Using my Vertex 2, I don't see the issue either when I force LLDV.RESET_9999 wrote: ↑Mon Jun 29, 2020 4:47 pmThat's probably because you are getting LLDV (12bit 422 DV).Darthjipsu wrote: ↑Mon Jun 29, 2020 3:28 pmHello guys.
I'm reading this topic for a while, but never posted before.
I'm sorry if my english is not perfect, it's not my native tongue.
I read about color issues with Nvidia Shield pro and Dolby Vision.
I just received my new TV with DV support (Philips OLED934) so I decided to conduct some test with DV.
So here are my results :
Philips O934 vs Nvidia Shield Pro : https://slow.pics/c/NVssdh3m (12 Pictures)
Xbox One X vs Nvidia Shield Pro : https://slow.pics/c/UcMwDqeF (13 Pictures)
I'm not a professional but I don't see much difference between Shield and TV or Xbox, even in Magenta/Red colors that seems to be problematic.
Feel free to discuss about it, and ask me some questions
the color issue is with the 8bit RGB DV signal.
I have a friend with a Vertex that can force LLDV and he confirmed that he's not seeing the issue when forcing LLDV.
Dolby Vision and 1.15.1
Re: Dolby Vision and 1.15.1
I wish my first-gen Vertex could do that.
![Sad :(](./images/smilies/icon_sad.gif)
Hi guys,
So I'm trying to get Dolby Vision work with ATV4K via my router. As I understand, you need one layer with profile 5 DV for it to be picked up by ATV4K. So I made a DV mkv and then I tried both tSMuxers to create .ts, but still Infuse doesn't see the DV, only HDR. Which makes me think both of the tSMuxers (nightly and the earlier one, edited) somehow do not create profile 5, right? So is there a way to make DV profile 5 using this method, or profile 5 can only be created in mp4? Many thanks!
You can't with the DV mkv. You'd need to use yusecope's tool in mode 2 to discard the EL and then mux it with an edited tsmuxer to get profile 5.Alldu wrote: ↑Wed Jul 01, 2020 6:48 pmHi guys,
I see. Would you be so kind to point me the direction where I can get that tool?shawnc22 wrote: ↑Wed Jul 01, 2020 9:24 pmYou can't with the DV mkv. You'd need to use yusecope's tool in mode 2 to discard the EL and then mux it with an edited tsmuxer to get profile 5.Alldu wrote: ↑Wed Jul 01, 2020 6:48 pmHi guys,
viewtopic.php?p=85413#p85413Alldu wrote: ↑Wed Jul 01, 2020 9:31 pmI see. Would you be so kind to point me the direction where I can get that tool?shawnc22 wrote: ↑Wed Jul 01, 2020 9:24 pmYou can't with the DV mkv. You'd need to use yusecope's tool in mode 2 to discard the EL and then mux it with an edited tsmuxer to get profile 5.Alldu wrote: ↑Wed Jul 01, 2020 6:48 pmHi guys,
So I tried ChrisAndy's method and I don't think I am getting DV. My setup...Grencola wrote: ↑Sun May 31, 2020 8:24 pmYep.Yep. But once the standard is finalized Plex should (hopefully) be one of the first to update their player, in which case you would just do a) then d) but it will be an mkv as ts will no longer be needed.chrisandy wrote: ↑Sun May 31, 2020 6:29 pmJust want to make sure I accurately summarize..
In order to get both Dolby Vision and Atmos via Plex you need
1)Nvidia Shield
2) The file:
a) MakeMKV of the BDMV
b) Extract Atmos audio via ea3to
c) Combine .mkv and extracted audio via TSmuxer to create a .ts
d) Use Plex via Shield to play .ts which will have both Dolby Vision + Atmos
Is this correct?Yep. LG can't passthrough lossless thd-atmos. An x700 or ATV 4K can work though. And probably the Ugoos AM6 Plus, too.
Sony X950H
Nvidia Shield Pro 2019
Plex server from a QNAP TS-451Be
My steps...
1. Re-ripped John Wick 3 using Makemkv 1.15.1 to an MKV
2. Used Makemkv to create an unprotected copy of the disk onto a harddrive
3. Using tsmuxer 2.6.12...
a. Dragged the JW3 MKV file to the txmuxer input section
b. Dragged the 00800.mpls file from the copy of the Bluray to the txmuxer input section
c. Selected the HEVC movie from the MKV and selected the TRUE-HD track from the 00800.mlps file and ran txmuxer, which spit out a JW3,ts file.
d. copied it to my Plex library and update the library on the Plex server
At this point I ran Plex on the Nvidia Shield and made sure to specifically select the .ts version. When I play it, I do get Dolby Atmos, HOWEVER my Sony TV shows no hint that it is playing a Dolby Vision movie as it did not switch to Dolby Vision Light like it does for streaming content. Should I expect my Sony TV to switch to a DV profile or is this something that is lost via the muxing?
