March of the Penguins DVD
tonytx05
Post by tonytx05 »
I can't get this disc to decrypt. I get kicked back to the main screen and MakeMKV acts like it doesn't see a disc in the drive. I have to go to Finder in MacOS to eject the drive at this point.
MakeMKV v1.15.1 darwin(x64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE BP60NB10 1.01d" opened in OS access mode.
Downloading latest SDF to /Users/anthony/Library/MakeMKV ...
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.01' at offset '1048576'
Using LibreDrive mode (v06.2 id=896BE8641F13)
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '38912'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '40960'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '43008'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '45056'
Title #1 was added (19 cell(s), 1:20:00)
Title #2 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 was added (1 cell(s), 0:23:30)
Title #7 was added (1 cell(s), 0:07:07)
Title #9 has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 was added (4 cell(s), 0:02:47)
Subtitle stream #3 is identical to stream #2 and was skipped
Subtitle stream #4 is identical to stream #2 and was skipped
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while issuing SCSI command A40..0087A470..00CC4 to device 'IoKit:IOBDServices:b110d9de7a8c7699:HL-DT-ST BD-RE BP60NB10 1.01'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..03F to device 'IoKit:IOBDServices:b110d9de7a8c7699:HL-DT-ST BD-RE BP60NB10 1.01'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..03F to device 'IoKit:IOBDServices:b110d9de7a8c7699:HL-DT-ST BD-RE BP60NB10 1.01'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..07F to device 'IoKit:IOBDServices:b110d9de7a8c7699:HL-DT-ST BD-RE BP60NB10 1.01'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..07F to device 'IoKit:IOBDServices:b110d9de7a8c7699:HL-DT-ST BD-RE BP60NB10 1.01'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0BF to device 'IoKit:IOBDServices:b110d9de7a8c7699:HL-DT-ST BD-RE BP60NB10 1.01'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0BF to device 'IoKit:IOBDServices:b110d9de7a8c7699:HL-DT-ST BD-RE BP60NB10 1.01'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0FF to device 'IoKit:IOBDServices:b110d9de7a8c7699:HL-DT-ST BD-RE BP60NB10 1.01'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0FF to device 'IoKit:IOBDServices:b110d9de7a8c7699:HL-DT-ST BD-RE BP60NB10 1.01'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..00800 to device 'IoKit:IOBDServices:b110d9de7a8c7699:HL-DT-ST BD-RE BP60NB10 1.01'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '6144'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_04_1.VOB' at offset '0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '0'
Re: March of the Penguins DVD
First step is cleaning the disk; hardware time-outs on modern drives often happens because the drive is trying REALLY HARD to read a sector, and the operating system thinks it has gone off-line. Too many, and the operating system can decide there is no disk present.
tonytx05
Post by tonytx05 »
Cleaning the disc didn't make a difference. It was already pretty clean to begin with. Note in the log it gets through the timeout errors and starts detecting titles. Then it shows MEDIUM ERROR:NO SEEK COMPLETE and everything snowballs from there.
