Grown Ups - usa version failed to save
shazeh
Post by shazeh » Thu Nov 25, 2010 9:15 pm
Debug log started at Thu Nov 25 20:46:25 2010 , written by MakeMKV v1.6.2 win(x64-release)
001005:0000 MakeMKV v1.6.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Pouya/MakeMKV_log.txt
003019:0000 Cells 32-33 were skipped due to cell commands (structure protection?)
003019:0000 Cells 36-end were skipped due to cell commands (structure protection?)
003028:0000 Title #0 was added (30 cell(s), 1:41:54)
003019:0000 Cells 2-end were skipped due to cell commands (structure protection?)
003028:0000 Title #1 was added (1 cell(s), 0:04:09)
003028:0000 Title #2 was added (1 cell(s), 0:03:50)
003028:0000 Title #3 was added (1 cell(s), 0:07:09)
003019:0000 Cells 7-end were skipped due to cell commands (structure protection?)
003028:0000 Title #47 was added (6 cell(s), 0:13:07)
003028:0000 Title #49 was added (1 cell(s), 0:02:33)
003028:0000 Title #50 was added (1 cell(s), 0:02:27)
003028:0000 Title #51 was added (1 cell(s), 0:02:37)
003028:0000 Title #52 was added (1 cell(s), 0:01:38)
003028:0000 Title #53 was added (1 cell(s), 0:02:32)
003028:0000 Title #54 was added (1 cell(s), 0:02:39)
003028:0000 Title #55 was added (1 cell(s), 0:02:31)
003028:0000 Title #56 was added (1 cell(s), 0:02:26)
003028:0000 Title #58 was added (1 cell(s), 0:02:05)
003028:0000 Title #59 was added (1 cell(s), 0:02:32)
003028:0000 Title #60 was added (1 cell(s), 0:01:03)
003028:0000 Title #61 was added (1 cell(s), 0:02:32)
003028:0000 Title #62 was added (1 cell(s), 0:01:41)
003028:0000 Title #63 was added (1 cell(s), 0:02:27)
003025:0000 Title #65 has length of 1 seconds which is less than minimum title length of 45 seconds and was therefore skipped
003025:0000 Title #75 has length of 1 seconds which is less than minimum title length of 45 seconds and was therefore skipped
003028:0000 Title #76 was added (1 cell(s), 0:01:25)
003025:0000 Title #87 has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
003025:0000 Title #88/1 has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
003025:0000 Title #88/2 has length of 8 seconds which is less than minimum title length of 45 seconds and was therefore skipped
003025:0000 Title #88/3 has length of 1 seconds which is less than minimum title length of 45 seconds and was therefore skipped
003025:0000 Title #89 has length of 1 seconds which is less than minimum title length of 45 seconds and was therefore skipped
003025:0000 Title #89/1 has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
003025:0000 Title #89/2 has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
003025:0000 Title #89/3 has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
003025:0000 Title #89/4 has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
003025:0000 Title #89/5 has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
003025:0000 Title #89/6 has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
003025:0000 Title #89/7 has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
003025:0000 Title #91 has length of 5 seconds which is less than minimum title length of 45 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory C:/Users/Pouya/Desktop/Grown Ups (2010)
001003:0020 DEBUG: Code 2 at KiNt*l4r%!}~DfPa:213135251
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '3843862528'
001003:0020 DEBUG: Code 0 at 0o<[N+g#o1%|/mia:213137091
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '3844255744'
001003:0020 DEBUG: Code 100864256 at C@k1k2cOwjb>Z=Fw0i:29395839
001003:0020 DEBUG: Code 100864256 at C@k1k2cOwjb>Z=Fw0i:121261727
001003:0020 DEBUG: Code 0 at it5[Ba&%1(Ycq#(nLA<:121263958
001003:0020 DEBUG: Code 0 at 4[XX/VGo,o,itCCBLt{E:29394298
001003:0020 DEBUG: Code 0 at IRA_H;]'tP~\ViBpg-3:29393838
001003:0020 DEBUG: Code 0 at 4[XX/VGo,o,itCCBLt{E:29394183
001003:0020 DEBUG: Code 1877078 at 4[XX/VGo,o,itCCBLt{E:29393309
005003:0000 Failed to save title 0 to file C:/Users/Pouya/Desktop/Grown Ups (2010)/t00_Grown_Ups.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Thu Nov 25 21:13:04 2010
setarip_old
Re: Grown Ups - usa version failed to save
Post by setarip_old » Fri Nov 26, 2010 4:41 am
Hi!
This SONY (Columbia) release should be no problem, likely containing only the long in the tooth "ARccOS" copy protection.
Perhaps a dirty or physically damaged disc. Try cleaning the disc...
shazeh
Post by shazeh » Fri Nov 26, 2010 6:05 pm
setarip_old wrote:Hi!
you are right, the disc was scratched. sorry, i jumped the gun.
setarip_old
Post by setarip_old » Fri Nov 26, 2010 6:23 pm
Glad to hear the solution was that simple ;>}
