#23
Post
by peervh » Sat Nov 27, 2010 2:16 pm
Thank you crowfax, atm I'm afraid, you cant do much testing, before it's resolved.
But that shouldn't take long.
mike: the only differences between the original files and the modified ones are:
1. UOPs set to 0, I'm quite sure that is not a problem?
2. removed a (superfluous) null dword at the end
About the latter: all those files (bdmv, mpls, ...) have this extension data block - or rather not.
There's a pointer to it in the file header and when it is zero, there usually is no data appended. Some authoring tools append a length field of zero anyway.
I've seen it on rare occasions, usually it's not there. So I'm quite sure it shouldn't be there, as it also make no sense.
But if that's really the problem that MakeMKV is having, I don't understand why there is no problem with other discs that don't have this appendix anyway.
If you tell me, that the field is required, I can make sure that it is retained in future versions. But that would be a little "messy" imo.
