It’s called a democracy my man!Woodstock wrote: Mon Jun 15, 2020 5:01 pm You know, it's a bit strange that we have one group desiring the removal of the speed restrictions, and another needing to limit speeds for reasons like available USB power or fragile media.
My BD copy of Last Starfighter has a section of the hub missing, but it survived 3 rips.
Libredrive version v6
jonghotti
Re: Libredrive version v6
Navvie
Between Christmas and new year in 2010 I destroyed a Pioneer DVD-RW drive (a DVR-116 or DVR-216, I think) after I removed the read speed limit with a program called Media Code Speed Edit.midnighwatcher wrote: Mon Jun 15, 2020 5:22 am Is it possible that the increased speeds could potentially destroy discs? I had a Bluray disc just literally explode in my LG drive into a million pieces. It had trouble reading the disc and was constantly adjusting the spin speed and then eventually heard a loud POP inside the drive like a gun after about an hour.
At the time, the read speed limit was to keep the drive quiet, with it removed it sure read discs a lot faster but sounded like a hair dryer. No, scrap that, it sounded like a lawn mower. After a couple of discs the drive literally went bang and wouldn't read any more discs. I replaced that drive with a Pioneer BDR-205 which I'm still using to this day.
Registered user
Linux / Windows 10
Asus BW-16D1HT 3.10MK (disc exploded, taking out my second BW-16D1HT)
Asus BC-12D2HT 3.11MK
LG BH16NS40 flashed to WH16NS60 1.03
LG GGC-H20L 1.03
Pioneer BDR-205 GENE
Linux / Windows 10
LG GGC-H20L 1.03
Ezatoka
with the BluRay White Snake I only could achieve a max speed of around 30.0 M/s [7.0x] at the biggest m2ts file with 30 GB
With what drive and firmware?
Ezatoka
Running an ASUS BW-16D1HT with MK firmware
Firmware version: 3.10
Unrestricted read speed: Yes-
Thanks. Always good to know what drive and firmware when results are posted. Hopefully it'll help Mike.
Grauhaar
The max speed has nothing to do with the size of a file. The place of the file on disc is important, on the inner place (near the hub) the max speed is approx 2x, on the outer place the max can be approx. 10x-12x. With one revolution (the RPM did not change) the inner place (very short) only less data can be read within the same time (one revolution) as on the outer place (much longer) a lot of more data can be read. So the 7x are normal, on some discs with read trouble, the drive can slow down the rate to 2x or less for the complete rip.Ezatoka wrote: Sat Jun 20, 2020 10:28 pm I only could achieve a max speed of around 30.0 M/s [7.0x] at the biggest m2ts file with 30 GB
Good Luck
Ezatoka
Certainly I noticed on several disks already that the speed is going down again when the rip comes near the end of the current file. Like it's max speed between 75 and 85%, then it gets slower again.
Ezatoka
hmm how about an opt-in possibility in the options to automatically submit the Metadata of the Drive model, current firmware and the max speed which could be achieved on a disk? Of course wouldn't need any serial number or anything, nor the name of the disk.SamuriHL wrote: Sun Jun 21, 2020 11:16 am Thanks. Always good to know what drive and firmware when results are posted. Hopefully it'll help Mike.
Honestly I think Mike only really needs to know when things aren't working quite right. Or perceived to not be working right. In those cases where people are replying to this thread that "hey, I see X" adding the model drive and firmware should be sufficient and useful.
Ezatoka
Then maybe just a "Max speed" at the display/in the log after ripping.
Nobody59
Some personal experiences with LibreDrive Microcodes and MakeMKV 1.15.1 since the last 3 months:
Using ASUS BW-16D1HT bought in December 2019 with MK Patched Firmware 3.10. I use for testing always the same old (but clean)
Blu-ray Disc in order to obtain comparable results. Operating System is windows 7 32 Bit. SATA II is switched to native IDE mode.
