jlpsvk
#2581 Post by jlpsvk » Tue Jun 16, 2020 9:00 pm
any special settings to encode BL??? yousesope's tools offen hangs when muxing encoded BL with EL. :(
box4m
#2582 Post by box4m » Thu Jun 18, 2020 4:24 am
Btw, how do u know if a movie is in FEL or MEL? I know theres lists bluray forum, but if u didnt have that?
planet_hoarder
#2583 Post by planet_hoarder » Thu Jun 18, 2020 11:40 am
you check bitrate of the EL, below 2.2Mbps is MEL, everything above is FEL.
box4m
#2584 Post by box4m » Thu Jun 18, 2020 1:17 pm
and how do u check bitrate? mediainfo doesnt tell me
Gauvin 139
#2585 Post by Gauvin 139 » Thu Jun 18, 2020 6:01 pm
Hello. First of all thank you for your work. Sorry for my bad english but i am french.
For yusesope, how did you get the file
Joker BL_RPU raw HEVC (my program - second version - identical to that of DVDFab)
Joker_dvhe.05.06_BL_RPU_Single_Track_Single_Layer
because it works well on my ATV4k combo, Infuse; Sony TV.
I have a little trouble understanding everything because I work with a google translator and there are many versions of different programs. I tried several times to make a version of Gemini Man with DV, but it still plays with HDR10 on my combo
Thank you
planet_hoarder
#2586 Post by planet_hoarder » Thu Jun 18, 2020 8:41 pm
what do you mean mediainfo doesn't tell?
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Duration                                 : 1 h 57 min
Bit rate                                 : 81.0 Mb/s
Frame rate                               : 59.940 (60000/1001) FPS
Bits/(Pixel*Frame)                       : 0.163
Stream size                              : 66.2 GiB (83%)
Title                                    : Gemini.Man.2019.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT
Mastering display luminance              : min: 0.0010 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 5180 cd/m2
Maximum Frame-Average Light Level        : 1577 cd/m2
Video #2
Bit rate                                 : 2 684 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Bits/(Pixel*Frame)                       : 0.022
Stream size                              : 2.19 GiB (3%)
BL Bitrate - 81Mb/s
EL Bitrate - 2 684 kb/s
Edit: My bad, this was dremuxed version... on the Disk it doesn't show, you are correct. Make an MKV remux and check the MediaInfo.
Last edited by planet_hoarder on Thu Jun 18, 2020 8:52 pm, edited 2 times in total.
#2587 Post by RESET_9999 » Thu Jun 18, 2020 8:47 pm
mediainfo doesnt say the bitrate when it's an original m2ts file.
But you can demux it and check the file size. MEL are smaller than 100mb and i've seen 8gb FEL.
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 16.7 GiB
Duration                                 : 53 min 35 s
Overall bit rate                         : 44.6 Mb/s
Maximum Overall bit rate                 : 109 Mb/s
Video #1
Maximum Frame-Average Light Level        : 644 cd/m2
Video #2
flashback8
#2588 Post by flashback8 » Thu Jun 18, 2020 9:20 pm
On a related note, it looks like Nvidia 2019 Shield Pros are finally getting restocked. Just ordered one from B&H, and it looks like Newegg and Amazon have them too. Hurry if you want one too!
Alldu
#2589 Post by Alldu » Thu Jun 18, 2020 11:18 pm
Some weird stuff here. So I created an m2ts DV file of Schindler's List with the edited tsMuxer, and everything is cool... except that my Sony X700 somehow refuses to fast forward it or rewind! It just says - this operation is prohibited. Anybody encountered the same anomaly? I did many DV titles, but this is the first time I see something like this. What could that be? Maybe because the movie is over 3 hours? Or the file is 97Gb? What gives?
box4m
#2590 Post by box4m » Sun Jun 21, 2020 9:08 am
when using mp4muxer, initially it uses abit of cpu and disk i/o, but then it seems to do nothing for forever until its done?
i have 3900x @ 4,25GHz and pci-e 4.0 disk so it should not take forever, what is it doing? can i enable logs?
edit: instead of making another post i got another question:
1) demux BL+EL with tsMuxer (04.06 fix)) (that has worked well for me every time without mp4box)
2) demux TrueHD audio "ffmpeg.exe -i bluray:path/to/bluray -map 0:AUDIO_STREAM -c:a copy -strict -2 X:\atmos.mp4"
3) run yusecope tool with BL+EL only -mode 1
4) "mp4muxer_64bits.exe --dv-profile 4 --input-file "step3_output.hevc" --media-lang eng --output-file X:\mp4muxer_output_only_video.mp4"
5) "mp4box.exe -add X:\step4_output.mp4 -add X:\step2_output.mp4:lang=eng -brand mp42isom -ab dby1 X:\mp4box_out.mp4 -tmp X:\"
this file does not play with mxplayer on 2019 shield, i get "cant play file", with plex i get HDR10 only and weird behaviour, cant fastforward etc
What gives?
planet_hoarder
#2591 Post by planet_hoarder » Sun Jun 21, 2020 1:40 pm
What gives?
your powerful CPU means nothing if program uses only one thread. Since it is run from CMD, then most probably it is.
AFAIK you can create an mp4 with TrueHD, but I am not sure any existent player can play TrueHD from mp4. That's why people are using tsMuxer to mix output from yusecope's tool and TrueHD+Atmos.
try to create a profile 8, that should work on Shield TV.
box4m
#2592 Post by box4m » Sun Jun 21, 2020 2:10 pm
What gives?
I will try profile 8 thanks.
Regarding only using one thread, ye maybe, but its called mp4muxer_64bit
edit: where can i read about the profiles btw? dolby seems to have removed the pdf?
#2593 Post by shawnc22 » Sun Jun 21, 2020 2:45 pm
What gives?
Why are you doing all of this if you have a shield? Also profile 8 is a single layer DV profile that has no EL support.
box4m
#2594 Post by box4m » Sun Jun 21, 2020 4:14 pm
What gives?
what should i be doing?
i didnt get m2ts or ts working with mxplayer
planet_hoarder
#2595 Post by planet_hoarder » Sun Jun 21, 2020 4:46 pm
What gives?
they didn't remove it, just changed the location:
https://professional.dolby.com/siteasse ... _09_16.pdf
yes, it is called xxx_64bit, but not xxx_64bit_mutithread. Two completely different things.
also for shield, you don't need to use Dolby's mp4muxer.
you can use your tsMuxer (04.06 fix). put output of yusecope's tool there and add sound, that's it.
for profile 8 you can try nightly release tsMuxer from 16-th March 2020.
https://bintray.com/justdan96/tsMuxer/t ... 1-36#files
