Does it convert - transform truehd into ac3??
grigoris
Post by grigoris » Wed Jun 17, 2020 4:57 am
Can this program convert truehd mkv or blueray into simple ac3 surround???
Re: Does it convert - transform truehd into ac3??
Post by Woodstock » Wed Jun 17, 2020 12:33 pm
Generally speaking, when MakeMKV encounters a TrueHD track, it will give you both the "complete" TrueHD track, and extract the "lossy core" AC3 track.
grigoris
Post by grigoris » Wed Jun 17, 2020 12:55 pm
How exactly i choose to convert one truehd sound of an mkv file into ac3 loseless?
And make change only at audio nothing else.
I try a sample of one mkv file that has one truehd sound that was only 1 minute long and the program it make more than 20-30 minutes and still doesn't end so i stop it.
So are you completely sure that this program can convert truehd into ac3 loseless????
Post by Woodstock » Wed Jun 17, 2020 2:56 pm
AC3 is not a lossless format, so it is impossible to convert to it losslessly.
But a TrueHD track contains AC3 data within it, so MakeMKV simply copies that part of the track out as a separate track for decoders that aren't smart enough to do that on their own.
grigoris
Post by grigoris » Sat Jun 20, 2020 1:09 am
And why even a video file 1 minute lenth-long is SO REALLY LATE to do it????
And as i tallied you before i STOP IT BEFORE IT COMPLETED CAUSE IT WOULD TAKE TOOOOOOOO LONG FOR 1 MINUTE VIDEO FILE.
bmillham
Post by bmillham » Sat Jun 20, 2020 2:04 am
A 1 minute file should not take long at all to rip. If it's taking that long for you then either you have a dirty/damaged disc, or your drive is defective. The audio format makes no difference as it's just copying the tracks without change.
grigoris
Post by grigoris » Sat Jun 20, 2020 2:45 am
For beggining LEARN TO READ BEFORE YOU ANSWER.
NEVER SAY I RIP A BLURAY. NEVER.
READ AND THEN ANSWER.
bmillham
Post by bmillham » Sat Jun 20, 2020 2:55 am
Wow, you are a rude one.
I guess you don't understand what MakeMKV is for. It's for Ripping DVD/BD's, not for transcoding MKVs.
Also, I'd suggest that you read your post. I quote you here:
That reads to me as ripping a bluray.
grigoris
Post by grigoris » Thu Jun 25, 2020 6:14 pm
I know VERY WELL what the program is for.
But i know that can convert truehd audio into ac3 to as describe at the program characteristics.
So.....
