UHD/HDR Menu Problems with VLC/MakeMKV
dougiefresh578
Post by dougiefresh578 »
I know this might not be the correct forum to post this issue to, but I tried the VLC forum and got no responses.
I was able to get Ultra HD Blu-Ray Discs working using VLC/MakeMKV and I even downloaded Java so the Menus can show up, and everything seems to be working fine, except one problem. If I turn on HDR in my Windows Settings, the Menu Options (Play/Scenes/Set Up/Extras) will still work like normal but they will not be visible or incredibly dark. If I play those same UHD BD Discs with HDR turned off, then the menu options will look normal. Everything else (Home Entertainment logo, Warning Screens, Movie, Menu Audio) will play normally in both HDR and SDR, the problem is with the actual Menu options themselves. I am wondering how I can get the Menus to show up normally when I have HDR turned on. Maybe I don't have a certain Codec that would fix this or its maybe something in settings I couldn't find.
What it looks like: https://imgur.com/a/1n0WYRN
Re: UHD/HDR Menu Problems with VLC/MakeMKV
They must have added support for UHD menus you used to have to disable menus for UHD discs to work I guess they have some work left I would just turn menus off for now
Also this is a vlc problem not makemkv
