First Blood
bokonon
First Blood
First Blood BluRay fails. It reads the disc fine apparently but when I rip it it gets to 11 Megs or so and then it stops reading, no further errors in logfile, gives the error that the programm must exit.
Process: makemkvcon [36966]
Path: /Applications/MakeMKV.app/Contents/MacOS/makemkvcon
Identifier: makemkvcon
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: makemkv [36964]
Date/Time: 2010-07-17 09:01:41.021 -0700
OS Version: Mac OS X 10.6.4 (10F34)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: 0x000000000000000d, 0x0000000000000000
Crashed Thread: 3
Thread 0: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x93ad8136 semaphore_wait_trap + 10
1 libSystem.B.dylib 0x93b52bc3 pthread_join + 756
2 makemkvcon 0x0002c2b8 0x1000 + 176824
3 makemkvcon 0x00004126 0x1000 + 12582
4 makemkvcon 0x00002982 0x1000 + 6530
5 makemkvcon 0x000028a9 0x1000 + 6313
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x93afe942 kevent + 10
1 libSystem.B.dylib 0x93aff05c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x93afe519 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x93afe2be _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x93afdd41 _pthread_wqthread + 390
5 libSystem.B.dylib 0x93afdb86 start_wqthread + 30
Thread 2:
0 libSystem.B.dylib 0x93b4e22e sem_wait + 10
1 makemkvcon 0x0002d201 0x1000 + 180737
2 makemkvcon 0x0002ba03 0x1000 + 174595
3 makemkvcon 0x0002bbdf 0x1000 + 175071
4 libSystem.B.dylib 0x93b0581d _pthread_start + 345
5 libSystem.B.dylib 0x93b056a2 thread_start + 34
Thread 3 Crashed:
0 ??? 0xa0685014 typeinfo for std::bad_alloc + 8
1 libmakemkv.dylib 0x0042fa00 set_world + 2352
Thread 4:
1 makemkvcon 0x00009ad4 0x1000 + 35540
2 makemkvcon 0x00008d63 0x1000 + 32099
3 libSystem.B.dylib 0x93b0581d _pthread_start + 345
4 libSystem.B.dylib 0x93b056a2 thread_start + 34
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 3 crashed with X86 Thread State (32-bit):
eax: 0xa0684fa8 ebx: 0xb020151e ecx: 0x00b06a13 edx: 0xb0201520
edi: 0xb02013a8 esi: 0xb02012a8 ebp: 0xb02012d8 esp: 0xb0201254
ss: 0x0000001f efl: 0x00010286 eip: 0xa0685014 cs: 0x00000017
ds: 0x00000000 es: 0x0000001f fs: 0x0000001f gs: 0x00000037
cr2: 0xa0684fcc
Version: ??? (???)
Report Version: 6
Crashed Thread: 3
Thread 2:
Thread 3 Crashed:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
cr2: 0xa0684fcc
- Contact:
Re: First Blood
Ouch. You do have "log debug messages" enabled in preferences and nothing is shown? Are you processing blu-ray disc?
bokonon
Re: First Blood
Yes I have log debug messages shown. I checked Console and didn't see anything else logged. The app's spew didn't list anything either. Is there another log somewhere I can check?
thanks
thanks
bokonon
Re: First Blood
oooh, found it in my home directory. Hopefully this helps...
servocrow
Re: First Blood
any fix available for this title?
- Contact:
Re: First Blood
Should work with latest version. If it doesn't please post the debug log.servocrow wrote:any fix available for this title?
servocrow
Re: First Blood
tried another retail copy and it worked fine, all is well
MrTeagan
Re: First Blood
I've tried two copies and same thing, fails 225 Mbs into the read. I have the latest version.
Director
servocrow
Re: First Blood
from what i can tell it differs from disc to disc, most likley it is either a bad batch or it was pressed at a different location. I tried a copy from Netflix, thats the one I couldnt get to work, the other one was borrowed from a friend and worked fine. The problematic disc alll have the same symptoms.
I thought about trying it this way, but never did, try ripping it via DVDFAB then push it through HANDBRAKE, i bet that might work.
MrTeagan
- Contact:
Re: First Blood
Please try to make a decrypted disc backup from this disc and see if any errors show up. It it works, try to open produced backup with MakeMKV.MrTeagan wrote:I've tried two copies and same thing, fails 225 Mbs into the read. I have the latest version.
MrTeagan
MrTeagan
Re: First Blood
OK, here's my debug list. Got a third copy of this blu today, fails exactly at the same place.
Director
setarip_old
Re: First Blood
@MrTeagan
Hi!
Can you currently successfully process ANY Blu-rays - or are you experiencing this same problem with some or all of them?
Hi!
MrTeagan
Re: First Blood
Every title is fine except this one and other folks are having the same issue.
Director
