Mortal Engines
Saici
Mortal Engines
Post by Saici »
unfortunately I'm unable to makeMKV/backup "Mortal Engines" UHD Bluray.
I did try multiple discs to no avail, running MakeMKV v1.15.1 with the latest hashed keys.
I did try switching my drive from a USB-adapter to SATA (connected directly to the motherboard, PSU)
Did multiple tries of waiting for the disc to stop spinning, starting immediately after putting it in,
also updated the FW from 3.01 to 3.10MK since I figured usually updated firmwares improve things after not succeeding on multiple discs on Rev 3.01.
Drive data:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: ##############
Bus encryption flags: 1F
Highest AACS version: 72
Firmware version: 3.10
Disc Information
Label: MORTAL_ENGINES
Timestamp: 2019###########
Data capacity: 82.43 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Backup error:
Backing up disc into folder "MORTAL_ENGINES"
Evaluation version, evaluation period expired 15 day(s) ago
Using LibreDrive mode (v05 id=0FA242DD4D0B)
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10' at offset '66722805760'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/AACS/Content001.cer' at offset '0'
Encountered 1 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Backup failed
Saici
Re: Mortal Engines
Post by Saici »
MakeMKV log:
MakeMKV v1.15.1 win(x64-release) started
Using Java runtime from C:\Program Files\AdoptOpenJDK\jre-8.0.222.10-hotspot\bin\java.exe
Saving 1 titles into directory
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '33214562304'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '33214562304'
Failed to save title 0 to file Mortal Engines-SEG_MainFeature_t00.mkv
0 titles saved, 1 failed