As a note, I did not change any setting in txmuxer.
Thanks.
Sorry, misread your original message.Chuck_IV wrote: ↑Thu Jul 02, 2020 5:57 amSo I tried ChrisAndy's method and I don't think I am getting DV. My setup...Grencola wrote: ↑Sun May 31, 2020 8:24 pmYep.Yep. But once the standard is finalized Plex should (hopefully) be one of the first to update their player, in which case you would just do a) then d) but it will be an mkv as ts will no longer be needed.chrisandy wrote: ↑Sun May 31, 2020 6:29 pmJust want to make sure I accurately summarize..
1)Nvidia Shield
2) The file:
Sony X950H
My steps...
Thanks.
Can you share the Mediainfo of the .ts file you created?
A screenshot of TSMuxer (before you mux) would help too.
I was just looking at the mediainfo of the MKV I ripped a couple days ago and I think this is the issue. for HDR format, I see "SMPTE ST 2086, HDR10 compatible". There is no mention of Dolby Vision.chrisandy wrote: ↑Thu Jul 02, 2020 6:08 amI think your approach is a little redundant. I can't speak to steps 1 and 2, but once you have a .mkv you can use eac3to to extract the Atmos file then you would throw in the .mkv and the thd+ac3 (atmos) file into TSMuxer. This should produce a .ts with DV.Chuck_IV wrote: ↑Thu Jul 02, 2020 5:57 amSo I tried ChrisAndy's method and I don't think I am getting DV. My setup...Grencola wrote: ↑Sun May 31, 2020 8:24 pm
Yep.
Sony X950H
My steps...
Thanks.
Is there something I am missing in MakeMKV that isn't retaining the DV part(I am on 1.15.1)? Here are my two mediainfos...
MKV ripped via MakeMKV 1.15.1(only included video portion to keep it small)...
General
Unique ID : 291245564851937371381727990531637701164 (0xDB1BDAFEE42A1A0F08758ABA50D0EA2C)
Complete name : P:\Movies\JOHN.WICK.3.PARABELLUM.4K.mkv
Format : Matroska
Format version : Version 2
File size : 68.9 GiB
Duration : 2 h 10 min
Overall bit rate mode : Variable
Overall bit rate : 75.4 Mb/s
Movie name : John Wick 3: Parabellum
Encoded date : UTC 2020-06-29 02:48:11
Writing application : MakeMKV v1.15.1 win(x64-release)
Writing library : libmakemkv v1.15.1 (1.3.5/1.4.7) win(x64-release)
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 70.8 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.356
Stream size : 64.7 GiB (94%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 358 cd/m2
Original source medium : Blu-ray
General
Complete name : P:\Movies\JOHN.WICK.3.PARABELLUM.DV.ts
Format : MPEG-TS
File size : 72.1 GiB
Overall bit rate : 79.0 Mb/s
Maximum Overall bit rate : 35.5 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 6
Bit rate : 73.8 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.371
Stream size : 67.4 GiB (93%)
Language : English
I would try creating an MKV from the .index file of the BDMV folder (or you can use the .mpls file I guess).Chuck_IV wrote: ↑Thu Jul 02, 2020 6:25 amI was just looking at the mediainfo of the MKV I ripped a couple days ago and I think this is the issue. for HDR format, I see "SMPTE ST 2086, HDR10 compatible". There is no mention of Dolby Vision.chrisandy wrote: ↑Thu Jul 02, 2020 6:08 amI think your approach is a little redundant. I can't speak to steps 1 and 2, but once you have a .mkv you can use eac3to to extract the Atmos file then you would throw in the .mkv and the thd+ac3 (atmos) file into TSMuxer. This should produce a .ts with DV.Chuck_IV wrote: ↑Thu Jul 02, 2020 5:57 am
Sony X950H
My steps...
Thanks.
