MastaG
Post by MastaG » Thu Jun 25, 2020 7:39 pm
planet_hoarder wrote:
Thu Jun 25, 2020 7:15 pm
MastaG wrote:
Thu Jun 25, 2020 10:02 am
Tue Jun 23, 2020 11:29 pm
Good question.
It depends which is playback device. If you can playback lossless audio (with proper speakers) with DV, then use tsMuxer. Otherwise mp4muxer_64bit is the best tool.
If you use mp4muxer_64bit, then you don't need yusecope's tool at all. It can create perfect DV mp4. If your device supports Profile 7, then use it.
with tsMuxer, I was only able to make work nightly release from 16th March. It creates profile 8 from BL_EL_RPU.hevc (yusecope's tool), and triggers DV on my LG OLED. Any other profile (4 or 6) from tsMuxer was not properly working for me.
Maybe because profile 8 is still work in progress and it just plays everything.
I noticed the same, but I think the reason for the stutters in profile 4 and 6 is because the TV's internal player is not capable of handling the full enhanced layer of such high bitrate movies.
I think when using profile 8 it's discarding the enhanced layer and only processing the metadata.. like using BL+RPU (mode 2).
No LG tv is able to playback dual layer DV profile 7 with FEL over 8MB/s. Only 60fps (Gemini Man) gave a problem.
profile 8 cannot discard anything - I create using mode 1 so it is BL+EL+RPU output
Great, then I'll hack up the source to put profile 8 for everything :)
Post by shawnc22 » Thu Jun 25, 2020 9:18 pm
If you're playing it back on the Shield, I honestly don't think it matters what profile you put it in. It seems to me that as long as the software (Plex, MXPlayer, MrMC, etc) can recognize the DV stream, it will pass it on to the hardware decoder. I have looked at the Plex exoplayer logs when attempting to play a profile 6 video that is considered deprecated and has no confirmed support. The logs show that the software doesn't recognize the dvhe.06.0x codec (it does for dvhe.04.0x), but still acknowledges that it contains a DV stream, so it passes it onto the hardware decoder for playback.
From a pure dolby specs standpoint, a single PID BL+EL+RPU stream that has HDR10 backwards compatibility should be either 6 or 7 (our case here). It should not be profile 8 as the latest dolby profiles specsheet clearly states that it is a single layer profile.
box4m
Post by box4m » Fri Jun 26, 2020 11:11 am
Gemini Man on the shield stutters with DV, but smooth with HDR10, am i correct when i say 59.94fps + DV is beyond HDMI2.0b standard?
Post by RESET_9999 » Fri Jun 26, 2020 11:22 am
no you are not.
no playback issue on bluray players. My x700 play that movie at 60fps in DV+ Atmos + subs just fine.
box4m
Post by box4m » Fri Jun 26, 2020 11:27 am
no you are not.
ok, interesting. BL+EL+RPU or stripped of EL?
Post by RESET_9999 » Fri Jun 26, 2020 11:58 am
Dual layer profile 7 BL+EL+RPU
planet_hoarder
Post by planet_hoarder » Fri Jun 26, 2020 12:33 pm
how did you create dual layer profile 7 with atmos?
box4m
Post by box4m » Fri Jun 26, 2020 1:49 pm
Grencola wrote:
Fri May 15, 2020 3:27 am
kazuma wrote:
Thu May 14, 2020 9:21 pm
thetoad wrote:
Thu May 14, 2020 6:52 pm
I use my m9702 daily, with that said, it is far from perfect. If KODI or Plex could ever play dolby vision bluray rips to my TV we;;, life will be much better. with that said, we are far from that day.
never gonna happen..
It's already happened :P the Ugoos AM6 Plus plays profile 7 dv rips in kodi 18.6 (seek to 5:15ish): https://drive.google.com/file/d/1cpBJSM ... Wt_2A/view I've also heard from people who have successfully played DV profile 5 rips in kodi 19 on their shield. both devices are quickly shaping up to be m9702 killers..
have you read anything more about kodi and different DV profiles? where did u read about this? is it only profile 5? :) thx
Post by RESET_9999 » Fri Jun 26, 2020 2:07 pm
Latest tsMuxer but that method only works on the x700 and the oppo.
Post by shawnc22 » Fri Jun 26, 2020 3:04 pm
My DV rip of Gemini Man have no playback issues on the Shield, and I'm pretty sure several others have reported no issues as well previously.
box4m
Post by box4m » Fri Jun 26, 2020 4:12 pm
what will i get if i run mp4muxer and create a profile 5 mp4 with BL+EL+RPU from yuse tool?
It plays fine but what am i seeing :P? BL+RPU cause its profile 5?
the filesize and bitrate is more with BL+EL+RPU even though its profile 5 so i guess placebo can make it look better :p
besson
Post by besson » Mon Jun 29, 2020 5:53 am
Hey,
Looking for a little help here, I went back many pages, and I am not sure how to do this process in it's completion.
I tried FFMPEG and got nothing but errors
I just got a new system capable of atmos, and really want to be able to do this. I have tried the disc and the blu ray folder, but nothing works.
I know there is a lot of help here and I mostly followed
viewtopic.php?t=18602&start=1650
planet_hoarder
Post by planet_hoarder » Mon Jun 29, 2020 2:32 pm
it depends, if EL really makes picture 12bit, than it's useless everywhere, since there are no consumer 12bit panels.
Then all profiles are the same, since they show BL+RPU
there is no benefit of using yusecope's tool, if you are creating DV file with mp4muxer.
planet_hoarder
Post by planet_hoarder » Mon Jun 29, 2020 2:35 pm
Hey,
can you be more specific? "atmos capable" usually mean can playback atmos object data, but for real atmos effect you need height speakers.
what did you do exactly? which tools?
where did you try to playback? how everything is connected?
Post by shawnc22 » Mon Jun 29, 2020 3:12 pm
It's true that a FEL makes the picture 12 bit, and there are no consumer displays capable of more than 10bit, but saying it is useless and that all profiles are essentially just BL+RPU is just not correct. Please give this a good read:
https://forum.blu-ray.com/showpost.php? ... tcount=119
