Forums over on AnyDVD have identified 'The Roosevelts - An Intimate History' disc 1 (and others) as having a new DVD copy protection scheme.
Here is the log from attempting to rip disc one of this set via makemkv:
Title #1 was added (15 cell(s), 1:52:48)
Title #3 has length of 82 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #4 was added (1 cell(s), 0:12:35)
Title #5 was added (1 cell(s), 0:18:46)
Title #6 has length of 204 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #7 has length of 182 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #8 has length of 125 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #9 has length of 191 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #10 has length of 159 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #11 was added (1 cell(s), 0:04:15)
Title #12 was added (1 cell(s), 0:04:03)
Title #13 was added (1 cell(s), 0:04:17)
Title #14 has length of 200 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #15 has length of 166 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #16 was added (1 cell(s), 0:05:13)
Title #17 was added (13 cell(s), 1:09:34)
Title #18 has length of 5 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #19 was added (1 cell(s), 0:18:25)
Title #20 was added (1 cell(s), 0:23:35)
Title #23 was added (12 cell(s), 1:37:19)
Title #25 has length of 82 seconds which is less than minimum title length of 240 seconds and was therefore skipped
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Cells 15-15 were removed from title end
Title #28 has length of 82 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #31 has length of 82 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #34 has length of 82 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #35 was added (12 cell(s), 1:37:19)
Title #37 has length of 82 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #40 has length of 82 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #43 has length of 82 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #46 has length of 82 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #49 has length of 82 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #52 has length of 82 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #55 has length of 82 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #58 has length of 82 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #61 has length of 82 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #64 has length of 82 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title #65 was added (11 cell(s), 1:27:12)
Title #67 has length of 82 seconds which is less than minimum title length of 240 seconds and was therefore skipped
Title 1 in VTS 8 is equal to title 1 and was skipped
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..02897C80..00CC4 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..03D606A0..00CC4 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..03D9CF10..00CC4 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..00126A90..00CC4 to device 'SPTI:\Device\CdRom0'
Saving 12 titles into directory //SCHROCKDATA/video/mkv/The Roosevelts - An Intimate History/Episode 1
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_09_1.VOB' at offset '19306496'
Failed to save title 0 to file //SCHROCKDATA/video/mkv/The Roosevelts - An Intimate History/Episode 1/title00.mkv
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_04_1.VOB' at offset '16758784'
Failed to save title 8 to file //SCHROCKDATA/video/mkv/The Roosevelts - An Intimate History/Episode 1/title08.mkv
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_08_1.VOB' at offset '19306496'
Failed to save title 10 to file //SCHROCKDATA/video/mkv/The Roosevelts - An Intimate History/Episode 1/title10.mkv
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_22_1.VOB' at offset '19306496'
Failed to save title 11 to file //SCHROCKDATA/video/mkv/The Roosevelts - An Intimate History/Episode 1/title11.mkv
8 titles saved, 4 failed
The Roosevelts - new DVD protection scheme
schrockstar
Re: The Roosevelts - new DVD protection scheme
Typing as someone not affiliated with MakeMKV as anything other than a user:
Scratched or dirty disk, drive problem, or badly mastered disk.
If it truly is a "new copy protection scheme", every disk in that set will have the SAME error. It is highly unlikely that a company would apply a copy protection scheme on one disk of a set, but not others. It is rather more common for a bad stamping of a disk to occur, which will affect many users, but isn't a copy protection scheme.
But, then again, a failing (or dirty) drive would also give the same error on multiple disks.
schrockstar
If any other users have difficulty ripping discs from this set, I would encourage you to post your makemkv log to the thread. If you have unrecoverable ECC errors at the exact same offset as reported in my logs, this may help those who are interested.
For what it is worth, the "new copy protection" discussed on AnyDVD forums in November 2014 had nothing to do with getting media errors. They had to do with a work-around to a mastering error in some of the tracks.
MakeMKV will report things like that with a debug message about a section being "Invalid or corrupt", along with a code to say which work-around is being tried to fix the problem.
aecad
This is the screen log for the title that appears to be Episode 1 (12 chapters) and what MakeMKV is reporting as a "Scsi error" occurs at the exact same offset as the log of the OP. Also note that both AnyDVD and DVDFab users had problems with both the DVDs and BDs of this title and Downton Abbey season 4 and 5. I will try to collect data on all seven discs of this set and submit by email.
