Did I brick my Buffalo BRXL-PT6U2VB?
cdemi
Post by cdemi »
I have bought the Buffalo BRXL-PT6U2VB EU External Drive.
I have managed to flash
ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
and now my drive shows as:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: 3.10
Serial number: MZFK1IF4404
Bus encryption flags: 1F
Firmware version: 3.10
However the discs are still not being read. As I understood, I need to flash either
HL-DT-ST-BD-RE_BU40N-1.02-NM01201-211711301218
or
HL-DT-ST-BD-RE_BU40N-BN11-0M00300-211711201351
but both are giving me
Updating Failure #5
I am using the following pack:
(Modified) ASUS ODD FW Changer (24.08.2019) + UHD Friendly Firmwares  + Latest MK Pack (15.04.2020)
Re: Did I brick my Buffalo BRXL-PT6U2VB?
cdemi wrote: Wed Jun 17, 2020 10:43 pm I have bought the Buffalo BRXL-PT6U2VB EU External Drive.
Revision: 3.10
or
Updating Failure #5
Yes it's bricked
I really don't get it I post the way not to brick your drive and you do it anyway.
Read cross flash warnings
https://makemkv.com/forum/viewtopic.php?f=16&t=19634
The only way to fix is now is to take the drive apart and use dosflash with a direct sata connection in ide mode
jonghotti
Post by jonghotti »
Revision: 3.10
or
Updating Failure #5
You sure did. What possessed you to choose the ASUS firmware to load on a slim LG drive?
