Can I get previous versions of MakeMKV?
klatk2
#1 Post by klatk2 » Sun Jun 07, 2020 9:52 pm
I'm running 10.6.8 (snow leopard) and was hoping I could get a version of MakeMKV that does not have 10.7 as a system requirement. Is there any way I can get a link to a compatible version? I couldn't find it anywhere clicking around...
Re: Can I get previous versions of MakeMKV?
#2 Post by d00zah » Sun Jun 07, 2020 10:26 pm
Link in sig.
klatk2
#3 Post by klatk2 » Mon Jun 08, 2020 5:51 pm
Bocheh
#4 Post by Bocheh » Sun Jul 19, 2020 6:56 am
Is it possible to get an earlier version of MakeMkv that will run on Mac OS 10.6.8 I have a Mac pro and This is the highest OS it can run.
#5 Post by Woodstock » Sun Jul 19, 2020 2:41 pm
For Windows and MacOS, the oldes is 1.14.7. I'm sure the reason for that has a lot to do with the ability to handle newer versions of AACS; if you regressed far enough back to get support for your version of MacOS, you would be limited to BDs produced more than 2 years ago.
If you accidentally inserted a BD with a newer AACS, your drive would be locked out of doing BDs completely.
Bocheh
#6 Post by Bocheh » Sun Jul 19, 2020 4:07 pm
Where can i get the 1.14.7 for Mac OS 10.6.8?
Bocheh
#7 Post by Bocheh » Sun Jul 19, 2020 4:24 pm
where do I get the registration key for the older version???
Bocheh
#8 Post by Bocheh » Sun Jul 19, 2020 4:46 pm
I found the registration process and I am running the software currently. Thanks for the help.
Love the product.
#9 Post by Woodstock » Sun Jul 19, 2020 6:15 pm
For others reading this, the registration keys are the same for all versions. Permanent keys always work, beta keys expire every 60 days or so.
With version 1.14.7 and a LibreDrive-compatible BD drive, AACS compatibility can be updated through the LD mechanism.