MakeMKV v1.9.1 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Aecad/MakeMKV_log.txt
Title #3 was added (1 cell(s), 0:01:22)
Title #6 was added (1 cell(s), 0:03:23)
Title #7 was added (1 cell(s), 0:03:02)
Title #8 was added (1 cell(s), 0:02:05)
Title #9 was added (1 cell(s), 0:03:10)
Title #10 was added (1 cell(s), 0:02:39)
Title #14 was added (1 cell(s), 0:03:20)
Title #15 was added (1 cell(s), 0:02:46)
Title #18 has length of 5 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #25 was added (1 cell(s), 0:01:22)
DEBUG: Code 10551311 at 2v\x6:dUo2"1l{@\:213142128
DEBUG: Code 0 at 2v\x6:dUo2"1l{@\:213143301
DEBUG: Code 0 at <|C!&I&2z{,(s O7|P:29394229
Title #28 was added (1 cell(s), 0:01:22)
Title #31 was added (1 cell(s), 0:01:22)
Title #34 was added (1 cell(s), 0:01:22)
Title #37 was added (1 cell(s), 0:01:22)
Title #40 was added (1 cell(s), 0:01:22)
Title #43 was added (1 cell(s), 0:01:22)
Title #46 was added (1 cell(s), 0:01:22)
Title #49 was added (1 cell(s), 0:01:22)
Title #52 was added (1 cell(s), 0:01:22)
Title #55 was added (1 cell(s), 0:01:22)
Title #58 was added (1 cell(s), 0:01:22)
Title #61 was added (1 cell(s), 0:01:22)
Title #64 was added (1 cell(s), 0:01:22)
Title #67 was added (1 cell(s), 0:01:22)
Title 3 in VTS 21 is equal to title 3 and was skipped
Saving 1 titles into directory F:/
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_08_1.VOB' at offset '19306496'
DEBUG: Code 0 at y6*vfE*%I]?KB[pfW2x&:121263038
DEBUG: Code 0 at _}>2]/?KC0L=d8 `"oE:121261750
DEBUG: Code 0 at y6*vfE*%I]?KB[pfW2x&:213130559
DEBUG: Code 9427 at y6*vfE*%I]?KB[pfW2x&:29393286
DEBUG: Code 0 at {Sd%j8Wv.P@.V@bGTwF]7:29399013
Failed to save title 18 to file F://title18.mkv
0 titles saved, 1 failed
Pioneer BD-RW BDR-208D / Intel i7-4770K / Windows 7 Ultimate (64 bit)
tgbauer
D3 also has some issue
MakeMKV v1.9.1 darwin(x86-release) started
Optical drive "DVD+R-DL TSSTcorp CDDVDW SN-208DB SB01d" opened in OS access mode.
Optical drive "BD-RE PIONEER BD-RW BDR-206 1.04d" opened in OS access mode.
Error 'Internal error - Operation was cancelled (112)' occurred while reading 'DVD+R-DL TSSTcorp CDDVDW SN-208DB SB01' at offset '550912'
Error 'Internal error - Operation was cancelled (112)' occurred while reading 'DVD+R-DL TSSTcorp CDDVDW SN-208DB SB01' at offset '32768'
Error 'Internal error - Operation was cancelled (66)' occurred while issuing SCSI command 460200010..00100 to device 'IoKit:IOBDServices:0c3f81186cc073b4:PIONEER BD-RW BDR-206 1.04'
Title #1 was added (13 cell(s), 1:36:08)
Title #3 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 was added (1 cell(s), 0:25:30)
Title #6 was added (1 cell(s), 0:22:40)
Title #11 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 was added (11 cell(s), 1:22:15)
Title #14 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 was added (14 cell(s), 1:44:44)
Title #17 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 was added (11 cell(s), 1:22:15)
Title #20 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 18-18 were removed from title end
Title #23 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #26 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #29 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #32 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #35 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #38 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #41 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #42 was added (12 cell(s), 1:30:06)
Title #44 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #47 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #53 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 6 titles into directory /Volumes/Intel730/Roosevelts_D3
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '16748544'
Failed to save title 1 to file /Volumes/Intel730/Roosevelts_D3/title01.mkv
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_04_1.VOB' at offset '16769024'
Failed to save title 2 to file /Volumes/Intel730/Roosevelts_D3/title02.mkv
4 titles saved, 2 failed
tgbauer
It may help to know what worked using other programs:
1. Play DVD, select main feature and make note of the Title #
2. Use mplayer to capture the video to a file. In this example: cache = 80MB; raw optical device = /dev/rdisk3; Track = 29; output file = ~/Roosevelts_D1.vob:
mplayer -cache 81920 -dvd-device /dev/rdisk3 dvd://29 -dumpstream -dumpfile ~/Roosevelts_D1.vob
3. Use HandBrake to convert raw file into mp4
Not sure if something similar can be automated into MakeMKV as a last effort when other methods to read the main feature fail.
If you know the correct title number, you can just open the disc in manual mode - /manualdvd/
rwsmith425
Was there ever a solution for this? I am experiencing the same issue. I also tried HandBrake and it freezes.
Saving 2 titles into directory /Users/randysmith/Movies/_Roosevelts D1_C304
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/VIDEO_TS/VTS_08_1.VOB' at offset '19306496'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk1' at offset '19306496'
Failed to save title 17 to file /Users/randysmith/Movies/_Roosevelts D1_C304/title_t17.mkv
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/VIDEO_TS/VTS_22_1.VOB' at offset '19306496'
Failed to save title 18 to file /Users/randysmith/Movies/_Roosevelts D1_C304/title_t18.mkv
Encountered 22 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
0 titles saved, 2 failed
No, you're encountering a different issue, just on the same DVD.
