Great, then I'll hack up the source to put profile 8 for everythingplanet_hoarder wrote: ↑Thu Jun 25, 2020 7:15 pmNo LG tv is able to playback dual layer DV profile 7 with FEL over 8MB/s. Only 60fps (Gemini Man) gave a problem.MastaG wrote: ↑Thu Jun 25, 2020 10:02 amI noticed the same, but I think the reason for the stutters in profile 4 and 6 is because the TV's internal player is not capable of handling the full enhanced layer of such high bitrate movies.planet_hoarder wrote: ↑Tue Jun 23, 2020 11:29 pm
Good question.
It depends which is playback device. If you can playback lossless audio (with proper speakers) with DV, then use tsMuxer. Otherwise mp4muxer_64bit is the best tool.
If you use mp4muxer_64bit, then you don't need yusecope's tool at all. It can create perfect DV mp4. If your device supports Profile 7, then use it.
with tsMuxer, I was only able to make work nightly release from 16th March. It creates profile 8 from BL_EL_RPU.hevc (yusecope's tool), and triggers DV on my LG OLED. Any other profile (4 or 6) from tsMuxer was not properly working for me.
Maybe because profile 8 is still work in progress and it just plays everything.
I think when using profile 8 it's discarding the enhanced layer and only processing the metadata.. like using BL+RPU (mode 2).
profile 8 cannot discard anything - I create using mode 1 so it is BL+EL+RPU output
If you're playing it back on the Shield, I honestly don't think it matters what profile you put it in. It seems to me that as long as the software (Plex, MXPlayer, MrMC, etc) can recognize the DV stream, it will pass it on to the hardware decoder. I have looked at the Plex exoplayer logs when attempting to play a profile 6 video that is considered deprecated and has no confirmed support. The logs show that the software doesn't recognize the dvhe.06.0x codec (it does for dvhe.04.0x), but still acknowledges that it contains a DV stream, so it passes it onto the hardware decoder for playback.MastaG wrote: ↑Thu Jun 25, 2020 7:39 pmGreat, then I'll hack up the source to put profile 8 for everythingplanet_hoarder wrote: ↑Thu Jun 25, 2020 7:15 pmNo LG tv is able to playback dual layer DV profile 7 with FEL over 8MB/s. Only 60fps (Gemini Man) gave a problem.MastaG wrote: ↑Thu Jun 25, 2020 10:02 am
From a pure dolby specs standpoint, a single PID BL+EL+RPU stream that has HDR10 backwards compatibility should be either 6 or 7 (our case here). It should not be profile 8 as the latest dolby profiles specsheet clearly states that it is a single layer profile.
Gemini Man on the shield stutters with DV, but smooth with HDR10, am i correct when i say 59.94fps + DV is beyond HDMI2.0b standard?
no you are not.
no playback issue on bluray players. My x700 play that movie at 60fps in DV+ Atmos + subs just fine.
ok, interesting. BL+EL+RPU or stripped of EL?RESET_9999 wrote: ↑Fri Jun 26, 2020 11:22 amno you are not.
Dual layer profile 7 BL+EL+RPU
how did you create dual layer profile 7 with atmos?
have you read anything more about kodi and different DV profiles? where did u read about this? is it only profile 5? thxGrencola wrote: ↑Fri May 15, 2020 3:27 amIt's already happened the Ugoos AM6 Plus plays profile 7 dv rips in kodi 18.6 (seek to 5:15ish): https://drive.google.com/file/d/1cpBJSM ... Wt_2A/view I've also heard from people who have successfully played DV profile 5 rips in kodi 19 on their shield. both devices are quickly shaping up to be m9702 killers..
Latest tsMuxer but that method only works on the x700 and the oppo.planet_hoarder wrote: ↑Fri Jun 26, 2020 12:33 pmhow did you create dual layer profile 7 with atmos?
My DV rip of Gemini Man have no playback issues on the Shield, and I'm pretty sure several others have reported no issues as well previously.
what will i get if i run mp4muxer and create a profile 5 mp4 with BL+EL+RPU from yuse tool?
It plays fine but what am i seeing ? BL+RPU cause its profile 5?
the filesize and bitrate is more with BL+EL+RPU even though its profile 5 so i guess placebo can make it look better :p
Hey,
Looking for a little help here, I went back many pages, and I am not sure how to do this process in it's completion.
I tried FFMPEG and got nothing but errors
I just got a new system capable of atmos, and really want to be able to do this. I have tried the disc and the blu ray folder, but nothing works.
I know there is a lot of help here and I mostly followed
viewtopic.php?t=18602&start=1650
it depends, if EL really makes picture 12bit, than it's useless everywhere, since there are no consumer 12bit panels.box4m wrote: ↑Fri Jun 26, 2020 4:12 pmwhat will i get if i run mp4muxer and create a profile 5 mp4 with BL+EL+RPU from yuse tool?
Then all profiles are the same, since they show BL+RPU
there is no benefit of using yusecope's tool, if you are creating DV file with mp4muxer.
can you be more specific? "atmos capable" usually mean can playback atmos object data, but for real atmos effect you need height speakers.besson wrote: ↑Mon Jun 29, 2020 5:53 amHey,
what did you do exactly? which tools?
where did you try to playback? how everything is connected?
It's true that a FEL makes the picture 12 bit, and there are no consumer displays capable of more than 10bit, but saying it is useless and that all profiles are essentially just BL+RPU is just not correct. Please give this a good read:planet_hoarder wrote: ↑Mon Jun 29, 2020 2:32 pmit depends, if EL really makes picture 12bit, than it's useless everywhere, since there are no consumer 12bit panels.box4m wrote: ↑Fri Jun 26, 2020 4:12 pmwhat will i get if i run mp4muxer and create a profile 5 mp4 with BL+EL+RPU from yuse tool?
https://forum.blu-ray.com/showpost.php? ... tcount=119
