0 Titles saved, 1 failed
Cooly
Post by Cooly »
I have successfully ripped 2 discs to my hard drive. The 3rd I used DvdFab to shrink "Predators" and make a backup of my movie. I then tried to make a MKV copy of the shrunk BluRay, 22.5G. Thinking I could save a little smaller copy to my hard drive. It appears to rip the entire copy to my hard drive, as I can watch to destination folder and see the file grow. Upon completion it disappears and MakeMKV displays: 0 titles saved, 1 failed. Hear is a copy of the log file.
Debug log started at Sun Nov 28 19:50:42 2010 , written by MakeMKV v1.6.2 win(x64-release)
001005:0000 MakeMKV v1.6.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Cooly/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at :e4{WP42AE'=sH_(z:121262164
003305:0000 AACS directory not present, assuming unencrypted disc
005053:0308 This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
003307:0000 File 00000.mpls was added as title #0
005014:0000 Saving 1 titles into directory E:/BluRay Movies/Predators
001003:0020 DEBUG: Code 7 at y#>Yi%z%z~MEKjBQ1lk^:121264050
001003:0020 DEBUG: Code 0 at se#Wjk$|<_4^GI!MuC-~~:29397449
001003:0020 DEBUG: Code 0 at 4,O:||lWA!BpRtH9bS\:121263751
FS ID=V_MPEG4/ISO/AVC C=0
TI=ZeNpjZICCHbYOjAyYwGFPnRKItmIgHTSwMzBYsCDoA7EMDC+ZGRiYINICIPsAkJUGsA==
005003:0000 Failed to save title 0 to file E:/BluRay Movies/Predators/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sun Nov 28 20:25:53 2010
I've tried this 4 times, rebooted my pc once, and no change in the outcome. the first 2 movies I copied, copied fine and playback with VLC Player works great. My shrunk copy of Predators plays fine on my PC and on my home theater system.
This software appears to have great potential. Any ideas whats wrong?
Thanks, Cooly
Cooly
setarip_old
Re: 0 Titles saved, 1 failed
Post by setarip_old »
Hi!
I and others have previously noted that pre-processing/compressing Blu-ray discs with DVDFab, BD-Rebuilder, multiAVCHD, or similar modifies the files in such a way that, presently, MakeMKV cannot properly process them. If I remember correctly, this was acknowledged earlier by "mike admin", who also stated that it would be addressed in the near future...
Post by mike admin »
Yes, this will be corrected in a next version.
