Liersi
#2641
Post
by Liersi » Wed Jul 01, 2020 6:55 pm
That worked. At least initially, now I can't get it to recognize the DV anymore in Plex, but it worked. The inconsistency may be due to the unusual setup with the Vertex2 emulating a compatible EDID. I'll look there first and see if I can fix it. Thanks a lot for the help Shawn.
I hope an mkv-based solution and playback in Kodi are in the near future.
EDIT: playback in DV works reliably on the AT4K. Issue's on the Shield or with Plex. Working on it.
planet_hoarder
#2642
Post
by planet_hoarder » Thu Jul 02, 2020 7:43 am
Liersi wrote: ↑Wed Jul 01, 2020 6:55 pm
you can also try profile 8 with nightly release tsMuxer from 16-th March 2020.
https://bintray.com/justdan96/tsMuxer/t ... 1-36#files
I read it works on Shield (with lossless), and works on LG WebOS (without lossless)
Liersi
#2643
Post
by Liersi » Thu Jul 02, 2020 3:13 pm
Just in time for the testing tonight. Thank you very much! The 04.06 fix version appears to work, the Shield TV always picks up DV given the right player (MrMC is reliable). I'm still struggling with my projector not triggering its HDR mode, but that isn't due to the file I believe. But who knows, I'll report back if this works, and how well it does if it does. Have a bunch of re-ripped mkvs from my backups (thank you foresight) ready for remuxing.
userr
#2644
Post
by userr » Thu Jul 02, 2020 3:44 pm
Liersi wrote: ↑Thu Jul 02, 2020 3:13 pm
are you saying youre playing profile 4 (04.06) mp4 in MrMc on 2019 shield?
#2645
Post
by shawnc22 » Thu Jul 02, 2020 4:09 pm
I'm guessing you've been following the steps from here?
https://www.avforums.com/threads/dolby- ... s.2254350/
If so, it's probably not the file that's the issue. Nevermind that profile 8 is wrong for these kind of files, it's not going to matter much on the Shield. It's surprising though that you've been having issues with Plex. Have you been turning off PGS subtitles? If you're worried about your remux process, give these sample files a try:
https://mega.nz/file/YSxhkSLK#fkfy54tYV ... xIOBZLyGR4 (MEL)
https://mega.nz/file/MHpBBLjK#4bM5jsNgP ... glhYbzLcQ0 (FEL)
Liersi
#2646
Post
by Liersi » Thu Jul 02, 2020 6:47 pm
Thank you Shawn. I hadn't seen that thread on avforums. A helpful HDfury rep on AVSforum spotted my problem like a hawk and solved it. The thread you linked to would have solved it as well. You need to force an HDR frame in another tab to make it work. Somehow overlooked that in the instructions I followed. Thanks again for following up on this, that's very gracious of you.
EDIT: by the way, you were also right about Plex. MrMC started crashing, and with this latest fix, Plex is working swimmingly. Cheers for that, too.
BringerChaos
#2647
Post
by BringerChaos » Fri Jul 03, 2020 2:13 pm
Is it possible to re encode the BL.hevc and use that along with the EL.hevc to make a smaller sized Dolby Vision capable file?
#2648
Post
by MartyMcNuts » Sat Jul 04, 2020 12:14 am
BringerChaos wrote: ↑Fri Jul 03, 2020 2:13 pm
Yes, check my posts in this very thread. (page #170)
For UHD enabled drives (AU/NZ/SG + Others) & DIY Single Drive Flasher (WW):
https://uhdenableddrives.com
userr
#2649
Post
by userr » Sat Jul 04, 2020 3:31 am
Cant delete post so i just edit it and remove it, cause question has been answered
userr on Sat Jul 04, 2020 5:34 pm, edited 1 time in total.
Liersi
#2650
Post
by Liersi » Sat Jul 04, 2020 9:02 am
userr wrote: ↑Thu Jul 02, 2020 3:44 pm
I only saw this question now. As you probably read further down, MrMC crashes after a while. Didn't realize this while testing short clips. They're .ts in my case, not .mp4, but I'm sure it comes to the same thing. MrMC does pick up on the DV more reliably than Plex, though, so I'm sad that is ultimately crashes. Last night, Plex wasn't sending LLDV at all with any of the files that worked previously.
stehohrhase
#2651
Post
by stehohrhase » Sat Jul 04, 2020 9:15 pm
Is it possible to convert FEL -> MEL or use only RPU ?
FEL is to much data.
planet_hoarder
#2652
Post
by planet_hoarder » Sun Jul 05, 2020 4:51 pm
stehohrhase wrote: ↑Sat Jul 04, 2020 9:15 pm
so far not possible to convert FEL to MEL, but you can use yusecope's tool in mode 2, I think, it creates BL+RPU
stehohrhase
#2653
Post
by stehohrhase » Mon Jul 06, 2020 3:37 am
I have recode/shrink my BL. It is now 10 GB.
EL (FEL) is 11 GB.
I have use yoseptools in Mode 2. Result: Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2086, HDR10 compatible.
But final size is 21 GB.
sullenhell
#2654
Post
by sullenhell » Mon Jul 06, 2020 10:49 pm
I have a few MP4 DV files that play blank screen with audio on my TCL Roku R613. From reading this thread I believe it's because they need to be profile 4/5. Is there an easy way to convert those MP4 files to profile 4/5 or would I have to start from scratch?
userr
#2655
Post
by userr » Tue Jul 07, 2020 1:28 pm
RESET_9999 wrote: ↑Fri Jun 26, 2020 11:22 am
box4m wrote: ↑Fri Jun 26, 2020 11:11 am
am i correct when i say 59.94fps + DV is beyond HDMI2.0b standard?
no you are not.
no playback issue on bluray players. My x700 play that movie at 60fps in DV+ Atmos + subs just fine.
thinking of buying x700, does it play profile 7 .ts or .mp4 with atmos from network share or plex?
im also curious, how do you know its actually recognizing DV, when u have to enable DV in settings, we dont know that its triggering and playing it correctly?
thanks