MKV ripped via MakeMKV 1.15.1(only included video portion to keep it small)...Resulting MUXED file...Code: Select all
General Unique ID : 291245564851937371381727990531637701164 (0xDB1BDAFEE42A1A0F08758ABA50D0EA2C) Complete name : P:\Movies\JOHN.WICK.3.PARABELLUM.4K.mkv Format : Matroska Format version : Version 2 File size : 68.9 GiB Duration : 2 h 10 min Overall bit rate mode : Variable Overall bit rate : 75.4 Mb/s Movie name : John Wick 3: Parabellum Encoded date : UTC 2020-06-29 02:48:11 Writing application : MakeMKV v1.15.1 win(x64-release) Writing library : libmakemkv v1.15.1 (1.3.5/1.4.7) win(x64-release) Video ID : 1 ID in the original source medium : 4113 (0x1011) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 10 min Bit rate : 70.8 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.356 Stream size : 64.7 GiB (94%) Language : English Default : No Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 1000 cd/m2 Maximum Frame-Average Light Level : 358 cd/m2 Original source medium : Blu-ray
General ID : 1 (0x1) Complete name : P:\Movies\JOHN.WICK.3.PARABELLUM.DV.ts Format : MPEG-TS File size : 72.1 GiB Duration : 2 h 10 min Overall bit rate mode : Variable Overall bit rate : 79.0 Mb/s Maximum Overall bit rate : 35.5 Mb/s Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : 6 Duration : 2 h 10 min Bit rate : 73.8 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.371 Stream size : 67.4 GiB (93%) Language : English Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 1000 cd/m2 Maximum Frame-Average Light Level : 358 cd/m2
Once you have that, you can use eac3to to extract the Atmos audio, then throw the thd+ac3 (Atmos file) and the MKV into TSMuxer, then mux.
Check this out:
For those that are looking to make this work in the easiest way possible:
1) Rip to MKV with MakeMKV
4) Remux to TS
That's kinda what I did(in a convoluted way). The Atmos worked the way I did it but I am concerned about the mediainfo of the rip. I just created a new MKV from the Makemkv copy I made earlier and the mediainfo shows the same as my MKV from a few days ago. I still don't see any mention of Dolby Vision. The Blyray box says it has Dolby Vision...chrisandy wrote: ↑Thu Jul 02, 2020 6:28 amI would try creating an MKV from the .index file of the BDMV folder (or you can use the .mpls file I guess).Chuck_IV wrote: ↑Thu Jul 02, 2020 6:25 amI was just looking at the mediainfo of the MKV I ripped a couple days ago and I think this is the issue. for HDR format, I see "SMPTE ST 2086, HDR10 compatible". There is no mention of Dolby Vision.chrisandy wrote: ↑Thu Jul 02, 2020 6:08 am
Check this out:
4) Remux to TS
Video
Format : HEVC
Color space : YUV
Bit depth : 10 bits
Language : English
Default : No
Forced : No
When you throw the MKV into TSMuxer, do you get two video files?Chuck_IV wrote: ↑Thu Jul 02, 2020 6:44 amThat's kinda what I did(in a convoluted way). The Atmos worked the way I did it but I am concerned about the mediainfo of the rip. I just created a new MKV from the Makemkv copy I made earlier and the mediainfo shows the same as my MKV from a few days ago. I still don't see any mention of Dolby Vision. The Blyray box says it has Dolby Vision...chrisandy wrote: ↑Thu Jul 02, 2020 6:28 amI would try creating an MKV from the .index file of the BDMV folder (or you can use the .mpls file I guess).Chuck_IV wrote: ↑Thu Jul 02, 2020 6:25 am
Check this out:
4) Remux to TSCode: Select all
No, I only see one.
**EDIT**
So when I create an MKV, I only select the main movie and audio tracks needed. Is there another track I need to include when creating the MKV?
When I drag the MKV over, I get a message that a track isn't compatible. I was assuming that was the Atmos audio but now I'm not so sure.
When I drag the m2ts file from the copy, into txmuxer, i DO get two video files. Maybe I should try that.
No you were doing it right the first time. Mediainfo will not show DV info on the mkv, just the TS. You're using the wrong version of tsmuxer. Look for the one labeled 04.06 fix that most people have been using around here.Chuck_IV wrote: ↑Thu Jul 02, 2020 6:52 amNo, I only see one.
**EDIT**
Thanks Shawn! How exactly you can run it in mode 2?shawnc22 wrote: ↑Wed Jul 01, 2020 11:18 pmviewtopic.php?p=85413#p85413
EDIT: Ok, found it!
![Smile :)](./images/smilies/icon_smile.gif)
