thetoad
#2566 Post by thetoad » Mon Jun 08, 2020 1:39 pm
can one do it on any other dolby vision bluray player? if not, I'd make a guess that its a dolby restriction, not allowing dolby vision content to be viewed in manners that they dislike
box4m
#2567 Post by box4m » Mon Jun 08, 2020 2:29 pm
flashback8 wrote:
Sun Jun 07, 2020 10:07 pm
sonysg wrote:
Tue Jun 02, 2020 12:32 am
sonysg wrote:
Tue May 26, 2020 5:23 am
Dear all,
I'm using OPPO 205 and Sony X950G
I have a problem when playing Dolby Vision disc or MP4 muxed Dolby Vision files
How could we enforced film to full screen(No Black bar) when play back DV contains? It said this operation is not permitted when I pressed "Zoom" on the Oppo's remote
I could do full screen easily on HDR10 but not in Dolby Vision format, only Full screen Dolby Vision contain could (i.e BumbleBee, Transformer 4) :( I wish I could to do that for every Dolby Vision titles to enhance the movie viewing experience
How to we bypass this restriction? it could because of the metadata of second layer(1920*1080) of Dolby Vision contains prevent this to be happened, because muxing Dolby Vision using MP4 container is possible now, I would like to save hard disk space and get rid of black bar whenever possible, Does MakeMKV allow or maximise the full screen properties when muxing in MP4 format?
Looking forward for your suggestion
I'm sorry to bumped up this question but no one seem to be giving me an overall idea on this
Is this restriction on the player itself or the DV authoring prevent the "Zoom" happening but its possible still on HDR10 contains
It's due to the processing chips being underpowered (or so Oppo claimed long ago). The 203/205 replacements presumably would've addressed that flaw, and others.
This is interesting, what replacements do u mean btw?
GabryLiv
#2568 Post by GabryLiv » Mon Jun 08, 2020 3:58 pm
Hello
Can you explain how the mel or fel files are recognized?
what is the procedure to insert the dolby vision into the mp4?
Demux the hevc file and the audio with tsmuxer
After how do we proceed?
flashback8
#2569 Post by flashback8 » Mon Jun 08, 2020 6:08 pm
sonysg wrote:
Mon Jun 08, 2020 1:14 pm
Do you have news or link for that claimed its underpowered? Oppo already stop the production of 203/205 unlikely they would fix this issue on these model, too bad not much UHD Bluray player out there now :(
It's buried somewhere in the Oppo-203/205 thread on the blu-ray.com forum. They talked about it sometime in 2018, I think.
flashback8
#2570 Post by flashback8 » Mon Jun 08, 2020 6:09 pm
Oppo would've come out with a newer player at some point. One of their execs is an A/V nut and pushed real hard for quality players. Alas, phones were too profitable, so Oppo ended up disbanding the A/V division (or greatly reducing it, perhaps) so that there would be more time and factory space dedicated to phones.
sonysg
#2571 Post by sonysg » Tue Jun 09, 2020 9:29 am
if anyone know a UHD Player that could do full zoom of Dolby Vision please let us know the model
Likely there would not be any player so far what I heard but still hoping its not restriction from Dolby Lab that prevent full screen to be happen :|
djbuddha
#2572 Post by djbuddha » Tue Jun 09, 2020 6:27 pm
jlpsvk wrote:
Mon Jun 01, 2020 10:33 am
so... I achieved this... with the help of mp4box :) i think, would be good enough. :)
1) demux with tsMuxer...
2) encode BL
3) mux BL_encode.hevc with EL.hevc with yousesope's tools with mode 2 to BL+RPU
4) mux only video to mp4 with mp4muxer 1.0.1
5) add audio, subs, chapters to MP4 with mp4box
So I followed these steps, and changed it a little, here are the results.
Demuxed the file
muxed the BL & EL using yousesope w/ mode 2
muxed the BL+RPU with all the other assets (subs and all the other audio) to .TS (using the tsMuxer nightly that you linked... thank you btw)
Here's what I found:
- My Apple TV 4K plays the file as Dolby Vision via Infuse. The Atmos track plays as 7.1 which is fine (as the Apple TV can't play Atmos from Infuse from the disc's audio file anyway).
- My nVidia Shield 2017 plays the file as HDR10 (plays fine) and Atmos plays back perfectly.
- All subs work.
So .... it looks like I got it right. Getting my hands on a new 2019 Shield Pro at some point. In THEORY this resulting .TS file should play both the Dolby Vision & Atmos ...
Am I getting this right?
I don't care if the container is MP4, MKV or TS .. for Dolby Vision titles they will get their own folder anyway given the way I organize... but this SHOULD be ok no?
#2573 Post by shawnc22 » Tue Jun 09, 2020 11:15 pm
2) encode BL
Demuxed the file
- All subs work.
When you get a 2019 Shield pro, hopefully the DV standard for MKV is set in place by then, and you can just go directly from disk to mkv with makemkv and be done. If not, the files you have already created will play fine, but they are missing the EL, so titles that have a full enhancement layer might not be shown in the way they were intended to.
djbuddha
#2574 Post by djbuddha » Wed Jun 10, 2020 12:04 am
2) encode BL
Demuxed the file
- All subs work.
