BD Drive won't rip DVD or Blu-rays all of a sudden
Re: BD Drive won't rip DVD or Blu-rays all of a sudden
#16 Post by mike admin » Sat Jun 20, 2020 9:38 pm
Ok, guys. Seems all of you have something in common:
Non-MK firmware
Windows
Internal (non-usb) dirive
Some specific (same for all of you) SATA controller.
If you can post details about your SATA controller, this will help. No worries if you can't get this info.
Should have a test version in about an hour, please check this topic.
Penfold82
#17 Post by Penfold82 » Sat Jun 20, 2020 10:03 pm
Not sure if this is the info your after.
Got it from Hwinfo.
 Intel ICH10 - SATA 4-port Controller [A0]
Penfold82
#18 Post by Penfold82 » Sat Jun 20, 2020 10:46 pm
Got it to work. found that my bios was set to IDE instead of AHCI.
Change this in BIOS and now working fine.
If you get inaccessible boot drive after changing bios setting, like I did, try the following.
1. Run Command Prompt as Admin
2. Invoke a Safe Mode boot with the command: bcdedit /set {current} safeboot minimal
3. Restart the PC and enter your BIOS during bootup.
4. Change from IDE to AHCI mode then Save & Exit.
5. Windows 10 will launch in Safe Mode.
6. Right click the Window icon and select to run the Command Prompt in Admin mode from among the various options.
7. Cancel Safe Mode booting with the command: bcdedit /deletevalue {current} safeboot
8. Restart your PC once more and this time it will boot up normally but with AHCI mode activated.
#19 Post by mike admin » Sat Jun 20, 2020 11:03 pm
Just pushed the update, should be working now. Likely, just a reboot would be sufficient.
morty423
#20 Post by morty423 » Sat Jun 20, 2020 11:10 pm
mike admin wrote: Sat Jun 20, 2020 11:03 pm Just pushed the update, should be working now. Likely, just a reboot would be sufficient.
It is now working again for me. Thank you!
paraw
#21 Post by paraw » Sun Jun 21, 2020 12:07 am
Still not working for me. The drive is an ASUS BC-12D2HT. I'm on Linux (Gentoo). The switch on/switch off did not change anything. According to lspci, the SATA controller is an Intel 6 Series/C200 Series Chipset Family 6 port Desktop SATA AHCI Controller (rev 05) (prog-if 01 [AHCI 1.0]).
beblank1us
#22 Post by beblank1us » Sun Jun 21, 2020 3:11 am
After powering off/on this is also still not working for me and I am stuck on the decrypting stage. Attached are my drive details and I am running on Windows.
Drive info.png (1.66 KiB) Viewed 37333 times
#23 Post by mike admin » Sun Jun 21, 2020 7:43 am
beblank1us wrote: Sun Jun 21, 2020 3:11 amAfter powering off/on this is also still not working for me and I am stuck on the decrypting stage. Attached are my drive details and I am running on Windows.
Do you have SDF v72? Please post the log file.
If you don't know how to do this, there is another option - navigate to the MakeMKV data directory (usually C:\Users\yourname\.MakeMKV) and delete the file _private_data.tar from there. Then reboot (if the drive is stuck).
#24 Post by mike admin » Sun Jun 21, 2020 7:45 am
paraw wrote: Sun Jun 21, 2020 12:07 am Still not working for me. The drive is an ASUS BC-12D2HT. I'm on Linux (Gentoo). The switch on/switch off did not change anything. According to lspci, the SATA controller is an Intel 6 Series/C200 Series Chipset Family 6 port Desktop SATA AHCI Controller (rev 05) (prog-if 01 [AHCI 1.0]).
Same question for you - do you have sdf v72? If unsure, do the following:
rm ~/.MakeMKV/_private_data.tar
reboot
paraw
#25 Post by paraw » Sun Jun 21, 2020 8:06 am
Deleted _private_data.tar. Now, it won't even try opening some discs (which were previously working), whereas with some others, I get
Debug log started at Sun Jun 21 07:55:45 2020 , written by MakeMKV v1.15.1 linux(x64-release)
001005:0000 MakeMKV v1.15.1 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/paraw/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at Fi:8.YS^z0_#RDnJ/Oz 3Q:29393631
001003:0020 DEBUG: Code 0 at 0DqdsUZ)*@R^v:>2:121275849
SDF  v06d: ASUS_BC-12D2HT_1.00_211306141200_K9BF3KA4840
003338:0000 Downloading latest SDF to /home/paraw/.MakeMKV ...
