Close Encounters of the Third Kind
ricardo436
#1 Post by ricardo436 » Sun Jun 28, 2020 1:41 pm
I want to backup this title, Close Encounters of the Third Kind, but I have noticed that there are 6 files of the movie.
Would anyone know to which title/file is the correct one to do??? But I would like to know are any of them the extended version?
Re: Close Encounters of the Third Kind
#2 Post by Woodstock » Sun Jun 28, 2020 1:46 pm
If you're doing a backup, it doesn't matter - the backup copies ALL the files, and the menu structure handles getting you the correct ones during playback.
Or are you using Open, and creating MKV files?
jayper
#3 Post by jayper » Sun Jun 28, 2020 4:16 pm
The disc includes three versions of the film:
- Theatrical Version
- Special Edition
- Director's Cut
Each of the three versions can be viewed in a mode called "View From Above." This mode will show small icons on screen to help highlight the differences between each cut of the film. This results in 6 different titles being shown by MakeMKV.
You'll need to determine which version of the film you want and select accordingly. It's been way too long since I backed this one up and the disc is not easily accessible at the moment, so I can't check for you.
According to Wikipedia, the running times are as follows:
- 135 minutes (Theatrical Version)
- 132 minutes (Special Edition)
- 137 minutes (Director's Cut)
Hope that helps and is enough to get your on your way.
ricardo436
#4 Post by ricardo436 » Mon Jun 29, 2020 1:59 pm
It does matter, because it'll take up a lot more space backing up all. As I said. I'm only interested in the extended version.
ricardo436
#5 Post by ricardo436 » Mon Jun 29, 2020 2:03 pm
- Special Edition
- Director's Cut
Thanks, but I can access the disc with no problems. Only Midway it the hardest to do.
