Blues Brothers UK version
charlie62
Post by charlie62 » Mon Jun 15, 2020 6:05 pm
Just sent the dump file for Blues Brothers UK version to Mike !
charlie62
Re: Blues Brothers UK version
Post by charlie62 » Tue Jun 16, 2020 4:14 pm
I don't know if Mike has put up a key for this, when I tried about an hour ago it was still the same, no key etc. So I decided to use Fab and it told me that there was write/errors on the disc Would this cause Makemkv to think the it didn't have a new key. Hope someone can help !
HayItzDatGuy
Post by HayItzDatGuy » Tue Jun 16, 2020 5:15 pm
No key just yet.
I went the full backup option without an issue. Just have to wait for the key to be made available so I can open the backup.
I'll assume it will either read it or it won't - if it won't, you will see other errors before you get any messages about the key being unavailable.
charlie62
Post by charlie62 » Tue Jun 16, 2020 6:13 pm
Thanks for that makes you feel your not on your own, it's just this covid, after 3 month I get more than a little paranoid
charlie62
Post by charlie62 » Tue Jun 16, 2020 10:18 pm
This disc has been returned as faulty thanks anyway
HayItzDatGuy
Post by HayItzDatGuy » Thu Jun 18, 2020 10:12 am
It's working now.
ns01-2017
Post by ns01-2017 » Fri Jun 19, 2020 11:06 am
There's two versions of the film with seemless branching, it's picking up the first version (Theatrical cut), but the longer chapters that are part of the longer cut are just being picked up a seperate files rather than stitching together to create the film.
ns01-2017
Post by ns01-2017 » Sat Jun 20, 2020 9:35 am
Working for both versions now.
