Cannot backup bluray on 1.15.1
j2020
Post by j2020 » Mon Jun 15, 2020 8:16 pm
Fedora 32, kernel 5.6.15, ryzen 300x, not sure if any of this is useful or if you need any more details.
All versions before 1.15.1 allowed me to backup using this drive, after updating to 1.15.1 I get the following errors:
MakeMKV v1.15.1 linux(x64-release) started
Error 'Internal error - Operation result is incorrect (132)' occurred while issuing SCSI command 280..001 to device 'SG:dev_21:1'
Error 'Posix error - No such device' occurred while issuing SCSI command A30..0020..03F to device 'SG:<unknown>'
Error 'Posix error - No such device' occurred while issuing SCSI command A40..0020..03F to device 'SG:<unknown>'
Error 'Posix error - No such device' occurred while issuing SCSI command A30..0020..07F to device 'SG:<unknown>'
Error 'Posix error - No such device' occurred while issuing SCSI command A40..0020..07F to device 'SG:<unknown>'
Error 'Posix error - No such device' occurred while issuing SCSI command A30..0020..0BF to device 'SG:<unknown>'
Error 'Posix error - No such device' occurred while issuing SCSI command A40..0020..0BF to device 'SG:<unknown>'
Error 'Posix error - No such device' occurred while issuing SCSI command A30..0020..0FF to device 'SG:<unknown>'
Error 'Posix error - No such device' occurred while issuing SCSI command A40..0020..0FF to device 'SG:<unknown>'
Error 'Posix error - No such device' occurred while issuing SCSI command A40..002000800 to device 'SG:<unknown>'
Error 'Posix error - No such device' occurred while issuing SCSI command 280..001 to device 'SG:<unknown>'
Downloading latest HK to /home/user/.MakeMKV ...
Error 'Posix error - No such device' occurred while reading '/AACS/MKB_RO.inf' at offset '13832'
Error 'Posix error - No such device' occurred while reading '/AACS/MKB_RO.inf' at offset '0'
Error 'Posix error - No such device' occurred while reading 'BD-RE PIONEER BD-RW BDR-XS06 1.10' at offset '7340032'
Error 'Posix error - No such device' occurred while reading 'BD-RE PIONEER BD-RW BDR-XS06 1.10' at offset '7344128'
Error 'Posix error - No such device' occurred while reading 'BD-RE PIONEER BD-RW BDR-XS06 1.10' at offset '8388608'
Error 'Posix error - No such device' occurred while reading 'BD-RE PIONEER BD-RW BDR-XS06 1.10' at offset '8392704'
Error 'Posix error - No such device' occurred while reading 'BD-RE PIONEER BD-RW BDR-XS06 1.10' at offset '2949120'
Error 'Posix error - No such device' occurred while reading 'BD-RE PIONEER BD-RW BDR-XS06 1.10' at offset '2988032'
Error 'Posix error - No such device' occurred while reading 'BD-RE PIONEER BD-RW BDR-XS06 1.10' at offset '3997696'
Error 'Posix error - No such device' occurred while reading 'BD-RE PIONEER BD-RW BDR-XS06 1.10' at offset '4036608'
Error 'Posix error - No such device' occurred while reading 'BD-RE PIONEER BD-RW BDR-XS06 1.10' at offset '786432'
Saved AACS dump file as /home/jon/.MakeMKV/MKB_v53_Movie_Name_02C2.tgz
Here are the details on the USB BluRay device (from lsusb):
Bus 006 Device 009: ID 08e4:017a Pioneer Corp. Pioneer Blu-ray Drive
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 9
idVendor 0x08e4 Pioneer Corp.
idProduct 0x017a
bcdDevice 1.00
iManufacturer 1 Pioneer Corporation
iProduct 2 Pioneer Blu-ray Drive
iSerial 3 1248041120900589
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x002c
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 8mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 2 SFF-8020i, MMC-2 (ATAPI)
bInterfaceProtocol 80
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0400 1x 1024 bytes
bInterval 0
bMaxBurst 15
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 15
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 0x0016
bNumDeviceCaps 2
USB 2.0 Extension Device Capability:
bLength 7
bDescriptorType 16
bDevCapabilityType 2
bmAttributes 0x00000002
HIRD Link Power Management (LPM) Supported
SuperSpeed USB Device Capability:
bLength 10
bDescriptorType 16
bDevCapabilityType 3
bmAttributes 0x00
wSpeedsSupported 0x000e
Device can operate at Full Speed (12Mbps)
Device can operate at High Speed (480Mbps)
Device can operate at SuperSpeed (5Gbps)
bFunctionalitySupport 1
Lowest fully-functional device speed is Full Speed (12Mbps)
bU1DevExitLat 0 micro seconds
bU2DevExitLat 0 micro seconds
Device Status: 0x0001
Self Powered
Re: Cannot backup bluray on 1.15.1
Post by d00zah » Mon Jun 15, 2020 8:44 pm
Host certificate revocation historically requires a new release of MakeMKV. LibreDrive eliminates that requirement IF your drive is supported. Sadly, I don't believe any Pioneer drives are currently supported.
j2020
Post by j2020 » Mon Jun 15, 2020 9:49 pm
Thank you for taking the time to reply. Where can I download the lastest "HK" ? I googled around some but couldn't find it.
And when you mention that the certificate revocation requires a new release, does that mean it will probably work in 1.15.2?
Thanks again
Post by d00zah » Tue Jun 16, 2020 12:03 am
The 'Hashed Keys' apply to UHD discs, requiring a "friendly", LibreDrive compatible drive. The download will happen automatically if "allow contacting web server for updates" is checked on the 'General' prefs tab.
New releases happen when they happen. There's no fixed release cycle. Rather than wait, you might consider a LibreDrive capable drive? There's even a forum dedicated to sellers of pre-flashed, tested drives.
Drives for sale, Flashing Services, where to buy...
Edit: As noted elsewhere, try cleaning the disc, no matter how pristine it may appear to the eye.
