From the Earth to the Moon DVD
Stryker412
Post by Stryker412 »
Am I correct in assuming they combined 2 episodes into one m2ts file? I'm only showing 2 files but at 2hrs each.
Re: From the Earth to the Moon DVD
Are you typing about a DVD or a BD? m2ts files are from Bluray. DVDs use VOBs.
Stryker412
Sorry yes I mean vob. I'm in BD mode most of the time.
Grauhaar
Post by Grauhaar »
This documentaion is very old and long time available on DVD. On my server are 12 single episodes ripped from the DVDs years ago. Try it with "File-> Open DVD files manually", maybe it helps.
Good Luck :)
Stryker412
I don't see any options like that in MakeMKV.
Grauhaar
Post by Grauhaar »
Recheck my posting
Good Luck :)
