Memento BluRay
muctur
Memento BluRay
#1 Post by muctur » Wed Nov 24, 2010 9:22 pm
When I rip the Memento BluRay with only the LPCM track selected for audio, the audio will not play in any media player (mplayer, VLC).
I want to keep the uncompressed audio track only.
Anyone have any suggestions?
I am currently using MakeMKV v1.6.2 for Mac.
Re: Memento BluRay
#2 Post by mike admin » Sat Nov 27, 2010 9:56 am
A well known player limitations for multi-channel LPCM audio. You can use mkvextract or eac3to to extract audio track from MKV and then encode it to FLAC. Most players handle FLAC better than multi-channel LPCM.
muctur
Re: Memento BluRay
#3 Post by muctur » Tue Nov 30, 2010 7:58 am
What is the best option for conversion to keep it uncompressed, but push it bitstream to a receiver?
skittle
Re: Memento BluRay
#4 Post by skittle » Tue Nov 30, 2010 8:32 am
Only thing that can send multi channel lpcm is hdmi cable (coax and optical only support 2 channel lpcm)... so if your playback device and receiver support hdmi and multi lpcm your good to go ;)
Otherwise your SOL as far as uncompressed lpcm.
muctur
Re: Memento BluRay
#5 Post by muctur » Tue Nov 30, 2010 8:35 am
Ok.
So if I need to convert it, but want it to play in VLC, is there anyway to retain an uncompressed version of the audio?
Re: Memento BluRay
#6 Post by mike admin » Tue Nov 30, 2010 11:21 am
Yes, convert to FLAC - you'll get compressed but lossless audio.
muctur
Re: Memento BluRay
#7 Post by muctur » Wed Dec 01, 2010 1:51 am
Ok. What programs for Snow Leopard would be able to do that?
tsMuxer only works on Leopard. I just want to covert the audio then re-encode it into one file, if possible.
skittle
Re: Memento BluRay
#8 Post by skittle » Wed Dec 01, 2010 3:08 am
http://flac.sourceforge.net/download.html
macflac looks like a easy gui ;) or just use flac (download flac encoder binary first) from command line:
$flac input.wav
