Mentions of 'patched firmware'? Suffice to say I did a little bit of digging, 'LibreDrive firmware', 'MK firmware', 'firmware rollback/downgrade', but I really have no idea where to start or what I should do, so if the users here could push me in the right direction I would appreciate that.Drive Information
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KLGK2KJ2756
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 3.10
'UHD Friendly' BDW (Asus BW-16D1HT) not Detecting UHD Discs
HappyMaskedMan
Hey all, at the recommendation of YouTuber EposVox I purchased an Asus BW-16D1HT, supposedly the most reliably UHD friendly Blu-ray drive. Using MakeMKV on Ubuntu 20.04 however, neither will detect any UHD/4K Blu-ray disc inserted.
Last edited by HappyMaskedMan on Thu Jul 02, 2020 5:07 am, edited 1 time in total.
Re: 'UHD Friendly' BDW (Asus BW-16D1HT) not Detecting UHD Discs
A very good place to start... 1st post has links to everything you need, including videos.
Ultimate UHD Drives Guide Updated 2020
But I notice you are running Linux & most flashtools are Windows-based, so these may be of interest:
Linux native flashing
Linux How To: Flash ASUS-BW-16D1HT
HappyMaskedMan
There are still so many options, I have no idea which would be best for me. I just want to restore the UHD friendliness of my BW-16D1HT while sacrificing as little as possible. What's the best/most recommended method to go about doing that?d00zah wrote: Wed Jul 01, 2020 6:34 pm A very good place to start... 1st post has links to everything you need, including videos.
I would think this covers your case (almost) exactly... you have a later version of Ubuntu.
It includes an indirect link to the latest MK FW archive, which contains 'ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin', a patched MK version of your drives current FW. Your MakeMKV install provides everything else you need.
Instructions seem clear, but if you can't make it work, or are hesitant, you should probably contact one the the vendors listed here who might be willing to perform a remote flash?
HappyMaskedMan
Worked like a charm! However, I think I have the 'sleep bug'; it only occurs when streaming a 4K UHD Blu-ray via MakeMKV VLC & pausing/resuming, but it is an issue albeit a minor one. Also, most of my 4K UHD Blu-ray discs induce MakeMKV to output this:d00zah wrote: Thu Jul 02, 2020 1:56 pm I would think this covers your case (almost) exactly... you have a later version of Ubuntu.
Failed to open disc-
UHD FAQHappyMaskedMan wrote: Sat Jul 04, 2020 5:54 pm Also, most of my 4K UHD Blu-ray discs induce MakeMKV to output this:
The volume key is unknown for this disc - video can't be decrypted Failed to open disc
Refer to the 'Hashed Keys - How do I discover the key for a disc I have?' section.
Disregard any references to manually downloading a 'hashed keys' file, et al. MakeMKV automatically downloads periodic updates, including keys. if 'Allow contacting web server for updates' is checked on the 'General' prefs tab.
