From the Earth to the Moon DVD
Stryker412
Am I correct in assuming they combined 2 episodes into one m2ts file? I'm only showing 2 files but at 2hrs each.
Re: From the Earth to the Moon DVD
Are you typing about a DVD or a BD? m2ts files are from Bluray. DVDs use VOBs.
Stryker412
Sorry yes I mean vob. I'm in BD mode most of the time.
Grauhaar
This documentaion is very old and long time available on DVD. On my server are 12 single episodes ripped from the DVDs years ago. Try it with "File-> Open DVD files manually", maybe it helps.
Good Luck
Stryker412
I don't see any options like that in MakeMKV.
Grauhaar
Recheck my posting
Good Luck
