Alldu
#2581 Post by Alldu » Thu Jun 18, 2020 11:18 pm
Some weird stuff here. So I created an m2ts DV file of Schindler's List with the edited tsMuxer, and everything is cool... except that my Sony X700 somehow refuses to fast forward it or rewind! It just says - this operation is prohibited. Anybody encountered the same anomaly? I did many DV titles, but this is the first time I see something like this. What could that be? Maybe because the movie is over 3 hours? Or the file is 97Gb? What gives?
box4m
#2582 Post by box4m » Sun Jun 21, 2020 9:08 am
when using mp4muxer, initially it uses abit of cpu and disk i/o, but then it seems to do nothing for forever until its done?
i have 3900x @ 4,25GHz and pci-e 4.0 disk so it should not take forever, what is it doing? can i enable logs?
edit: instead of making another post i got another question:
1) demux BL+EL with tsMuxer (04.06 fix)) (that has worked well for me every time without mp4box)
2) demux TrueHD audio "ffmpeg.exe -i bluray:path/to/bluray -map 0:AUDIO_STREAM -c:a copy -strict -2 X:\atmos.mp4"
3) run yusecope tool with BL+EL only -mode 1
4) "mp4muxer_64bits.exe --dv-profile 4 --input-file "step3_output.hevc" --media-lang eng --output-file X:\mp4muxer_output_only_video.mp4"
5) "mp4box.exe -add X:\step4_output.mp4 -add X:\step2_output.mp4:lang=eng -brand mp42isom -ab dby1 X:\mp4box_out.mp4 -tmp X:\"
this file does not play with mxplayer on 2019 shield, i get "cant play file", with plex i get HDR10 only and weird behaviour, cant fastforward etc
What gives?
planet_hoarder
#2583 Post by planet_hoarder » Sun Jun 21, 2020 1:40 pm
box4m wrote: Sun Jun 21, 2020 9:08 am when using mp4muxer, initially it uses abit of cpu and disk i/o, but then it seems to do nothing for forever until its done?
What gives?
your powerful CPU means nothing if program uses only one thread. Since it is run from CMD, then most probably it is.
AFAIK you can create an mp4 with TrueHD, but I am not sure any existent player can play TrueHD from mp4. That's why people are using tsMuxer to mix output from yusecope's tool and TrueHD+Atmos.
try to create a profile 8, that should work on Shield TV.
box4m
#2584 Post by box4m » Sun Jun 21, 2020 2:10 pm
planet_hoarder wrote: Sun Jun 21, 2020 1:40 pm
What gives?
I will try profile 8 thanks.
Regarding only using one thread, ye maybe, but its called mp4muxer_64bit
edit: where can i read about the profiles btw? dolby seems to have removed the pdf?
#2585 Post by shawnc22 » Sun Jun 21, 2020 2:45 pm
What gives?
Why are you doing all of this if you have a shield? Also profile 8 is a single layer DV profile that has no EL support.
box4m
#2586 Post by box4m » Sun Jun 21, 2020 4:14 pm
shawnc22 wrote: Sun Jun 21, 2020 2:45 pm
What gives?
what should i be doing?
i didnt get m2ts or ts working with mxplayer
planet_hoarder
#2587 Post by planet_hoarder » Sun Jun 21, 2020 4:46 pm
box4m wrote: Sun Jun 21, 2020 2:10 pm
What gives?
they didn't remove it, just changed the location:
https://professional.dolby.com/siteasse ... _09_16.pdf
yes, it is called xxx_64bit, but not xxx_64bit_mutithread. Two completely different things.
also for shield, you don't need to use Dolby's mp4muxer.
you can use your tsMuxer (04.06 fix). put output of yusecope's tool there and add sound, that's it.
for profile 8 you can try nightly release tsMuxer from 16-th March 2020.
https://bintray.com/justdan96/tsMuxer/t ... 1-36#files
#2588 Post by shawnc22 » Sun Jun 21, 2020 5:05 pm
planet_hoarder wrote: Sun Jun 21, 2020 4:46 pm they didn't remove it, just changed the location:
No, don’t do this. If you’re making BL+EL+RPU files, stick with the 04.06 version of tsmuxer you’ve been using. Profile 8 is not the correct profile to use for these files.
box4m
#2589 Post by box4m » Sun Jun 21, 2020 6:18 pm
tsmuxer finishes in 0seconds when trying to mux to .ts "finished with error code -1", not sure if there are logs?
