box4m
Post by box4m »
Grencola wrote: Fri May 15, 2020 3:27 am
kazuma wrote: Thu May 14, 2020 9:21 pm
thetoad wrote: Thu May 14, 2020 6:52 pm I use my m9702 daily, with that said, it is far from perfect. If KODI or Plex could ever play dolby vision bluray rips to my TV we;;, life will be much better. with that said, we are far from that day.
never gonna happen..
It's already happened :P the Ugoos AM6 Plus plays profile 7 dv rips in kodi 18.6 (seek to 5:15ish): https://drive.google.com/file/d/1cpBJSM ... Wt_2A/view I've also heard from people who have successfully played DV profile 5 rips in kodi 19 on their shield. both devices are quickly shaping up to be m9702 killers..
have you read anything more about kodi and different DV profiles? where did u read about this? is it only profile 5? :) thx
planet_hoarder wrote: Fri Jun 26, 2020 12:33 pm how did you create dual layer profile 7 with atmos?
Latest tsMuxer but that method only works on the x700 and the oppo.
Post by shawnc22 »
box4m wrote: Fri Jun 26, 2020 11:11 am Gemini Man on the shield stutters with DV, but smooth with HDR10, am i correct when i say 59.94fps + DV is beyond HDMI2.0b standard?
My DV rip of Gemini Man have no playback issues on the Shield, and I'm pretty sure several others have reported no issues as well previously.
box4m
Post by box4m »
what will i get if i run mp4muxer and create a profile 5 mp4 with BL+EL+RPU from yuse tool?
It plays fine but what am i seeing :P? BL+RPU cause its profile 5?
the filesize and bitrate is more with BL+EL+RPU even though its profile 5 so i guess placebo can make it look better :p
besson
Post by besson »
Hey,
Looking for a little help here, I went back many pages, and I am not sure how to do this process in it's completion.
I tried FFMPEG and got nothing but errors
I just got a new system capable of atmos, and really want to be able to do this. I have tried the disc and the blu ray folder, but nothing works.
I know there is a lot of help here and I mostly followed
viewtopic.php?t=18602&start=1650
planet_hoarder
Post by planet_hoarder »
box4m wrote: Fri Jun 26, 2020 4:12 pm what will i get if i run mp4muxer and create a profile 5 mp4 with BL+EL+RPU from yuse tool?
it depends, if EL really makes picture 12bit, than it's useless everywhere, since there are no consumer 12bit panels.
Then all profiles are the same, since they show BL+RPU
there is no benefit of using yusecope's tool, if you are creating DV file with mp4muxer.
planet_hoarder
besson wrote: Mon Jun 29, 2020 5:53 am Hey,
can you be more specific? "atmos capable" usually mean can playback atmos object data, but for real atmos effect you need height speakers.
what did you do exactly? which tools?
where did you try to playback? how everything is connected?
Post by shawnc22 »
planet_hoarder wrote: Mon Jun 29, 2020 2:32 pm
It's true that a FEL makes the picture 12 bit, and there are no consumer displays capable of more than 10bit, but saying it is useless and that all profiles are essentially just BL+RPU is just not correct. Please give this a good read:
https://forum.blu-ray.com/showpost.php? ... tcount=119
Liersi
Post by Liersi »
Hey guys, first time in this thread. I've been reading back for a while, also started in from the beginning, and it's a lot of shifting info due to all the players and sinks people are using. The following question is not out of laziness but genuine confusion about all the possibilities you are discussing.
My scenario is playback via new Shield TV 2019 to a non-DV sink via a HDfury Vertex2, which allows the use of LLDV through emulation of compatible device EDID. So Shield, LLDV via Vertex2 device emulation, display. Assuming I want to retain everything I can, including HD audio (even Atmos etc.), which of these profiles and demuxing/splitting/remuxing processes would produce working files?
Thank you for any advice that helps me learn this stuff better. It's daunting sometimes!
besson
Post by besson »
planet_hoarder wrote: Mon Jun 29, 2020 2:35 pm
Sorry the steps were not very clear that I was following, so what I was trying wasn't working.
So setup is:
Sony soundbar with rear speakers with vertical engine to simulate the atmos effect connected via e-arc to my vizio tv with e-arc. Using a apple tv 4k, but willing to get anything that displays that it is playing atmos.
Like I said steps weren't super clear, but I got stopped dead in my tracks at the FFMPEG part with ffmpeg -i bluray:\path\to\bluray_disc -map 0:0 -c copy \path\to\BL.hevc -map 0:1 -c copy \path\to\EL.hevc
My command was directly to my drive, which said it was encrypted. I then pointed it to the decrypted blu ray folder, no luck.
If someone can help me step by step here and get the proper end file with my atmos track that will actually play and show atmos I'm willing to pay. I have been dumping money into this and I just want the atmos track and my 4kuhd track.
Not sure if any of this helps, but i am building a full on htpc as well, but can get a shield in the meantime if necessary. Apologies if im sounding like a bumbling idiot I have been having a rough time with this process.
Thank You
Post by shawnc22 »
Liersi wrote: Mon Jun 29, 2020 3:54 pm Hey guys, first time in this thread. I've been reading back for a while, also started in from the beginning, and it's a lot of shifting info due to all the players and sinks people are using. The following question is not out of laziness but genuine confusion about all the possibilities you are discussing.
Needing to send a LLDV signal won't affect the kind of file you have to create. If you don't want to wait for the new DV-compatible mkv containers, the easiest way right now is to go from disk -> mkv with makemkv 1.15.1. If atmos audio is present, extract it with eac3to to thd+ac3 format. Then add mkv and extracted track into either latest nightly build of tsmuxer or the 04.06 fix version that most have been using around here and mux.
Liersi
Post by Liersi »
shawnc22 wrote: Mon Jun 29, 2020 4:10 pm Needing to send a LLDV signal won't affect the kind of file you have to create. If you don't want to wait for the new DV-compatible mkv containers, the easiest way right now is to go from disk -> mkv with makemkv 1.15.1. If atmos audio is present, extract it with eac3to to thd+ac3 format. Then add mkv and extracted track into either latest nightly build of tsmuxer or the 04.06 fix version that most have been using around here and mux.
See, I wouldn't even have known if LLDV made a difference for this. I'll try it the way you describe next chance I get and report back. Thank you very much for helping me out.
Post by shawnc22 »
besson wrote: Mon Jun 29, 2020 4:07 pm Sorry the steps were not very clear that I was following, so what I was trying wasn't working.
So setup is:
Thank You
There's a lot going on here, but the main problem here is that you don't have a device capable of playing back lossless truehd atmos. e-ARC is capable of passing a truehd atmos signal, but I doubt the vizio is capable of decoding it in the first place. The Apple TV is also not capable; the best it will do is convert it to LPCM using infuse. I'm not sure about the capabilities of a htpc, but the Shield will solve this issue. Once you get this issue solved and if you don't care about dolby vision, then just go from disk to mkv with the latest version of makemkv and call it a day.
box4m
Post by box4m »
how else do i merge BL+EL? if i use mp4muxer and have BL + EL as inputs, it creates a duallayer no?
Post by shawnc22 »
box4m wrote: Mon Jun 29, 2020 5:09 pm
No methods exist to merge the layers themselves. You can merge the tracks that carry them (dual track -> single track), but not the layers.
