Usually, when cancelling, at least after decryption is done, it cancels immediately. Sometimes, however, it takes a while, seeming unresponsive. In these cases, it sometimes cancels properly, but usually it doesn't, and instead becomes completely unresponsive before crashing. I'm not sure, but clicking the cancel button again, due to the cancellation seeming to be stuck, might increase the risk of it crashing, though it isn't necessary to cause it.
I got this error in the log when it took a while to cancel but ended up successfully doing so:
Error 'Internal error - Operation was cancelled (65)' occurred while issuing SCSI command 4602010D0..010 to device 'SPTI:\Device\CdRom0'
Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your driveCode: Select all
Error 'Internal error - Operation was cancelled (122)' occurred while reading '/AACS/MKB_RO.inf' at offset '20'
Error 'Internal error - Operation was cancelled (122)' occurred while reading '/AACS/MKB_RO.inf' at offset '244'
Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your driveIt also says "Using LibreDrive mode (v06 id=94DE7D3D0ADE)" though I'm guessing that's pretty standard stuff, but might be important for debugging.
Let me know if I can provide any more info. This is on Win10x64, version 1.15.1.
