New LG drive (WH14NS40)
ruff.hi
#1 Post by ruff.hi » Fri Jun 26, 2020 11:26 pm
I just picked up a new LG drive (WH14NS40) after my old one died.
Details from MakeMKV are ...
[b]Drive Information[/b]
Current profile: DVD-ROM
Product: BD-RE WH14NS40
Revision: 1.04
Serial number: KLOK???????
Firmware date: 2119-01-04 13:51
Highest AACS version: 70
[b]LibreDrive Information[/b]
Harware support: Yes
Firmware support: No
Firmware version: 1.04
Can I flash this to enable LibreDrive?
Re: New LG drive (WH14NS40)
#2 Post by Billycar11 » Sat Jun 27, 2020 2:17 am
ruff.hi
#3 Post by ruff.hi » Sat Jun 27, 2020 3:55 am
Thx Billycar11 ... I have been doing some reading, including most of the posts linked in the one you shared.
Here is where I currently stand ...
  • I have downloaded the mk-firmware-pack-20200415.zip file
  • and unzipped it
  • there are 2 files that match my drive
    • HL-DT-ST-BD-RE_WH14NS40-NS50-1.03-NM00600-211711211658.bin in the MK/OLD directory
    • HL-DT-ST-BD-RE_WH14NS40-NS50-1.04-NM01201-211901041351.bin in the active(?) directory
    • flash_HL-DT-ST_BD-RE_WH14NS40_1.00_NS50.bin
    • flash_HL-DT-ST_BD-RE_WH14NS40_1.02_NS50.bin
  • does my drive qualify (using your 'important before you flash' list)
    1. Make sure your Drive was built after 2015 - yes. March 2020
    2. Drive Platform MT1959<Most important - yes, see above
    3. SVC NS50+ LG only - yes. Little SVC CODE: NS50 on the s/n sticker
    4. Just because your drive is the same model number does not mean it will work, if you are unsure ask me i offer remote flashing and check everything before i flash. - um, ok
What is not done is ... My drive has stock 1.04 revision on it. My understanding is that if I flash this to the 1.04 bin file above, then this will unlock LibreDrive ... is this right?
Final question: do I really want to do this? I have installed the drive and ripped a couple of DVDs and a Blu-Ray. Then run the resulting MKV file through HandBrake and output mp4 files. They are currently sitting on my FreeNAS server and PLEX is managing them. We watched Passengers tonight.
What will unlocking LibreDrive (if that is all it does) do for me that I don't currently have?
Edit: Just downloaded the flasher ... and it came with two other options for bin files (added above).
ruff.hi
#4 Post by ruff.hi » Sun Jun 28, 2020 3:20 am
So ... I ended up flashing my new drive using the HL-DT-ST-BD-RE_WH14NS40-NS50-1.04-NM01201-211901041351.bin file.
Results ...
OS device name: E:
Revision: 1.04
I then ripped a blu-ray and a DVD. Speed looked to be a little better but the one big thing I noticed was that the DVD rip was dead silent.
TeddyRaspin
#5 Post by TeddyRaspin » Sun Jun 28, 2020 11:52 am
@ruff.hi
Where did you buy the WH14NS40 ?
ruff.hi
#6 Post by ruff.hi » Sun Jun 28, 2020 10:23 pm
S.p.e.c.t.r.e.
#7 Post by S.p.e.c.t.r.e. » Sun Jun 28, 2020 11:56 pm
ruff.hi wrote: Sun Jun 28, 2020 3:20 am So ... I ended up flashing my new drive using the HL-DT-ST-BD-RE_WH14NS40-NS50-1.04-NM01201-211901041351.bin file.
Results ...
OS device name: E:
Revision: 1.04
I wonder what that KLOK means.
S.p.e.c.t.r.e.
#8 Post by S.p.e.c.t.r.e. » Sun Jun 28, 2020 11:59 pm
ruff.hi wrote: Sat Jun 27, 2020 3:55 am
I thought we were suppose to use makemkv command line mode to upgrade the firmware. Am I wrong on this? I have the WH16NS40...
#9 Post by SamuriHL » Mon Jun 29, 2020 12:04 am
It's not required and its not super user friendly. If the Windows UI's work, it's certainly easier to flash with them.
jextrevor
#10 Post by jextrevor » Mon Jul 06, 2020 8:05 pm
I'm curious if your drive works with UHD discs with that firmware. I've got a WH14NS40 and downgraded it to 1.02 firmware to enable reading UHD discs. However, seeing the "unrestricted read speed: enabled" makes me want to try out whatever firmware you are using.
Also - even though my drive says "DVD all regions", I've had consistent problems with it reading some DVDs. These DVDs are read fine by my DVD drive, an HP DVD Writer 1270t.
My drive details as reported by MakeMKV:
OS device name: /dev/sr0
Revision: 1.02
Serial number: KLOK35J0001
Firmware date: 2115-12-11 15:03
Highest AACS version: 72
Firmware version: 1.02
#11 Post by Coopervid » Tue Jul 07, 2020 8:16 pm
For unrestricted read speed read this:
viewtopic.php?f=19&t=22221
jextrevor
#12 Post by jextrevor » Tue Jul 07, 2020 8:22 pm
Coopervid wrote: Tue Jul 07, 2020 8:16 pm For unrestricted read speed read this:
I see some items in the list of firmware similar to my drive name, but none matching 1.02 and my specific firmware date. Do you know how to flash a UHD-friendly firmware that would be in that list?
S.p.e.c.t.r.e.
#13 Post by S.p.e.c.t.r.e. » Tue Aug 04, 2020 2:14 am
I have not flashed my WH16ns40 drive yet nor do I have any UHD disks to test either.
My drive works fine with DVD's in oem firmware but it very noisy with the head going back and forth and it first reads a dvd. My really old 10 year old bray burner didn't make as much noise.
It does read some bray at 7.6x
