besson
Post by besson » Tue Jun 30, 2020 1:01 am
shawnc22 wrote: Mon Jun 29, 2020 11:45 pm
besson wrote: Mon Jun 29, 2020 5:37 pm Ok, backing up a bit I want to know how to create the file that would work if i had a setup that could play this. From there I will buy whatever...price not an issue.
If price is not an issue, I'd ditch that whole soundbar set up and a get real receiver + speakers :). Going through all this trouble to get fake atmos playing on a soundbar is just not worth the trouble imo. Not to mention any potential audio passthrough issues with the TV or video passthrough issues with the soundbar that you might run into. As far as creating the files go, just scroll a couple posts up on this page and there're some general steps that I outlined.
Well that is the crux of my issue, I will definitely read more back, but how involved of a process is this? I have about 40 UHD movies so far in my collection, and I understand it'll be lengthy, I just wish there was a magic program like Makemkv to make these files.
Post by shawnc22 » Tue Jun 30, 2020 2:19 am
besson wrote: Tue Jun 30, 2020 1:01 am
When the next version of makemkv arrives, it'll be just that. Maybe by the time you get your setup situation resolved, it'll be ready.
Liersi
Post by Liersi » Wed Jul 01, 2020 1:46 pm
shawnc22 wrote: Mon Jun 29, 2020 4:10 pm Needing to send a LLDV signal won't affect the kind of file you have to create. If you don't want to wait for the new DV-compatible mkv containers, the easiest way right now is to go from disk -> mkv with makemkv 1.15.1. If atmos audio is present, extract it with eac3to to thd+ac3 format. Then add mkv and extracted track into either latest nightly build of tsmuxer or the 04.06 fix version that most have been using around here and mux.
I'm just getting to try this today, and looking at tsmuxer the question for me is the output container. Tsmuxer obviously does ts or m2ts, but everyone's talking about mp4. Does m2ts work?
Post by shawnc22 » Wed Jul 01, 2020 3:36 pm
Liersi wrote: Wed Jul 01, 2020 1:46 pm
Yes it’s the only container at the moment that can do dv + atmos. MP4 does not support atmos audio
Liersi
Post by Liersi » Wed Jul 01, 2020 4:39 pm
shawnc22 wrote: Wed Jul 01, 2020 3:36 pm Yes it’s the only container at the moment that can do dv + atmos. MP4 does not support atmos audio
Figured as much and started testing. I'm using Plex on Shield as that's supposed to work. Latest Tsmuxer nightly on Win10 (w64-nightly-2020-06-27--02-14-32). Image stays black on playback. DV confirmed working with streaming on the same setup. Mediainfo shows DV in the resulting file, I'll attach the rundown:
General
Format : BDAV
Format/Info : Blu-ray Video
File size : 47.5 GiB
Duration : 1 h 45 min
Overall bit rate mode : Variable
Overall bit rate : 64.7 Mb/s
Maximum Overall bit rate : 35.5 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
Commercial name : HDR10
Dolby Vision : 1.0, dvhe.06.06, BL+EL+RPU
Codec ID : 6
Bit rate : 61.4 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 24.000 FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.309
Stream size : 45.2 GiB (95%)
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 630 cd/m2
Maximum Frame-Average Light Level : 460 cd/m2
Audio
Menu ID : 1 (0x1)
Format : AC-3 MLP FBA 16-ch
Format/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Muxing mode : Stream extension
Codec ID : 131
Bit rate mode : Variable
Bit rate : 640 kb/s
Maximum bit rate : 7 896 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 482 MiB (1%)
Service kind : Complete Main
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Seems to all be there, just won't play. Does anyone see aynthing that's obviously wrong?
