From the Earth to the Moon DVD
Stryker412
#1 Post by Stryker412 » Fri Jun 26, 2020 1:40 pm
Am I correct in assuming they combined 2 episodes into one m2ts file? I'm only showing 2 files but at 2hrs each.
Re: From the Earth to the Moon DVD
#2 Post by Woodstock » Fri Jun 26, 2020 4:47 pm
Are you typing about a DVD or a BD? m2ts files are from Bluray. DVDs use VOBs.
Stryker412
#3 Post by Stryker412 » Fri Jun 26, 2020 9:57 pm
Sorry yes I mean vob. I'm in BD mode most of the time.
Grauhaar
#4 Post by Grauhaar » Sat Jun 27, 2020 6:29 am
This documentaion is very old and long time available on DVD. On my server are 12 single episodes ripped from the DVDs years ago. Try it with "File-> Open DVD files manually", maybe it helps.
Good Luck :)
Stryker412
#5 Post by Stryker412 » Sat Jun 27, 2020 5:09 pm
I don't see any options like that in MakeMKV.
Grauhaar
#6 Post by Grauhaar » Sat Jun 27, 2020 5:10 pm
Recheck my posting
Good Luck :)
