Jet Li - Fearless; fails to rip
Kappabear
Post by Kappabear »
A few weeks ago, I ripped the DVD "Jet Li - Fearless" and finally got around to watching it today, when I realized that I didn't include the subtitles. So, I'm now attempting to rip the DVD again, for whatever reason, it continually fails, and I have NO idea why.
I've unchecked all of the Subtitles, in an attempt to see if the DVD will rip, but it still fails. I've also, unchecked all of the audio, and it still fails.
This is the error that I continually receive, and I have no idea what it means:
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Help, please.
MakeMKV v1.15.1 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/me/MakeMKV_log.txt
Optical drive "DVD+R-DL TSSTcorp CDDVDW SH-S202N SB02d" opened in OS access mode.
Complex multiplex encountered - 19 cells and 5313 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Navigation information is invalid around 0:20:59 - check output file for AV sync errors
Navigation information is invalid around 0:22:27 - check output file for AV sync errors
Navigation information is invalid around 1:15:39 - check output file for AV sync errors
Navigation information is invalid around 1:16:33 - check output file for AV sync errors
Navigation information is invalid around 1:31:39 - check output file for AV sync errors
Navigation information is invalid around 1:32:16 - check output file for AV sync errors
Navigation information is invalid around 1:41:08 - check output file for AV sync errors
Navigation information is invalid around 1:43:32 - check output file for AV sync errors
Title #1 was added (46 cell(s), 1:43:10)
Complex multiplex encountered - 19 cells and 5300 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
DEBUG: Code 1822682 at kub#JBFm77?&s)t~:121263383
DEBUG: Code 0 at +&T~w-Xdxqy3Dar84#:121273457
DEBUG: Code 0 at +&T~w-Xdxqy3Dar84#:29406580
Title #2 (1:43:04) was skipped due to navigation error
Title #3 was added (5 cell(s), 0:04:50)
Title #4 was added (1 cell(s), 0:06:47)
Title #5 was added (3 cell(s), 0:16:03)
Title #6 has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/me/Movies/Rips
AV synchronization issues were found in file '/Users/me/Movies/Rips/title_t00.mkv' (title #1)
AV sync issue in stream 0 at 0:00:30.530 : video frame timecode differs by -16.7ms
AV sync issue in stream 0 at 0:00:33.917 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:00:35.752 : video frame timecode differs by -16.716ms
AV sync issue in stream 0 at 0:00:38.004 : video frame timecode differs by -16.711ms
AV sync issue in stream 0 at 0:00:40.256 : video frame timecode differs by -16.716ms
AV sync issue in stream 0 at 0:00:42.175 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:00:49.849 : video frame timecode differs by -16.711ms
AV sync issue in stream 0 at 0:00:50.433 : video frame timecode differs by -16.716ms
AV sync issue in stream 0 at 0:00:51.634 : video frame timecode differs by -16.705ms
AV sync issue in stream 0 at 0:01:16.209 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:01:31.724 : video stream has 13 frames with invalid timecodes
AV sync issue in stream 0 at 0:01:40.266 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:01:45.522 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:01:52.112 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:02:34.521 : video frame timecode differs by -16.711ms
AV sync issue in stream 0 at 0:02:40.660 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:02:45.331 : video frame timecode differs by -16.711ms
AV sync issue in stream 0 at 0:02:46.082 : video frame timecode differs by -16.716ms
AV sync issue in stream 0 at 0:02:47.667 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:02:49.669 : video frame timecode differs by -16.711ms
AV sync issue in stream 0 at 0:03:08.855 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:03:11.941 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:03:13.860 : video frame timecode differs by -16.711ms
AV sync issue in stream 0 at 0:03:20.450 : video frame timecode differs by -16.716ms
AV sync issue in stream 0 at 0:03:28.658 : video frame timecode differs by -16.705ms
AV sync issue in stream 0 at 0:03:32.212 : video frame timecode differs by -16.711ms
AV sync issue in stream 0 at 0:03:34.380 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:03:45.308 : video frame timecode differs by -16.694ms
AV sync issue in stream 0 at 0:03:48.144 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:03:48.678 : video frame timecode differs by -16.705ms
AV sync issue in stream 0 at 0:03:48.811 : video frame timecode differs by -16.716ms
AV sync issue in stream 0 at 0:03:52.982 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:03:56.853 : video frame timecode differs by -16.716ms
AV sync issue in stream 0 at 0:03:58.488 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:04:00.907 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:04:11.951 : video frame timecode differs by -16.688ms
AV sync issue in stream 0 at 0:04:12.168 : video frame timecode differs by -16.705ms
AV sync issue in stream 0 at 0:04:13.670 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:04:16.422 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:04:19.842 : video frame timecode differs by -16.716ms
AV sync issue in stream 0 at 0:04:20.460 : video frame timecode differs by -16.711ms
AV sync issue in stream 0 at 0:04:22.462 : video frame timecode differs by -16.7ms
AV sync issue in stream 0 at 0:04:25.265 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:04:27.300 : video frame timecode differs by -16.711ms