SDF  v072: ASUS_BC-12D2HT_1.00_211306141200_K9BF3KA4840
001003:0020 DEBUG: Code 4 at DF&6y_c@adL4<MeV(d%L:29394367
001003:0020 DEBUG: Code 2399228161 at !Ko|V6~1>:Q>[Nj2M:213132399
DEBUG: Code 0 at !Ko|V6~1>:Q>[Nj2M:213132215
001003:0020 DEBUG: Code 2399203585 at !Ko|V6~1>:Q>[Nj2M:213132399
DEBUG: Code 1 at !Ko|V6~1>:Q>[Nj2M:213132215
DEBUG: Code 2 at !Ko|V6~1>:Q>[Nj2M:213132215
DEBUG: Code 3 at !Ko|V6~1>:Q>[Nj2M:213132215
DEBUG: Code 4 at !Ko|V6~1>:Q>[Nj2M:213132215
DEBUG: Code 5 at !Ko|V6~1>:Q>[Nj2M:213132215
DEBUG: Code 0 at !Ko|V6~1>:Q>[Nj2M:213132031
DEBUG: Code 0 at 0DqdsUZ)*@R^v:>2:213141599
DEBUG: Code 0 at Y"1_`~gBhucQ>oW*:29401014
001003:0020 DEBUG: Code 117637252 at OBJTKgMeJzd_yf]y:213130559
001003:0020 DEBUG: Code 117637252 at 59\D5CLED~UVu32XvH:213131778
001003:0020 DEBUG: Code 117637252 at 59\D5CLED~UVu32XvH:121261934
002003:0000 Error 'Internal error - Operation result is incorrect (132)' occurred while reading '/BDMV/STREAM/00347.m2ts' at offset '1280845824'
The last block (from 001003:0020 DEBUG Code 4 to Internal error) then repeats several times, before a popup informs me that MakeMKV encountered a serious error and will now close.
ictbydesign
#26 Post by ictbydesign » Sun Jun 21, 2020 8:36 am
Thanks Mike,
Power off and then on again worked for me.
ictbydesign
#27 Post by ictbydesign » Sun Jun 21, 2020 9:45 am
Just noticed now that after the backup is complete Error Code: 233 appears about 5 times. Never seen this before so not sure if it is related.
MrVanx
#28 Post by MrVanx » Sun Jun 21, 2020 10:42 am
Hi Mike,
I just re-enabled webserver updates to get the latest sdf, still no joy here. I get the same behaviour as in my earlier post.
drive details:
OS device name: /dev/sr0
Product: BDDVDRW UH12NS30
Revision: 1.03
Serial number: K9MEA8F2118
Firmware date: 2114-04-24 19:00
Bus encryption flags: 16
Highest AACS version: 63
Drive platform: MT1939
Firmware version: 1.03
BD raw metadata read: Partial
OS: Linux mint 19.3
Please see attached log file and also the output of lspci for my SATA details.
All the best.
outputOfLspci.txt
(2.52 KiB) Downloaded 1336 times
MakeMKV_log (another copy).txt
(493.79 KiB) Downloaded 1411 times
Gingerwig
#29 Post by Gingerwig » Sun Jun 21, 2020 11:11 am
Hi Mike
I am also having the same problem. DVD and BD discs start, hang on Using direct disc access mode and then the drive dismounts and MakeMKV crashes with fatal error.
OS: WIndows 10
Drive: Internal Sata
OS device name: E:
Revision: 1.00
Serial number: K9F21175123
Firmware date: 2113-06-13 14:57
Highest AACS version: 72
Firmware version: 1.00
I've tried deleting _private_data.tar and restarting but no joy.
Thanks for the great software.
Ginge
MakeMKV_log.txt
(137.45 KiB) Downloaded 1378 times
#30 Post by mike admin » Sun Jun 21, 2020 11:32 am
Ok, I never seen such SATA controller, trying to fix the code...
Hopefully will have an update in a few hours.
Meanwhile, here are instructions for workaround.
LibreDrive has an "emergency brake" feature that allows one to disable it completely for a specific drive, to make sure LibreDrive code does not touch drive firmware at all.
It was designed to be used as a last resort, for cases like this.
To disable the LibreDrive for a drive, first get your drive ID. This can be done using "makemkvcon -f --list" or by looking at the log file
SDF  v072: HL-DT-ST_BDDVDRW_UH12NS30_1.03_211404241900_K9MEA8F2118
In this example "HL-DT-ST_BDDVDRW_UH12NS30_1.03_211404241900_K9MEA8F2118" is a (unique) drive ID.
There are two ways to disable LibreDrive for a drive - by adding Sdf_stop line to a MakeMKV config file
Sdf_stop = "HL-DT-ST_BDDVDRW_UH12NS30_1.03_211404241900_K9MEA8F2118"
or by setting an SDF_STOP environment variable
SDF_STOP=HL-DT-ST_BDDVDRW_UH12NS30_1.03_211404241900_K9MEA8F2118 makemkv
either way the drive will not be touched by (presently buggy) LibreDrive code. If you have more than one drive, both options take a list of space-separated Drive Ids.
This way you do not need to disable updates or meddle with tar files.