MastaG
#2590 Post by MastaG » Sun Jun 21, 2020 8:38 pm
A little unrelated to this topic.
But I'm trying to demux the blu-ray discs of westworld season 1 and 2.
But there's so many files on those discs.
How do I know which playlist contains a certain episode?
planet_hoarder
#2591 Post by planet_hoarder » Sun Jun 21, 2020 11:10 pm
shawnc22 wrote: Sun Jun 21, 2020 5:05 pm
Dolby's white paper says profile 4 needs two layers. yusecope tool combines two layers into one - BL+EL+RPU.hevc
even readme from latest broken mp4muxer says so:
           "To multiplex Dolby vision BL+EL+RPU file into a .mp4 file with EC-3 audio track:\n"
           "   mp4muxer -i ves_bl_el_rpu.265 -i audio.ec3 -o output.mp4 --dv-profile 8 \n"
           "            --dv-bl-compatible-id 2 --mpeg4-comp-brand mp42,iso6,isom,msdh,dby1 --overwrite \n"
           "   Note: For the Dolby vision profile 8, dv-bl-compatible-id is necessary. \n\n"
afaik, profile 4 and 7 (and dropped 6) needs second physical layer. At least when I create profile 4 from tsMuxer, it stutters on my LG OLED.
when I create profile 4,6 or 7 from old mp4muxer_64bit, plays perfectly.
when I create profile 8 from tsMuxer with output BL_EL_RPU.hevc from yusecope's tool - plays in DV on my TV.
too bad latest release of dolby's mp4muxer is faulty (created profile 8 plays in HDR), otherwise would have been a nice additional tool.
NOW. the biggest question is how to spot a difference between DV profiles (4,7,8) on the screen.
I wonder, if profile 8 is basically combined 4 and 6, with traces of 7 and older 2,3; then it is an ultimate DV profile for all. I just want to know if there is any difference.
planet_hoarder
#2592 Post by planet_hoarder » Sun Jun 21, 2020 11:12 pm
MastaG wrote: Sun Jun 21, 2020 8:38 pm A little unrelated to this topic.
try create mkv episodes using makemkv. otherwise, no idea
#2593 Post by shawnc22 » Sun Jun 21, 2020 11:37 pm
planet_hoarder wrote: Sun Jun 21, 2020 11:10 pm afaik, profile 4 and 7 (and dropped 6) needs second physical layer. At least when I create profile 4 from tsMuxer, it stutters on my LG OLED.
already have had this discussion once before:
https://makemkv.com/forum/viewtopic.php ... 165#p88345
and from one of the tsmuxer dev's:
https://makemkv.com/forum/viewtopic.php ... 180#p88398
planet_hoarder
#2594 Post by planet_hoarder » Mon Jun 22, 2020 6:11 am
shawnc22 wrote: Sun Jun 21, 2020 11:37 pm
yeah, the theory makes sense, but I'd like to know if there is a visual difference.
if the EL makes picture in 12 bit, then it's a waste, since no TV has 12 bit panel. Means BL+RPU is more than enough for Dolby Vison.
Also dolby's whitepaper says profile 8 is not finalized. Maybe that's why profile 8 with BL+EL+RPU works for LG internal player, when profile 5 doesn't work at all.
mp4muxer_64bit always creates mp4 two tracks BL and EL+RPU (at least for profile 4,6,7 that works on LG internal player), where EL+RPU gets the dolby vision profile and BL stays HDR10.
Maybe that's why mp4's in profile 5 is not working and profile 8 plays in HDR for me. I need to create them again and check MediaInfo.
box4m
#2595 Post by box4m » Mon Jun 22, 2020 3:44 pm
Weird question i guess but, anyone know of a player for androidtv/shield that can either playback 23.976p movies @ 24p, speed them up.
Or if you know of an application that could speedup the video and audio without stripping the DV data?
