Hi, I want to describe my use case before purchasing, hopefully someone has had a similar use case before.
I run MakeMKV through docker on the UnRaid platform. I have multiple disc drives, as a result, I have multiple containers of MakeMKV (One for each drive.)
If I purchased a key, would it cover each instance I have of MakeMKV running on this system, or would one have to buy a key for each container of MakeMKV?
Thank you
Key purchase - pre purchase question - Docker
StarLord
Re: Key purchase - pre purchase question
Mike has said the key is for one user, with nothing said about how many instances that user is running. I use mine on up to three machines at a time... one user.
Running it on your FRIEND'S machine while you're using it, that's more than one user.
Oh, and the "packager" versions, like Docker and Flatpak, are not from Mike; Those are where someone else packaged up MakeMKV to "help" people.
StarLord
Thanks for the reply,Woodstock wrote: Sun Jun 07, 2020 3:24 pm Mike has said the key is for one user, with nothing said about how many instances that user is running. I use mine on up to three machines at a time... one user.
It does now give me pause to consider whether these docker images would even validate correctly as they aren't Mike's direct software release.
Re: Key purchase - pre purchase question - Docker
People have asked Mike when he is going to choose a package for distribution. I've never seen him answer. You really cannot choose ONE, because the "portable packages" are just as insular as the "distribution packages".
