Does it convert - transform truehd into ac3??
grigoris
Can this program convert truehd mkv or blueray into simple ac3 surround???
Re: Does it convert - transform truehd into ac3??
Generally speaking, when MakeMKV encounters a TrueHD track, it will give you both the "complete" TrueHD track, and extract the "lossy core" AC3 track.
grigoris
How exactly i choose to convert one truehd sound of an mkv file into ac3 loseless?
And make change only at audio nothing else.
I try a sample of one mkv file that has one truehd sound that was only 1 minute long and the program it make more than 20-30 minutes and still doesn't end so i stop it.
So are you completely sure that this program can convert truehd into ac3 loseless????
AC3 is not a lossless format, so it is impossible to convert to it losslessly.
But a TrueHD track contains AC3 data within it, so MakeMKV simply copies that part of the track out as a separate track for decoders that aren't smart enough to do that on their own.
grigoris
And why even a video file 1 minute lenth-long is SO REALLY LATE to do it????
And as i tallied you before i STOP IT BEFORE IT COMPLETED CAUSE IT WOULD TAKE TOOOOOOOO LONG FOR 1 MINUTE VIDEO FILE.
bmillham
A 1 minute file should not take long at all to rip. If it's taking that long for you then either you have a dirty/damaged disc, or your drive is defective. The audio format makes no difference as it's just copying the tracks without change.
grigoris
For beggining LEARN TO READ BEFORE YOU ANSWER.
NEVER SAY I RIP A BLURAY. NEVER.
READ AND THEN ANSWER.
bmillham
Wow, you are a rude one.
I guess you don't understand what MakeMKV is for. It's for Ripping DVD/BD's, not for transcoding MKVs.
Also, I'd suggest that you read your post. I quote you here:
That reads to me as ripping a bluray.Can this program convert truehd mkv or blueray
grigoris
I know VERY WELL what the program is for.
But i know that can convert truehd audio into ac3 to as describe at the program characteristics.
So.....
So.....