Wait, doesn't yousesope's script put the layer in the newly exported hevc file before remuxing it to TS?
djbuddha
#2575 Post by djbuddha » Wed Jun 10, 2020 12:28 am
2) encode BL
Demuxed the file
- All subs work.
Update, I tried this process using a Dolby Vision / Atmos demo disc & earlier with The Matrix Reloaded and ran into an issue of sorts.
Dolby Disc: If I try to mux the TrueHD 4974 kbps track (AC3 core + TrueHD 640 kbps) @ 48 kHz track from the Dolby disc, that track is completely unplayable
The Matrix Reloaded: If I mux the TrueHD 7794 kbps track (AC3 core + TrueHD 448 kbps) @ 48 kHz track from the Matrix Reloaded disc, that track plays perfectly.
Is the core track being that high of a bitrate really causing the issue? (the 448 works, the 640 doesn't)
If I try to play a 2 minute clip at 640 it stutters like crazy.
If I play the entire Matrix Reloaded movie at 448 kbps it plays perfectly.
Same results with both the Apple TV 4K & the 2017 nVidia Shield
Anybody got any ideas? The Dolby Vision comes through but is useless as the audio is going crazy on the Dolby disc with the 640 kbps ACE core + True HD track.
#2576 Post by shawnc22 » Wed Jun 10, 2020 3:54 am
When you use yusecope's tool in mode 2, it discards the enhancement layer (EL)-resulting in a BL+RPU file. You have to do this for playback on the AppleTV because there is no dual layer support. The Shield does support dual-layer (BL+EL+RPU), so you're free to use yusecope's tool in its default mode.
PapitaHD
#2577 Post by PapitaHD » Fri Jun 12, 2020 5:22 pm
Hi all, I've been doing some quite thorough testing with Gemini Man 60fps-DV, so I thought some of you would might be interested in the result, here they are:
I encoded the BL with x265, using mostly slow preset and crf17 and I used the encoded file as BL for all my tests.
The attempts that didn't work at all: yusesope's tool v0.0.4 default mode, muxed with DV profile 4 and 6 both with tsMuxer and mp4muxer. All of these files seemed to be good in mediainfo but non of them was playable neither on my LG C8 nor M9702.
I made a profile 7 (dvhe.07.09) dual layer version with mp4muxer and it played perfectly on M9702 but on LG C8 it always froze after about 10 minutes. When it froze I was always able to cancel and then it started from the point where it stopped, I was also able to seek, and it played smoothly without any lags but after 10 minutes it always froze no matter what point I was watching it from.
Then I used mode 2 of yusesope's tool to make a BL+RPU hevc file and muxed it with tsMuxeR to get profile 5 (dvhe.05.09) DV in .TS container. Guess what, it plays perfectly on my C8. I watched the whole movie and there weren't any kind of lags or artifacts. I used TrueHD Atmos and also 2 other DD tracks.
If any of you would like to play it on an LG TV, this is the way to do it.
#2578 Post by shawnc22 » Fri Jun 12, 2020 9:21 pm
It makes sense if the original issue is that the LG is unable to process the EL due to maybe processing power. Using mode 2 strips away the EL entirely, so it's probably less demanding to play. The tradeoff is that since Gemini Man has an FEL, the resulting picture may not be entirely accurate when the EL is stripped away.
box4m
#2579 Post by box4m » Sun Jun 14, 2020 11:28 am
Did anyone get profile 4/6 to play in MXPlayer on 2019 Shield?
hehoheho
#2580 Post by hehoheho » Mon Jun 15, 2020 2:00 pm
RESET_9999 wrote:
Wed Jan 29, 2020 5:39 pm
box4m wrote:
Wed Jan 29, 2020 5:21 pm
Are you saying that x700 plays dual layer dolby vision mp4s? From network share or usb?
Where can i find more info?
Thx
Yes the x700 plays Dual & Single layer DV MP4 with LPCM 7.1 via USB. Some titles just wont play ( about 2 or 3) but I watched more than 100 DV dual layer with lossless audio without any problems.
I read somewhere(in this thread i think) that it also works from a network but the slow 100mbps ethernet port caused playback issues.
here's what is supported with the x700:
MP4 DV (SL & DL) + lpcm 7.1 = play perfectly fine. (subtitles dont work)
M2TS / TS + atmos = HDR10 only but atmos is supported.
MKV + atmos - HDR10 but atmos not supported (because the core is separated)
MKV + DTS-X / DTSHD = HDR10 and all the DTS family is supported.
Burned ISO = Dolby vision + atmos supported. (latest Tsmuxer can now create compliant DV bluray structure)https://forum.doom9.org/showthread.php?t=176668&page=16
no cinavia... But i only use it for DV mp4 remux, I wish there was a device that can do it all......
I use my HTPC for HDR10 and the new Shield for everything that is streaming....Netflix in DV + Atmos.. amazon, movies anywhere, vudu. etc...
Sorry for my english...
Would you please advise how to play ISO on X700 as per you mentioned?
It is dual layer Dolby Vision with Dolby Atmos plays at the same time? Could play with custom subtitle file as well?
And how about if the ISO is placed on NAS?
Thx!
