Sudden error
paraw
Sudden error
Post by paraw »
Hi all, up to yesterday I was able to play any blu-ray, but from tonight nothing works anymore. I tried all I could think of, but I can't figure out what is going on. The drive is an ASUS BC-12D2HT. The debug log contains the following messages:
Debug log started at Sat Jun 20 23:07:13 2020 , written by MakeMKV v1.15.1 linux(x64-release)
001005:0000 MakeMKV v1.15.1 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/paraw/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at Fi:8.YS^z0_#RDnJ/Oz 3Q:29393631
001003:0020 DEBUG: Code 0 at 0DqdsUZ)*@R^v:>2:121275849
SDF  v071: ASUS_BC-12D2HT_1.00_211306141200_K9BF3KA4840
003338:0000 Downloading latest SDF to /home/paraw/.MakeMKV ...
SDF  v072: ASUS_BC-12D2HT_1.00_211306141200_K9BF3KA4840
csf8=1
csf6
001003:0020 DEBUG: Code 4 at DF&6y_c@adL4<MeV(d%L:29394367
001003:0020 DEBUG: Code 2399228161 at !Ko|V6~1>:Q>[Nj2M:213132399
DEBUG: Code 0 at !Ko|V6~1>:Q>[Nj2M:213132215
001003:0020 DEBUG: Code 2399203585 at !Ko|V6~1>:Q>[Nj2M:213132399
DEBUG: Code 1 at !Ko|V6~1>:Q>[Nj2M:213132215
DEBUG: Code 2 at !Ko|V6~1>:Q>[Nj2M:213132215
DEBUG: Code 3 at !Ko|V6~1>:Q>[Nj2M:213132215
DEBUG: Code 4 at !Ko|V6~1>:Q>[Nj2M:213132215
DEBUG: Code 5 at !Ko|V6~1>:Q>[Nj2M:213132215
DEBUG: Code 0 at !Ko|V6~1>:Q>[Nj2M:213132031
DEBUG: Code 0 at 0DqdsUZ)*@R^v:>2:213141599
DEBUG: Code 0 at Y"1_`~gBhucQ>oW*:29401014
001003:0020 DEBUG: Code 117637252 at OBJTKgMeJzd_yf]y:213130559
001003:0020 DEBUG: Code 117637252 at 59\D5CLED~UVu32XvH:213131778
001003:0020 DEBUG: Code 117637252 at 59\D5CLED~UVu32XvH:121261934
002003:0000 Error 'Internal error - Operation result is incorrect (132)' occurred while reading '/BDMV/STREAM/00274.m2ts' at offset '48787605504'
002003:0000 Error 'Internal error - Operation result is incorrect (132)' occurred while reading '/BDMV/STREAM/00274.m2ts' at offset '15239387136'
and so on. After that, the drive is completely blocked, to the point that even to just eject the disk, I have to turn off the computer and turn it on again (a simple reboot won't do, and the eject command just doesn't work). The strangest thing, as I wrote above, is that up to yesterday, everything was working fine. Note that DVDs still work, if this information is of any use. Anyone has any suggestion on what I could do? :(
Re: Sudden error
Post by mike admin »