Hardware tracking errors are when the drive cannot move the head to where it thinks the track is. That can be caused by hardware failure (will usually show up on other disks, too), damaged/dirty disks that decodes incorrectly, or a fake play list that points to outside the data area of the disk (not uncommon with Lionsgate disks).
asset4
Same thing on discs 1 and 3. This is on a retry with some titles working that were intentionally skipped. At first I thought it was a drive issue so I tried different drives.
Disc 1:
Disc 1:
Disc 3:MakeMKV v1.15.1 win(x64-release) started
Title #4 has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #11 was added (1 cell(s), 0:01:22)
Title #14 was added (1 cell(s), 0:01:22)
Title #17 was added (1 cell(s), 0:01:22)
Title #20 was added (1 cell(s), 0:01:22)
Title #23 was added (1 cell(s), 0:01:22)
Title #26 was added (1 cell(s), 0:01:22)
Title #29 was added (1 cell(s), 0:01:22)
Title #32 was added (1 cell(s), 0:01:22)
Title #35 was added (1 cell(s), 0:01:22)
Title #38 was added (1 cell(s), 0:01:22)
Title #41 was added (1 cell(s), 0:01:22)
Title #44 was added (1 cell(s), 0:01:22)
Title #47 was added (1 cell(s), 0:01:22)
Title #50 was added (1 cell(s), 0:01:22)
Title #53 was added (1 cell(s), 0:01:22)
Title 3 in VTS 17 is equal to title 3 and was skipped
Saving 7 titles into directory N:/_Roosevelts D3_AD64
Title 0 skipped
Title 1 skipped
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '16748544'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '16748544'
Failed to save title 2 to file N:/_Roosevelts D3_AD64/title_t02.mkv
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_04_1.VOB' at offset '16769024'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '16769024'
Failed to save title 3 to file N:/_Roosevelts D3_AD64/title_t03.mkv
Title 4 skipped
Title 5 skipped
Title 6 skipped
Encountered 53 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
Title #18 has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Saving 20 titles into directory N:/_Roosevelts D1_C304
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '19306496'
Failed to save title 0 to file N:/_Roosevelts D1_C304/title_t00.mkv
Title 1 skipped
Title 2 skipped
Title 3 skipped
Title 4 skipped
Title 5 skipped
Title 6 skipped
Title 7 skipped
Title 8 skipped
Title 9 skipped
Title 10 skipped
Title 11 skipped
Title 12 skipped
Title 13 skipped
Title 14 skipped
Title 15 skipped
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '16758784'
Failed to save title 16 to file N:/_Roosevelts D1_C304/title_t16.mkv
Title 17 skipped
Failed to save title 18 to file N:/_Roosevelts D1_C304/title_t18.mkv
Failed to save title 19 to file N:/_Roosevelts D1_C304/title_t19.mkv
Encountered 95 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
0 titles saved, 4 failed
This is in the Bluray section, but it applies to DVDs as well: If you're experiencing rip errors, please read here first!
Disk read errors are not the same as copy protection schemes.
crazyheartstrings
Open DVD Manually using VLC->Playlist->Title will make you much happier on just about ALL Ken Burns documentary boxsets. I've successfully ripped The Roosevelts, The Vietnam War, War, American Lives, America, The Civil War, The West, The Dustbowl, Prohibition and am halfway through Jazz. A few rip just fine, most are much better/faster with the VLC/Manual DVD method.
(War D6 Main Feature is split in 2) (Jazz D3 needs CC turned off)
Anyway here's The Roosevelts D1:
Manual mode
Main title 59
Special features (Play all) 17
MakeMKV v1.16.5 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/dawnvanderpool/MakeMKV_log.txt
Optical drive "DVD+R-DL HL-DT-ST DVDRW GS31N TA17 K0ZB8651835d" opened in OS access mode.
Open DVD manually : "59 17"
DEBUG: Code 10551311 at [5db#qwT$:sonyQ$:213142496
DEBUG: Code 0 at [5db#qwT$:sonyQ$:121274998
DEBUG: Code 0 at sxi6tX15]1=@7.Tmm(:29394229
Title #59 was added (13 cell(s), 1:53:20)
DEBUG: Code 233 at XpXPywNOah/CX/RpRtEOnV3b:0
Saving 2 titles into directory /Users/dawnvanderpool/Movies/_Roosevelts D1_C304
DEBUG: Code 0 at Kes%`\bI4JgmZV[xQ:213130237
AV synchronization issues were found in file '/Users/dawnvanderpool/Movies/_Roosevelts D1_C304/title_t00.mkv' (title #1)
AV sync issue in stream 1 at 1:52:11.840 with duration of 218.666ms : audio gap - 6.833 missing frame(s)
AV sync issue in stream 2,3,4 at 1:52:11.936 with duration of 122.666ms : audio gap - 3.833 missing frame(s)
AV sync issue in stream 1 at 0:31:23.849 with duration of 208.833ms : audio gap - 6.526 missing frame(s)
2 titles saved
Manual mode
Main title 59
2 titles saved
