completely successful.
But you could have saved $75-$110 by following the guides herepk3lee wrote: Thu Jul 02, 2020 1:02 am Hi All,
I just get my Buffalo BRUHD-PU3 today, and I am using DVDFab UHD tool to downgrade it to BU10 by just a click, and completely successful.![]()
rmccarroll
It works!planet1 wrote: Wed Jun 19, 2019 10:25 pm Hello,
just wanted to report back that my Buffalo BRXL-PT6U2VB is a UHD-friendly device now:
1. Crossflashing worked like a charm with this MK firmware
2. Device shows up as LibreDrive compatible:
3. and CAN FINALLY READ UHD-blurays:
@mike admin
Just in case you might be still interested in Buffalo firmwares, they released a new FW update tool [brdrive_fwupdater_200.exe], featuring:
a. Buffalo_BU40N_FW_Updater_2.01.exe
b. Buffalo_BH16NS58_FW_Updater_2.01.exe
- I used the firmware you linked
- I used the ASUS Crossflash exe if found on this site
Took all of 2 minutes.
Thanks planet1 for your post
Thanks makemkv.com forum contributors for your help
