Can I get previous versions of MakeMKV?
klatk2
I'm running 10.6.8 (snow leopard) and was hoping I could get a version of MakeMKV that does not have 10.7 as a system requirement. Is there any way I can get a link to a compatible version? I couldn't find it anywhere clicking around...
klatk2
Bocheh
Re: Can I get previous versions of MakeMKV?
Is it possible to get an earlier version of MakeMkv that will run on Mac OS 10.6.8 I have a Mac pro and This is the highest OS it can run.
For Windows and MacOS, the oldes is 1.14.7. I'm sure the reason for that has a lot to do with the ability to handle newer versions of AACS; if you regressed far enough back to get support for your version of MacOS, you would be limited to BDs produced more than 2 years ago.
If you accidentally inserted a BD with a newer AACS, your drive would be locked out of doing BDs completely.
Bocheh
Where can i get the 1.14.7 for Mac OS 10.6.8?
Bocheh
where do I get the registration key for the older version???
Bocheh
I found the registration process and I am running the software currently. Thanks for the help.
Love the product.
Love the product.
For others reading this, the registration keys are the same for all versions. Permanent keys always work, beta keys expire every 60 days or so.
With version 1.14.7 and a LibreDrive-compatible BD drive, AACS compatibility can be updated through the LD mechanism.