Post by shawnc22 » Wed Jul 01, 2020 5:02 pm
Liersi wrote: Wed Jul 01, 2020 4:39 pm
General
Format : BDAV
Video
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 6
Color space : YUV
Bit depth : 10 bits
Audio
Menu ID : 1 (0x1)
Codec ID : 131
Bit rate : 640 kb/s
Bit depth : 16 bits
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Could be an issue with the nightly. Try the exact same steps but with this version here:
https://drive.google.com/file/d/1q5v4-J ... gPqCD/view
Liersi
Post by Liersi » Wed Jul 01, 2020 6:55 pm
shawnc22 wrote: Wed Jul 01, 2020 5:02 pm Could be an issue with the nightly. Try the exact same steps but with this version here:
That worked. At least initially, now I can't get it to recognize the DV anymore in Plex, but it worked. The inconsistency may be due to the unusual setup with the Vertex2 emulating a compatible EDID. I'll look there first and see if I can fix it. Thanks a lot for the help Shawn.
I hope an mkv-based solution and playback in Kodi are in the near future.
EDIT: playback in DV works reliably on the AT4K. Issue's on the Shield or with Plex. Working on it.
planet_hoarder
Post by planet_hoarder » Thu Jul 02, 2020 7:43 am
Liersi wrote: Wed Jul 01, 2020 6:55 pm
you can also try profile 8 with nightly release tsMuxer from 16-th March 2020.
https://bintray.com/justdan96/tsMuxer/t ... 1-36#files
I read it works on Shield (with lossless), and works on LG WebOS (without lossless)
Liersi
Post by Liersi » Thu Jul 02, 2020 3:13 pm
planet_hoarder wrote: Thu Jul 02, 2020 7:43 am you can also try profile 8 with nightly release tsMuxer from 16-th March 2020.
Just in time for the testing tonight. Thank you very much! The 04.06 fix version appears to work, the Shield TV always picks up DV given the right player (MrMC is reliable). I'm still struggling with my projector not triggering its HDR mode, but that isn't due to the file I believe. But who knows, I'll report back if this works, and how well it does if it does. Have a bunch of re-ripped mkvs from my backups (thank you foresight) ready for remuxing.
userr
Post by userr » Thu Jul 02, 2020 3:44 pm
Liersi wrote: Thu Jul 02, 2020 3:13 pm
are you saying youre playing profile 4 (04.06) mp4 in MrMc on 2019 shield?
Post by shawnc22 » Thu Jul 02, 2020 4:09 pm
I'm guessing you've been following the steps from here?
https://www.avforums.com/threads/dolby- ... s.2254350/
If so, it's probably not the file that's the issue. Nevermind that profile 8 is wrong for these kind of files, it's not going to matter much on the Shield. It's surprising though that you've been having issues with Plex. Have you been turning off PGS subtitles? If you're worried about your remux process, give these sample files a try:
https://mega.nz/file/YSxhkSLK#fkfy54tYV ... xIOBZLyGR4 (MEL)
https://mega.nz/file/MHpBBLjK#4bM5jsNgP ... glhYbzLcQ0 (FEL)
Liersi
Post by Liersi » Thu Jul 02, 2020 6:47 pm
shawnc22 wrote: Thu Jul 02, 2020 4:09 pm I'm guessing you've been following the steps from here?
Thank you Shawn. I hadn't seen that thread on avforums. A helpful HDfury rep on AVSforum spotted my problem like a hawk and solved it. The thread you linked to would have solved it as well. You need to force an HDR frame in another tab to make it work. Somehow overlooked that in the instructions I followed. Thanks again for following up on this, that's very gracious of you.
EDIT: by the way, you were also right about Plex. MrMC started crashing, and with this latest fix, Plex is working swimmingly. Cheers for that, too.
BringerChaos
Post by BringerChaos » Fri Jul 03, 2020 2:13 pm
Is it possible to re encode the BL.hevc and use that along with the EL.hevc to make a smaller sized Dolby Vision capable file?
Post by MartyMcNuts » Sat Jul 04, 2020 12:14 am
BringerChaos wrote: Fri Jul 03, 2020 2:13 pm Is it possible to re encode the BL.hevc and use that along with the EL.hevc to make a smaller sized Dolby Vision capable file?
Yes, check my posts in this very thread. (page #170)
userr
Post by userr » Sat Jul 04, 2020 3:31 am
Cant delete post so i just edit it and remove it, cause question has been answered
