In a future release, do you intend to add the possibility to use a .SRT sourcefile in order to directly mux it into the target .mkv file ? It will avoid to use right after MakeMkv MkvMerge to finilize the convertion (obviously, when you need subtitles).
Thanks !
Subtitles in SRT format
- Contact:
Re: Subtitles in SRT format
This is a nice feature to have, hovewer I doubt it will be implemented anytme soon. Sorry.
thisisalexandre
No problem... Anyway, it is a workaround since no multimedia player can handle at the moment PGS subsitles ! When it will be the case, MakeMkv will be a self standing product.
