BD Drive won't rip DVD or Blu-rays all of a sudden
BhamPax
Re: BD Drive won't rip DVD or Blu-rays all of a sudden
Post by BhamPax »
I am having this problem as well. SDF v73 did not fix it. Drive was not previously supported by Libredrive.
SDF v073: HL-DT-ST_BDDVDRW_UH12NS30_1.03_211404241900_K9PF9QA3831
BhamPax
Post by BhamPax »
Update: After updating the registry value (Windows 10) for sdf_stop to my info I am now able to proceed.
For those of you who don't know where to look: Computer\HKEY_CURRENT_USER\Software\MakeMKV
beblank1us
Post by beblank1us »
BhamPax wrote: Mon Jun 22, 2020 3:29 pm Update: After updating the registry value (Windows 10) for sdf_stop to my info I am now able to proceed.
Which registry value did you edit? I have the same drive and have not been able to get past the decrypting stage. Attached are entries I currently have available in the registry for MakeMKV and the user variable for SDF_STOP.
2020-06-22 22_40_33-Start.png (5.49 KiB) Viewed 39509 times
2020-06-22 22_38_49-Start.png (11.49 KiB) Viewed 39509 times
gottawatch
Post by gottawatch »
beblank1us wrote: Tue Jun 23, 2020 3:42 am
For your variable value, try deleting the first part "SDF v073: " and leave just your drive ID. When you restart MakeMKV, you should be good to go with the workaround.
BhamPax
Post by BhamPax »
The sdf_Stop key was already there with no value entered when I went to find the setting.
Registry keys and environment variables are usually case-sensitive, so "sdf_Stop" is not the same as "Sdf_stop".
Post by mike admin »
Update pushed, please try again. Maybe it will work this time...
paraw
Post by paraw »
Tried with SDF v74, no luck.
Still a bunch of
DEBUG: Code 0 at ZF2@*aqIu4mgMH0Yh:213130766
DEBUG: Code 3 at Z3bZeQqXT9X4>IGo:":29395195
Error 'Internal error - Operation result is incorrect (132)' occurred whiie issuing SCSI command A40..0020..0FF to device 'SG:dev_21:1'
Then, at the end
followed by a crash.
gottawatch
Also no luck with SDF v74.
SDF v074: hp_BDDVDRW_CH30L_BC56_210000000000_348CF003445
001003:0020 DEBUG: Code 2399219969 at 514U4Qpim*J{}UjC?:213132399
DEBUG: Code 0 at 514U4Qpim*J{}UjC?:213132215
001003:0020 DEBUG: Code 2399211777 at 514U4Qpim*J{}UjC?:213132399
DEBUG: Code 1 at 514U4Qpim*J{}UjC?:213132215
DEBUG: Code 2 at 514U4Qpim*J{}UjC?:213132215
DEBUG: Code 3 at 514U4Qpim*J{}UjC?:213132215
DEBUG: Code 4 at 514U4Qpim*J{}UjC?:213132215
DEBUG: Code 5 at 514U4Qpim*J{}UjC?:213132215
DEBUG: Code 0 at 514U4Qpim*J{}UjC?:213132031
DEBUG: Code 0 at !g|`?-JJCvH7_aDw8:121261773
DEBUG: Code 0 at !g|`?-JJCvH7_aDw8:29393792
001003:0020 DEBUG: Code 3221225664 at a#>oq:av;Y j4;_J:213130559
001003:0020 DEBUG: Code 3221225664 at <L16^|;$dv,=@_}j,*:213131778
001003:0020 DEBUG: Code 3221225664 at <L16^|;$dv,=@_}j,*:121261934
002003:0000 Error 'OS error - This device does not exist' occurred while reading 'BD-ROM hp BDDVDRW CH30L BC56' at offset '524288'
002003:0000 Error 'OS error - This device does not exist' occurred while reading 'BD-ROM hp BDDVDRW CH30L BC56' at offset '1048576'
002003:0000 Error 'OS error - This device does not exist' occurred while reading 'BD-ROM hp BDDVDRW CH30L BC56' at offset '32768'
001003:0020 DEBUG: Code 0 at \Mt(tcC2mH?WLP\*V2[:213129777
002001:0000 File system not recognized, disc can't be opened
001003:0020 DEBUG: Code 3221225664 at 266L9_:?HCenQ;[b:213134952
And that last line repeats a lot.
After this, I had to power off and on my drive to get it to eject the disc.
paraw wrote: Tue Jun 23, 2020 2:23 pm Tried with SDF v74, no luck.
Ok, I'm disabling these drives for everyone for now. The individual SDF_STOP should not be necessary anymore. Sorry for the screw-up...
Please do check this topic, I might ask for help, as I am unable to reproduce this crash on my hardware.
MrVanx
Post by MrVanx »
mike admin wrote: Tue Jun 23, 2020 4:27 pm
Hi Mike, apologies Ive only just revisited the forum and missed out on the v74 sdf testing :)
The latest is loaded now and libredrive is not enabled, all is working as it should.
Happy to do some testing, as long as it doesn't have the potential to bork my drive permanently of course :D
Penfold82
Post by Penfold82 »
Hi Mike,
As I said in previous post changing my sata controller from IDE to AHCI sorted the issue for me and every SDF update after worked ok.
I appreciate all the hard work you are doing and If you need some testing, I can try to help out changing controller mode etc.
Penfold82 wrote: Wed Jun 24, 2020 10:12 pm As I said in previous post changing my sata controller from IDE to AHCI sorted the issue for me and every SDF update after worked ok.
There were two separate bugs in that code. Hang in IDE mode was just one of them (not rally a bug of my microcode, rather a missing workaround for buggy IDE controller).
Other bug is fixed (hopefully) as of now too, sdf v76 should work.
paraw
Post by paraw »
I can confirm that SDF v76 works for me (at least for the moment). :D
Thank you for looking into this!
jtiger102
Post by jtiger102 »
I think I may have the same bug.
Using SDF v76.
I have the Asus drive in the Vantec external enclosure via USB with patched firmware for Libredrive.
If I power on the drive without MakeMKV open, the drive acts normally. That is, it powers on, reads a disc, and I get the Win10 notification.
I have to have the drive powered on prior to opening MakeMKV, otherwise it doesn't detect any drives and I have to restart MakeMKV. I think this is normal anyway.
After opening MakeMKV, it seems to read the disc to get the structure, etc just fine.
However, after starting the read process, it hangs and doesn't go any further. I have to manually stop the process, which does take a few seconds. MakeMKV eventually responds with a fatal error message and then closes. I am unable to eject the drive.
If I go to power off the drive, it takes a few seconds for the Windows USB disconnect sound. If I repower the drive after waiting for 10 seconds, it responds normally and I'm able to eject the drive. However, it won't read the disc.
Just to be safe, I uninstalled and reinstalled MakeMKV as well. No dice.
I am running Windows 10 v2004 if that makes any difference.
MakeMKV_log.txt
(13.34 KiB) Downloaded 1161 times