AV sync issue in stream 0 at 0:04:30.436 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:04:38.695 : video frame timecode differs by -16.716ms
AV sync issue in stream 0 at 0:04:40.947 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:04:55.745 : video frame timecode differs by -16.716ms
AV sync issue in stream 0 at 0:05:00.466 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:05:03.419 : video frame timecode differs by -16.716ms
AV sync issue in stream 0 at 0:05:06.639 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:05:06.639 : too many video frames with invalid timecodes, future messages will be suppressed
AV sync issue in stream 0 at 0:05:18.935 : video stream has 56 frames with invalid timecodes
AV sync issue in stream 0 at 0:05:42.975 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:05:49.766 : video frame timecode differs by -16.705ms
AV sync issue in stream 0 at 0:05:52.068 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:06:04.497 : video stream has 4 frames with invalid timecodes
AV sync issue in stream 0 at 0:06:34.143 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:06:41.517 : video frame timecode differs by -16.716ms
AV sync issue in stream 0 at 0:06:46.739 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:06:56.332 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:06:59.919 : video frame timecode differs by -16.711ms
AV sync issue in stream 0 at 0:07:08.878 : video frame timecode differs by -16.705ms
AV sync issue in stream 0 at 0:07:10.930 : video frame timecode differs by -16.711ms
AV sync issue in stream 0 at 0:07:14.684 : video frame timecode differs by -16.716ms
AV sync issue in stream 0 at 0:07:26.279 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:07:57.393 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:08:03.149 : video frame timecode differs by -16.711ms
AV sync issue in stream 0 at 0:08:12.992 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:08:14.944 : video frame timecode differs by -16.705ms
AV sync issue in stream 0 at 0:08:20.750 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:08:25.671 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:08:51.113 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:08:57.370 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:09:09.298 : video frame timecode differs by -16.716ms
AV sync issue in stream 0 at 0:09:10.550 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:09:22.979 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:09:23.563 : video frame timecode differs by -16.711ms
AV sync issue in stream 0 at 0:09:34.156 : video frame timecode differs by -16.716ms
AV sync issue in stream 0 at 0:09:37.994 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:09:40.079 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:09:44.951 : video frame timecode differs by -16.711ms
AV sync issue in stream 0 at 0:09:49.005 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:09:50.539 : video frame timecode differs by -16.705ms
AV sync issue in stream 0 at 0:09:54.760 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:09:58.514 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:10:08.608 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:10:15.197 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:10:25.791 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:10:28.878 : video frame timecode differs by -16.705ms
AV sync issue in stream 0 at 0:10:43.726 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:10:48.481 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:10:59.942 : video frame timecode differs by -16.716ms
AV sync issue in stream 0 at 0:11:10.169 : video frame timecode differs by -16.711ms
AV sync issue in stream 0 at 0:11:12.838 : video frame timecode differs by -16.722ms
AV sync issue in stream 0 at 0:11:13.839 : video frame timecode differs by -16.7ms
AV sync issue in stream 0 at 0:11:22.264 : video frame timecode differs by -16.727ms
AV sync issue in stream 0 at 0:11:22.264 : too many video frames with invalid timecodes, future messages will be suppressed
AV sync issue in stream 0 at 0:20:08.323 : video stream has 139 frames with invalid timecodes
AV sync issue in stream 0 at 0:20:20.602 : video frame timecode differs by -16.727ms
Too many AV synchronization issues in file '/Users/me/Movies/Rips/title_t00.mkv' (title #1) , future messages will be printed only to log file
DEBUG: Code 4294967295 at 12n3M84.-Z~c`8wRW71Q/:29402026
DEBUG: Code 2 at )b[jIhsx!8@BKYK{(i~:29400508
DEBUG: Code 0 at )b[jIhsx!8@BKYK{(i~:29399956
DEBUG: Code 0 at 12n3M84.-Z~c`8wRW71Q/:29400140
Failed to save title 0 to file /Users/me/Movies/Rips/title_t00.mkv
0 titles saved, 1 failed
DEBUG: Code 4294966314 at 3XA:9URij{|ddd&kf0hw:121275389
DEBUG: Code 0 at 3XA:9URij{|ddd&kf0hw:213140633
DEBUG: Code 0 at %$4P&W?OM;\l}eqJ:29396138
DEBUG: Code 0 at _kAnP8/ QH,5@aS^C:121264464
DEBUG: Code 0 at _kAnP8/ QH,5@aS^C:121263912
DEBUG: Code 0 at _kAnP8/ QH,5@aS^C:213130145
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Re: Jet Li - Fearless; fails to rip
Give it a wipe down with a CLEAN damp cotton or microfiber cloth and try again. The errors look like the laser is trying to read the disk through a foggy layer (happens when disks are stored in closed cases).
Kappabear
Post by Kappabear »
Woodstock wrote: Mon Jun 08, 2020 1:43 pm Give it a wipe down with a CLEAN damp cotton or microfiber cloth and try again. The errors look like the laser is trying to read the disk through a foggy layer (happens when disks are stored in closed cases).
Thanks Woodstock. I gave the disc a bath with a dot of Dawn liquid soap and water, and that helped. You're absolutely correct in that the disc has been sitting for years in a closed case.
