How to MKV Cars BD?
leftheaded
How to MKV Cars BD?
Has anyone been able to create a MKV from the Cars Blu-ray? Mine isn't working - the audio is jittery. And after some searching it seems this might be a disc that cannot be made into a MKV. Anyone?
crowfax
Re: How to MKV Cars BD?
MakeMKV does nothing to alter the audio track. The issue most likely lays with your choice of media player.
servocrow
if you are trying to run it through Windows MEdia player then try another player, i.e. Splayer or Splash Lite.
if you get the same result then try re-ripping the BR with another app , like DVDFAB HD Decryptor, then convert to mkv with MAKEMKV
- Contact:
This issue has nothing to do with a decryption.servocrow wrote:if you get the same result then try re-ripping the BR with another app , like DVDFAB HD Decryptor, then convert to mkv with MAKEMKV
