Hello everyone,
New to this site and looking for some help. I just recently bought the LG WH16NS60 with fw 1.02 and would like to downgrade it to fw 1.00 to be able to backup UHD discs. I am not familiar at this but I would appreciate if someone could please tell me how to do it step by step and what necessary software I would need. I also need the WH16NS60 to be able not to just back discs after the downgrade but also still be able to burn discs. I have Windows 64 bit (MSI MPG Z390M GAMING EDGE AC motherboard) and don't know if I need an external enclosure to do this. This is probably asking for too much but it would be much appreciated. Thanks to all of you in advance.
tmelo35
New LG WH16NS60
Re: New LG WH16NS60
viewtopic.php?f=16&t=19634tmelo35 wrote: ↑Wed Jun 10, 2020 11:06 pmHello everyone,
tmelo35
short version flash WH16NS60 1.02MK and be done with it
Re: New LG WH16NS60
Thank you for the quick reply, Billycar11.
I clicked the link you provided but can't find short version flash WH16NS60 1.02MK.
I have downloaded the both Asus and LG firmware flashers and the fw v1.00 for the WH16NS60.
Do I just put the drive in a compatible external enclosure and just update the firmware from 1.02 to 1.00 using one of the flashers?
Sorry for so many questions, I'm just new to this and don't want to mess up.
Thanks again,
tmelo35
Thanks again,
tmelo35
Re: New LG WH16NS60
I think you should email me for a remote flash billycar5924@gmail.comtmelo35 wrote: ↑Thu Jun 11, 2020 2:05 pmThank you for the quick reply, Billycar11.
Thanks again,
tmelo35
tragic bleak
Re: New LG WH16NS60
You should have no problem following my very detailed step-by-step instructions for this drive at viewtopic.php?f=16&t=19928tmelo35 wrote: ↑Thu Jun 11, 2020 2:05 pmThank you for the quick reply, Billycar11.
Thanks again,
tmelo35
Re: New LG WH16NS60
Thanks a million, tragic bleak.
I followed your instructions and it worked perfectly.
I ripped a 4k disc with no problems so far.
I'm just curious, I use DVDFab a lot and it requires firmware 1.00, is it possible to downgrade using the same steps and will it still work the same?
Once again, thanks for your help,
tmelo35
tmelo35
Re: New LG WH16NS60
Yes you can go to 1.00 aftertmelo35 wrote: ↑Fri Jun 12, 2020 3:27 amThanks a million, tragic bleak.
tmelo35
Re: New LG WH16NS60
Thanks, Billycar11.
Is this the correct one?: DE_LG WH16NS60_1.00.bin
