Blues Brothers UK version
charlie62
Post by charlie62 »
Just sent the dump file for Blues Brothers UK version to Mike !
charlie62
Re: Blues Brothers UK version
Post by charlie62 »
I don't know if Mike has put up a key for this, when I tried about an hour ago it was still the same, no key etc. So I decided to use Fab and it told me that there was write/errors on the disc Would this cause Makemkv to think the it didn't have a new key. Hope someone can help !
HayItzDatGuy
Post by HayItzDatGuy »
No key just yet.
I went the full backup option without an issue. Just have to wait for the key to be made available so I can open the backup.
I'll assume it will either read it or it won't - if it won't, you will see other errors before you get any messages about the key being unavailable.
charlie62
Post by charlie62 »
Thanks for that makes you feel your not on your own, it's just this covid, after 3 month I get more than a little paranoid
charlie62
Post by charlie62 »
This disc has been returned as faulty thanks anyway
HayItzDatGuy
It's working now.
ns01-2017
Post by ns01-2017 »
There's two versions of the film with seemless branching, it's picking up the first version (Theatrical cut), but the longer chapters that are part of the longer cut are just being picked up a seperate files rather than stitching together to create the film.
ns01-2017
Post by ns01-2017 »
Working for both versions now.