With sdf_06d.bin: Blu-ray Copy (38,72 GB) = 28:19 Minutes (Peak Read 7.5x)
With sdf_070.bin: Blu-ray Copy (38,72 GB) = 19:11 Minutes (Peak Read 11.1x = ~48,2 M/s)
with sdf_071.bin: Blu-ray Copy (38,72 GB) = 28:48 Minutes (Peak Read 7.5x)
with sdf_072.bin: Blu-ray Copy (38,72 GB) = 28:42 Minutes (Peak Read 7.6x)
It seems that the Microcodes after sdf_70.bin currently no longer work properly for me in terms of speed.
Yes. They (SDF v70+) have a very fine speed control, but you would need MakeMKV 1.15.2 to use it. By default the drive speed is not touched. Starting with 1.15.2, MakeMKV controls speed settings per drive and media type. You would be able to set something like unlimited speed for single-layer BD, medium speed for double-layer BD and "do not touch" for UHD media. Or set a global maximum speed for your power-hungry USB drive. Different policies for different drives and media.Nobody59 wrote: Sun Jun 21, 2020 9:48 pmIt seems that the Microcodes after sdf_70.bin currently no longer work properly for me in terms of speed.
Just wait for 1.15.2 .
The default "set max speed" policy is gone from LibreDrive microcode.
Sounds good!!mike admin wrote: Sun Jun 21, 2020 10:13 pmYes. They (SDF v70+) have a very fine speed control, but you would need MakeMKV 1.15.2 to use it. By default the drive speed is not touched. Starting with 1.15.2, MakeMKV controls speed settings per drive and media type. You would be able to set something like unlimited speed for single-layer BD, medium speed for double-layer BD and "do not touch" for UHD media. Or set a global maximum speed for your power-hungry USB drive. Different policies for different drives and media.Nobody59 wrote: Sun Jun 21, 2020 9:48 pmIt seems that the Microcodes after sdf_70.bin currently no longer work properly for me in terms of speed.
diverderf
I am having the same issues with the Win10 OS not recognizing my BD drive after starting MakeMKV. I noticed the change happened after it updated the SDF file on 6/19. I ended up having to uninstall and then reinstall MakeMKV, and set the auto-update setting to not update.MrVanx wrote: Sun Jun 14, 2020 9:27 pmYep I get a similar result with my UH12NS30 also:rerunsorted wrote: Fri Jun 12, 2020 4:29 amUsing v6 causes my OS to drop the drive when attempting to decrypt the disc causing MakeMKV to also crash.Code: Select all
Drive Information OS device name: E: Current profile: BD-ROM Manufacturer: HL-DT-ST Product: BDDVDRW UH12NS30 Revision: 1.02 Serial number: K9LE9OD4329 Firmware date: 2114-03-26 11:41 Bus encryption flags: 16 Highest AACS version: 68
I get the 'OS error - This device does not exist' error until MakeMKV crashes. I then have to power off the PC before the drive is recognized again.
My drive was originally Revision 1.03. I tried flashing down to 1.02 to see if that would resolve the issue but it didn't.
I've tried 3 discs, all Blu-ray. They were Onward, Frozen 2 and Jumanji 2. All had the same behavior after tried to decrypt and all discs were able to be ripped when not using LibreDrive v6.
I left makemkv whirring away for a bit (attempting to open a BD disc) and it eventually gave me an error (fatal error?).Code: Select all
OS device name: /dev/sr0 Current profile: BD-ROM Manufacturer: HL-DT-ST Product: BDDVDRW UH12NS30 Revision: 1.03 Serial number: K9MEA8F2118 Firmware date: 2114-04-24 19:00 Bus encryption flags: 16 Highest AACS version: 71
anyways I have reverted back so I can rip a disc but please see attached my log file which might be of some help?
FYI the disc I was attempting to open in the log worked just fine after reverting back to 1.15.1 (linux), libredrive status returned to "Status: Possible, not yet enabled".
Cheers.
OS device name: E:
Revision: 1.03
Serial number: K9LEA8E3013
Highest AACS version: 65
